| | delete "system volume information" I used retrospect backup software to make a copy of my old computer so that I could access the files. I am done with the files and am trying to delete them. I can delete them all except for the "system volume information" folder. Any ideas how to do this? |
| | RE: delete "system volume information" System Volume Information is a system folder containing restore points. (Is your old computer running Windows XP?) It's not a folder where user data is stored. Is this folder located on your active system disc, or on a separate partition or drive? Why are you trying to delete these files? Maybe if you tell us exactly what you are trying to do, and why you are trying to do it, someone will be able to help. "Aaron Wheeler" wrote: > I used retrospect backup software to make a copy of my old computer so that I > could access the files. I am done with the files and am trying to delete > them. I can delete them all except for the "system volume information" > folder. Any ideas how to do this? |
| | RE: delete "system volume information" Thanks for your help, Jimmuh. Sorry if the first post was unclear. My old computer ran XP and my new one runs Vista. I used backup software to copy my old computer's C-volume into a folder on my new computer. This folder contains all of the hidden/system/user-generated/etc. files from my old computer. I have extracted all of the relevant information from this folder, and would like to delete it. However, when I try to do so, I am prevented from deleting the "system volume information" folder. Note that this folder is completely useless and meaningless (has nothing to do with my new computer's hidden/system files/etc.). Hope that's clear. I would like to delete this folder. Any suggestions? "jimmuh" wrote: > System Volume Information is a system folder containing restore points. (Is > your old computer running Windows XP?) It's not a folder where user data is > stored. Is this folder located on your active system disc, or on a separate > partition or drive? Why are you trying to delete these files? > > Maybe if you tell us exactly what you are trying to do, and why you are > trying to do it, someone will be able to help. > > "Aaron Wheeler" wrote: > > > I used retrospect backup software to make a copy of my old computer so that I > > could access the files. I am done with the files and am trying to delete > > them. I can delete them all except for the "system volume information" > > folder. Any ideas how to do this? |
| | RE: delete "system volume information" Okay, I think I understand now. Sorry, I'm a little slow on the uptake sometimes. (That ought to make you wonder about taking advice from me!) If I understand you correctly this problem folder is now just a junk folder in a subdirectory on your new system, and it has, therefore, nothing to do with the system files on the new computer. You can right-click on that directory and select Properties from the context menu. On the Security tab of the Properties dialog you'll see an Advanced button. Go in there and take ownership of that directory and all of its contents. After that you should be able to blow it away. (It still thinks it's owned by the other system.) "Aaron Wheeler" wrote: > Thanks for your help, Jimmuh. Sorry if the first post was unclear. My old > computer ran XP and my new one runs Vista. > > I used backup software to copy my old computer's C-volume into a folder on > my new computer. This folder contains all of the > hidden/system/user-generated/etc. files from my old computer. I have > extracted all of the relevant information from this folder, and would like to > delete it. However, when I try to do so, I am prevented from deleting the > "system volume information" folder. Note that this folder is completely > useless and meaningless (has nothing to do with my new computer's > hidden/system files/etc.). > > Hope that's clear. I would like to delete this folder. Any suggestions? > > "jimmuh" wrote: > > > System Volume Information is a system folder containing restore points. (Is > > your old computer running Windows XP?) It's not a folder where user data is > > stored. Is this folder located on your active system disc, or on a separate > > partition or drive? Why are you trying to delete these files? > > > > Maybe if you tell us exactly what you are trying to do, and why you are > > trying to do it, someone will be able to help. > > > > "Aaron Wheeler" wrote: > > > > > I used retrospect backup software to make a copy of my old computer so that I > > > could access the files. I am done with the files and am trying to delete > > > them. I can delete them all except for the "system volume information" > > > folder. Any ideas how to do this? |
| | RE: delete "system volume information" Awesome -- that does it. Thanks! "jimmuh" wrote: > Okay, I think I understand now. Sorry, I'm a little slow on the uptake > sometimes. (That ought to make you wonder about taking advice from me!) > > If I understand you correctly this problem folder is now just a junk folder > in a subdirectory on your new system, and it has, therefore, nothing to do > with the system files on the new computer. You can right-click on that > directory and select Properties from the context menu. On the Security tab of > the Properties dialog you'll see an Advanced button. Go in there and take > ownership of that directory and all of its contents. After that you should be > able to blow it away. (It still thinks it's owned by the other system.) > > "Aaron Wheeler" wrote: > > > Thanks for your help, Jimmuh. Sorry if the first post was unclear. My old > > computer ran XP and my new one runs Vista. > > > > I used backup software to copy my old computer's C-volume into a folder on > > my new computer. This folder contains all of the > > hidden/system/user-generated/etc. files from my old computer. I have > > extracted all of the relevant information from this folder, and would like to > > delete it. However, when I try to do so, I am prevented from deleting the > > "system volume information" folder. Note that this folder is completely > > useless and meaningless (has nothing to do with my new computer's > > hidden/system files/etc.). > > > > Hope that's clear. I would like to delete this folder. Any suggestions? > > > > "jimmuh" wrote: > > > > > System Volume Information is a system folder containing restore points. (Is > > > your old computer running Windows XP?) It's not a folder where user data is > > > stored. Is this folder located on your active system disc, or on a separate > > > partition or drive? Why are you trying to delete these files? > > > > > > Maybe if you tell us exactly what you are trying to do, and why you are > > > trying to do it, someone will be able to help. > > > > > > "Aaron Wheeler" wrote: > > > > > > > I used retrospect backup software to make a copy of my old computer so that I > > > > could access the files. I am done with the files and am trying to delete > > > > them. I can delete them all except for the "system volume information" > > > > folder. Any ideas how to do this? |
| | #6 (permalink) |
| | RE: delete "system volume information" You are most welcome. It is seldom, indeed, that I get a chance to be useful to anyone. ;-) "Aaron Wheeler" wrote: > Awesome -- that does it. Thanks! > > "jimmuh" wrote: > > > Okay, I think I understand now. Sorry, I'm a little slow on the uptake > > sometimes. (That ought to make you wonder about taking advice from me!) > > > > If I understand you correctly this problem folder is now just a junk folder > > in a subdirectory on your new system, and it has, therefore, nothing to do > > with the system files on the new computer. You can right-click on that > > directory and select Properties from the context menu. On the Security tab of > > the Properties dialog you'll see an Advanced button. Go in there and take > > ownership of that directory and all of its contents. After that you should be > > able to blow it away. (It still thinks it's owned by the other system.) > > > > "Aaron Wheeler" wrote: > > > > > Thanks for your help, Jimmuh. Sorry if the first post was unclear. My old > > > computer ran XP and my new one runs Vista. > > > > > > I used backup software to copy my old computer's C-volume into a folder on > > > my new computer. This folder contains all of the > > > hidden/system/user-generated/etc. files from my old computer. I have > > > extracted all of the relevant information from this folder, and would like to > > > delete it. However, when I try to do so, I am prevented from deleting the > > > "system volume information" folder. Note that this folder is completely > > > useless and meaningless (has nothing to do with my new computer's > > > hidden/system files/etc.). > > > > > > Hope that's clear. I would like to delete this folder. Any suggestions? > > > > > > "jimmuh" wrote: > > > > > > > System Volume Information is a system folder containing restore points. (Is > > > > your old computer running Windows XP?) It's not a folder where user data is > > > > stored. Is this folder located on your active system disc, or on a separate > > > > partition or drive? Why are you trying to delete these files? > > > > > > > > Maybe if you tell us exactly what you are trying to do, and why you are > > > > trying to do it, someone will be able to help. > > > > > > > > "Aaron Wheeler" wrote: > > > > > > > > > I used retrospect backup software to make a copy of my old computer so that I > > > > > could access the files. I am done with the files and am trying to delete > > > > > them. I can delete them all except for the "system volume information" > > > > > folder. Any ideas how to do this? |
| System Information - "Can't Collect Information" | Vista General | |||
| "Windows is unable to find a system volume that meets its criteriafor installing" | Vista installation & setup | |||
| "Windows is unable to find a system volume..." | Vista installation & setup | |||
| Error: "Cannot convert "System.Object[]" to "System.Int32"." | PowerShell | |||
| Accessing "System Information" | PowerShell | |||
