Vista Tutorial - Can't power down monitor
Old 02-06-2007   #1 (permalink)
Brett
Guest
I have the power option set to turn off the monitor in 1 hour. However, it
never does. I set it down to 1 minute and still nothing. Is there a way to
find out why it isn't working?
Thanks,
Brett
Old 02-06-2007   #2 (permalink)
aarbie
Guest
RE: Can't power down monitor
I have exactly the same problem.
Can you give details fo the chipset/CPU you current have. I suspect it is a
power management issue, but cannot be sure.
> Thanks,
> Brett
Old 02-06-2007   #3 (permalink)
Brett
Guest
Re: Can't power down monitor
It use to work. I believe the problem is a program I installed named
Synergy. It runs on two machines and neither will sleep. Will try to get
with the author and see if it is a known issue.
"aarbie" <aarbie@discussions.microsoft.com> wrote in message
news:3BA6BA06-D216-41DE-A014-DE4D8FFE37F4@microsoft.com...
> a
>> it
>> to
>> Thanks,
>> Brett
Old 03-12-2007   #4 (permalink)
oldtiredtech
Guest
I have the same problem. When I use the photo slide show as my screen saver
the monitor never powers off. If I use the Windows logo as my screen saver
the monitor powers of at the spcified time. Also it seems to work randomly.
Some times it turns off the monitor and others it doesn't. I have an ATI
X1650 graphics card. I saw some other posts from RC1 where the monitor was
not turning off with ATI cards. I contacted Microsoft support on this but
they were not helpful. They just kept trying the same thing over and over
with a different tech.
> Thanks,
> Brett
How do i prevent monitor power off... General Discussion
Monitor doesn't power off General Discussion
Monitor doesn't power off Vista General
Vista and Monitor Power Saving Vista hardware & devices
Monitor will not go into Power Save - 5472 Vista General
