Vista Tutorial - Set Single Click for Mouse - How
Old 11-24-2007   #11 (permalink)
Bob C
Guest
Re: Set Single Click for Mouse - How
Click the Orb and type "Folder........." and select [Folder Options] On the
General tab, select the appropriate "Click items as follows" radio button.
Aloha,
BobC
"bobman111" <bobman111.30jcx4@xxxxxx-mx.forums.net> wrote in message
news:bobman111.30jcx4@xxxxxx-mx.forums.net...
Quote:
> hey is it possible to change from single back to double click i have
> heard you cant
> thanks
> bobman111
Old 11-24-2007   #12 (permalink)
Newbie
Vista home premium 32 bit
thanks guys
Old 12-25-2007   #13 (permalink)
Newbie
ok so this is a little of task but is it possible to start a program right when its folder is opened
Old 12-25-2007   #14 (permalink)
Administrator
Vista x64 Ultimate SP2, Windows 7 (7600) x64
Quote  Quote: Originally Posted by bobman111 View Post
Hi Bobman,
Sorry, there is no way that I'm aware of. You will have to click on the exe file of the program or a shortcut for the program to start it.
Old 03-09-2008   #15 (permalink)
Newbie
is it possible to disable the "if you started this action click continue" alert
thx
Old 03-09-2008   #16 (permalink)
Hank
Guest
A very difficult (for the experts here) Restore Point
problem on my computer was just solved by activating the
hidden Administrator and doing SFC /scannow. Credit to
the Barefoot Kid.
Single click generates 2 mouse clicks General Discussion
My mouse double clicks frequently when I single click it Vista hardware & devices
Single click mouse Vista hardware & devices
mouse single click Vista hardware & devices
hot to change mouse to single click instead of double click to ope Vista hardware & devices
