| | Broadcast SSID required to connect to wireless network - why ? Why is it that my recently upgraded (to Vista Ultimate) laptop won't connect to my wireless network unless I go into my wireless router's administration screens and turn "broadcast SSID" back on (it previously was off when I was running Windows XP Pro SP2)? I have been running with 128-bit WEP security and broadcast SSID off for nearly two years. When I went to re-joining (a separate sore point in and of itself since this should have been preserved as part of the upgrade process, in my opinion) my wireless network by typing in the 36-digit hex key, Vista would not recognize my network. Only when I turned broadcast SSID back on at the router, did it finally join up. However, if I turn broadcast SSID back off and reboot the PC, it cannot find the wireless network. Windows XP Pro SP2 never had this type of problem. As far as I can tell, Vista has taken a step backwards when it comes to wireless connectivity. |
| | Re: Broadcast SSID required to connect to wireless network - why ? >> Why is it that my recently upgraded (to Vista Ultimate) laptop won't >> connect to my wireless network unless I go into my wireless router's administration screens and turn "broadcast SSID" back on (it previously was off when I was running Windows XP Pro SP2)? I have been running with 128-bit WEP security and broadcast SSID off for nearly two years. When I went to re-joining (a separate sore point in and of itself since this should have been preserved as part of the upgrade process, in my opinion) my wireless network by typing in the 36-digit hex key, Vista would not recognize my network. Only when I turned broadcast SSID back on at the router, did it finally join up. However, if I turn broadcast SSID back off and reboot the PC, it cannot find the wireless network. Windows XP Pro SP2 never had this type of problem. As far as I can tell, Vista has taken a step backwards when it comes to wireless connectivity. Fred: Hiding the SSID is not considered a strong security measure in WiFi security. |
| | Re: Broadcast SSID required to connect to wireless network - why ? first, all forms of wep have been cracked for a long time now. all youre doing by using it is slowing down your connection. use wpa instead... and i can confirm that while NOT broadcasting the ssid, i CAN connect just fine. although a difference in vista and xp is that in xp the OS simply saw nothing.... vista sees "unnamed network" "Fred Morrison" <fpmorrison@nospamverizon.net> wrote in message news:6C671D68-A993-45FA-809D-208384B2EDB5@microsoft.com... > Why is it that my recently upgraded (to Vista Ultimate) laptop won't > connect to my wireless network unless I go into my wireless router's > administration screens and turn "broadcast SSID" back on (it previously > was off when I was running Windows XP Pro SP2)? I have been running with > 128-bit WEP security and broadcast SSID off for nearly two years. When I > went to re-joining (a separate sore point in and of itself since this > should have been preserved as part of the upgrade process, in my opinion) > my wireless network by typing in the 36-digit hex key, Vista would not > recognize my network. Only when I turned broadcast SSID back on at the > router, did it finally join up. However, if I turn broadcast SSID back > off and reboot the PC, it cannot find the wireless network. Windows XP > Pro SP2 never had this type of problem. As far as I can tell, Vista has > taken a step backwards when it comes to wireless connectivity. > > |
| | Re: Broadcast SSID required to connect to wireless network - why ? I have an older LinkSys WRT54G router. It doesn't show WPA as an available option in any of it's administration screens; therefore, I continue to use 128-bit WEP. Bottom line: I need to find out how to make Vista connect to a wireless network that does not broadcast its SSID. It worked for Windows XP Pro SP2, so I don't understand why Windows Vista Ultimate won't connect unless I broadcast my SSID to the surrounding neighborhood. "Troy McClure" <g@s.com> wrote in message news:6468DB01-321D-4BA3-9711-376459B3FDBE@microsoft.com... > first, all forms of wep have been cracked for a long time now. all youre doing by using it is > slowing down your connection. use wpa instead... > and i can confirm that while NOT broadcasting the ssid, i CAN connect just fine. although a > difference in vista and xp is that in xp the OS simply saw nothing.... vista sees "unnamed > network" > > > > > "Fred Morrison" <fpmorrison@nospamverizon.net> wrote in message > news:6C671D68-A993-45FA-809D-208384B2EDB5@microsoft.com... >> Why is it that my recently upgraded (to Vista Ultimate) laptop won't connect to my wireless >> network unless I go into my wireless router's administration screens and turn "broadcast SSID" >> back on (it previously was off when I was running Windows XP Pro SP2)? I have been running with >> 128-bit WEP security and broadcast SSID off for nearly two years. When I went to re-joining (a >> separate sore point in and of itself since this should have been preserved as part of the upgrade >> process, in my opinion) my wireless network by typing in the 36-digit hex key, Vista would not >> recognize my network. Only when I turned broadcast SSID back on at the router, did it finally >> join up. However, if I turn broadcast SSID back off and reboot the PC, it cannot find the >> wireless network. Windows XP Pro SP2 never had this type of problem. As far as I can tell, >> Vista has taken a step backwards when it comes to wireless connectivity. >> >> > |
| | Re: Broadcast SSID required to connect to wireless network - why ? The folks at LinkSys had me upgrade the firmware on my WRT54G v1.1 router to the latest edition. 4.21.1, and now it shows WPA as an available option. I switched from 128-bit WEP to WPA-Personal/TKIP, entered my secrect passcode, and saved those settings on the router. Just for grins, I powered off and powered back on the router. It took a bit of hunt-and-click, with many missteps down blind alleys, to get reconnected from Windows Vista Ultimate, but I finally stumbled onto a "reconnect even if SSID is not being broadcast" feature, but I don't know how I got there, so I doubt I could help anyone else. All I can say is, hunt-and-click on anything "network" related until you find it ;-) "Troy McClure" <g@s.com> wrote in message news:6468DB01-321D-4BA3-9711-376459B3FDBE@microsoft.com... > first, all forms of wep have been cracked for a long time now. all youre doing by using it is > slowing down your connection. use wpa instead... > and i can confirm that while NOT broadcasting the ssid, i CAN connect just fine. although a > difference in vista and xp is that in xp the OS simply saw nothing.... vista sees "unnamed > network" > > > > > "Fred Morrison" <fpmorrison@nospamverizon.net> wrote in message > news:6C671D68-A993-45FA-809D-208384B2EDB5@microsoft.com... >> Why is it that my recently upgraded (to Vista Ultimate) laptop won't connect to my wireless >> network unless I go into my wireless router's administration screens and turn "broadcast SSID" >> back on (it previously was off when I was running Windows XP Pro SP2)? I have been running with >> 128-bit WEP security and broadcast SSID off for nearly two years. When I went to re-joining (a >> separate sore point in and of itself since this should have been preserved as part of the upgrade >> process, in my opinion) my wireless network by typing in the 36-digit hex key, Vista would not >> recognize my network. Only when I turned broadcast SSID back on at the router, did it finally >> join up. However, if I turn broadcast SSID back off and reboot the PC, it cannot find the >> wireless network. Windows XP Pro SP2 never had this type of problem. As far as I can tell, >> Vista has taken a step backwards when it comes to wireless connectivity. >> >> > |
| | #6 (permalink) |
| | #7 (permalink) |
| | Re: Broadcast SSID required to connect to wireless network - why ? Some older computers don't support WPA, so setting the router to WPA won't work for everyone. "Fred Morrison" <fpmorrison@nospamverizon.net> wrote in message news:68DFB1E6-13BD-4BFC-B897-08B7BA9D5078@microsoft.com... > The folks at LinkSys had me upgrade the firmware on my WRT54G v1.1 router > to the latest edition. 4.21.1, and now it shows WPA as an available > option. I switched from 128-bit WEP to WPA-Personal/TKIP, entered my > secrect passcode, and saved those settings on the router. Just for grins, > I powered off and powered back on the router. |
| | #8 (permalink) |
| | Re: Broadcast SSID required to connect to wireless network - why ? Hi Fred, This is why I always do a clean install. I had this problem with Windows Vista Ultimate RC2. I fixed this problem, by installing the Drivers for the Adapter Card, as I was installing Ultimate RC2, the last time. You may not be in the position to do a clean install, but it is what fixes the problem. What I did, since I dual-boot between Windows XP Home Edition Service Pack 2 on NTFS File System and Windows Vista Ultimate RC2, I had downloaded the drivers for the Network Adapter Card and unpacked them, into a sub-folder of Unzipped. Next I rebooted the computer with the DVD in the Drive and booted from the DVD. I did a Custom reinstall and when it asked for any drivers needed, I pointed the process towards the folder to look for the drivers. Then I continued reinstalling Ultimate RC2 and it worked without requiring SSID to be continuously broadcasted. The first time, I installed Ultimate RC2, I installed first, then supplied the drivers. Found the same problem you currently see. -- thecreator "Fred Morrison" <fpmorrison@nospamverizon.net> wrote in message news:6C671D68-A993-45FA-809D-208384B2EDB5@microsoft.com... > Why is it that my recently upgraded (to Vista Ultimate) laptop won't > connect to my wireless network unless I go into my wireless router's > administration screens and turn "broadcast SSID" back on (it previously > was off when I was running Windows XP Pro SP2)? I have been running with > 128-bit WEP security and broadcast SSID off for nearly two years. When I > went to re-joining (a separate sore point in and of itself since this > should have been preserved as part of the upgrade process, in my opinion) > my wireless network by typing in the 36-digit hex key, Vista would not > recognize my network. Only when I turned broadcast SSID back on at the > router, did it finally join up. However, if I turn broadcast SSID back > off and reboot the PC, it cannot find the wireless network. Windows XP > Pro SP2 never had this type of problem. As far as I can tell, Vista has > taken a step backwards when it comes to wireless connectivity. > > |
| | #9 (permalink) |
| | Re: Broadcast SSID required to connect to wireless network - why ? On Feb 5, 6:15 pm, "CZ" <C...@no99spam.com> wrote: > >> Why is it that my recently upgraded (to Vista Ultimate) laptop won't > >> connect to my wireless network > > unless I go into my wireless router's administration screens and turn > "broadcast SSID" back on (it > previously was off when I was running Windows XP Pro SP2)? I have been > running with 128-bit WEP > security and broadcast SSID off for nearly two years. When I went to > re-joining (a separate sore > point in and of itself since this should have been preserved as part of the > upgrade process, in my > opinion) my wireless network by typing in the 36-digit hex key, Vista would > not recognize my > network. Only when I turned broadcast SSID back on at the router, did it > finally join up. However, > if I turn broadcast SSID back off and reboot the PC, it cannot find the > wireless network. Windows > XP Pro SP2 never had this type of problem. As far as I can tell, Vista has > taken a step backwards > when it comes to wireless connectivity. > > Fred: > > Hiding the SSID is not considered a strong security measure in WiFi > security. This is not a very satisfactory answer. You can set your home router to broadcast, but networks that you need to connect to but have no control over (e.g. work) do not broadcast the SSID. I have the same exact problem with Vista, whereas it worked fine with XP. |
| | #10 (permalink) |
| | Re: Broadcast SSID required to connect to wireless network - why ? I had no problem with this on Windows Home Ultimate. You just tell it the SSID, since it can't see it. I also have an HP printer I was able to do this with. Now, I did a clean install, and setup the wireless network using the wireless network wizard. If you upgraded, you may have to manually find a way to invoke this wizzard. -- Larry Maturo <LoveToScraps@gmail.com> wrote in message news:1172777390.489753.160790@p10g2000cwp.googlegroups.com... > On Feb 5, 6:15 pm, "CZ" <C...@no99spam.com> wrote: >> >> Why is it that my recently upgraded (to Vista Ultimate) laptop won't >> >> connect to my wireless network >> >> unless I go into my wireless router's administration screens and turn >> "broadcast SSID" back on (it >> previously was off when I was running Windows XP Pro SP2)? I have been >> running with 128-bit WEP >> security and broadcast SSID off for nearly two years. When I went to >> re-joining (a separate sore >> point in and of itself since this should have been preserved as part of >> the >> upgrade process, in my >> opinion) my wireless network by typing in the 36-digit hex key, Vista >> would >> not recognize my >> network. Only when I turned broadcast SSID back on at the router, did it >> finally join up. However, >> if I turn broadcast SSID back off and reboot the PC, it cannot find the >> wireless network. Windows >> XP Pro SP2 never had this type of problem. As far as I can tell, Vista >> has >> taken a step backwards >> when it comes to wireless connectivity. >> >> Fred: >> >> Hiding the SSID is not considered a strong security measure in WiFi >> security. > > This is not a very satisfactory answer. > You can set your home router to broadcast, but networks that you need > to connect to but have no control over (e.g. work) do not broadcast > the SSID. > I have the same exact problem with Vista, whereas it worked fine with > XP. > |
| Cannot connect to non-broadcast network | Network & Sharing | |||
| SSID Broadcast Problem | Vista networking & sharing | |||
| SSID broadcast (or not) | Vista installation & setup | |||
| Vista Home Premium will not connect to Wireless non-broadcast SSID | Vista networking & sharing | |||
| Wireless doesn't connect if SSID is hidden | Vista General | |||
