| | Vista - ATI Display Driver Problems |
| 02-06-2007 | #1 |
| | ATI Display Driver Problems Hi, just bought the Vista Business Ed. and after installing the OS (3 times already) everything its super slow. Even do the colors are great. it happens to be like if its freezed like when you try to open the start menu or anything it does it every 7 to 10 seconds as if it refreshes in that time, i went to ATI.COM and search for the vista 32 bit drivers for (Radeon X300 PCI Express 128mb) and its the same... Any suggestions. |
| My System Specs |
| 02-06-2007 | #2 |
| | Re: ATI Display Driver Problems I have an Ati x600 and didn't bother getting the software after my Business install. I suspect something else is going on. How's Device Manager? "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message news:C0CC6CE9-25A7-4F1F-A458-D113A86FE88A@microsoft.com... > Hi, just bought the Vista Business Ed. and after installing the OS (3 > times > already) everything its super slow. Even do the colors are great. it > happens > to be like if its freezed like when you try to open the start menu or > anything it does it every 7 to 10 seconds as if it refreshes in that time, > i > went to ATI.COM and search for the vista 32 bit drivers for (Radeon X300 > PCI > Express 128mb) and its the same... Any suggestions. |
| My System Specs |
| 02-07-2007 | #3 |
| | Re: ATI Display Driver Problems Well i went to display manager and uninstall the ATI display drivers and when the PC restarted everything run like normal except that the video drivers where in 800x600 but Vista automaticlly installed the drivers again and when restarted the PC again comes with the same problem any other suggestions, Thanks "Bill Condie" wrote: > I have an Ati x600 and didn't bother getting the software after my Business > install. > > I suspect something else is going on. How's Device Manager? > > "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message > news:C0CC6CE9-25A7-4F1F-A458-D113A86FE88A@microsoft.com... > > Hi, just bought the Vista Business Ed. and after installing the OS (3 > > times > > already) everything its super slow. Even do the colors are great. it > > happens > > to be like if its freezed like when you try to open the start menu or > > anything it does it every 7 to 10 seconds as if it refreshes in that time, > > i > > went to ATI.COM and search for the vista 32 bit drivers for (Radeon X300 > > PCI > > Express 128mb) and its the same... Any suggestions. > |
| My System Specs |
| 02-07-2007 | #4 |
| | Re: ATI Display Driver Problems I had a similar4 problem a while ago with windows XP and what I needed to do was completely uninstall ATI including cleaning the registry of any remnants of ATI, searching for folders that ATI had installed and delete them then BEFORE restarting go to the Device manager and uninstall the card from the display adapter. Then reboot and go through the process of installing drivers etc. By the way I have an ATI card as well (1900 GT) and did not have any problems such as you experiencing.. Hope this helps. "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message news:296E4DFF-865D-4982-873F-54EECD59BECD@microsoft.com... > Well i went to display manager and uninstall the ATI display drivers and > when > the PC restarted everything run like normal except that the video drivers > where in 800x600 but Vista automatically installed the drivers again and > when > restarted the PC again comes with the same problem any other suggestions, > Thanks > > "Bill Condie" wrote: > >> I have an Ati x600 and didn't bother getting the software after my >> Business >> install. >> >> I suspect something else is going on. How's Device Manager? >> >> "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message >> news:C0CC6CE9-25A7-4F1F-A458-D113A86FE88A@microsoft.com... >> > Hi, just bought the Vista Business Ed. and after installing the OS (3 >> > times >> > already) everything its super slow. Even do the colors are great. it >> > happens >> > to be like if its freezed like when you try to open the start menu or >> > anything it does it every 7 to 10 seconds as if it refreshes in that >> > time, >> > i >> > went to ATI.COM and search for the vista 32 bit drivers for (Radeon >> > X300 >> > PCI >> > Express 128mb) and its the same... Any suggestions. >> |
| My System Specs |
| 02-07-2007 | #5 |
| | Re: ATI Display Driver Problems Well, i thought that would fix my problem but after rebooting, Vista automaticly assingns the Driver again from their database, install them for me (they recognized the Video Card instantly) and the "Updated" Drivers from ATI where installed but, when its finally rebooted the PC comes with the same problem (im dissappointed) before i bought the Vista i read that everything was compatible but it turns out to be a headache, whatever the suggestions are ill try them if you have them, thanks |
| My System Specs |
| 02-07-2007 | #6 |
| | Re: ATI Display Driver Problems Still with the same problem, Vista install the drivers from their database and the "Updated" drivers from ATI dont work, im dissappointed, i checked everything to see if it was compatible before buying it and its been a problem, if you guys have any other suggestions im open to try them all, thanks "SSI" wrote: > I had a similar4 problem a while ago with windows XP and what I needed to do > was completely uninstall ATI including cleaning the registry of any remnants > of ATI, searching for folders that ATI had installed and delete them then > BEFORE > restarting go to the Device manager and uninstall the > card from the display adapter. Then reboot and go through the process of > installing drivers etc. > By the way I have an ATI card as well (1900 GT) and did not have any > problems such as you experiencing.. > Hope this helps. > > > > "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message > news:296E4DFF-865D-4982-873F-54EECD59BECD@microsoft.com... > > Well i went to display manager and uninstall the ATI display drivers and > > when > > the PC restarted everything run like normal except that the video drivers > > where in 800x600 but Vista automatically installed the drivers again and > > when > > restarted the PC again comes with the same problem any other suggestions, > > Thanks > > > > "Bill Condie" wrote: > > > >> I have an Ati x600 and didn't bother getting the software after my > >> Business > >> install. > >> > >> I suspect something else is going on. How's Device Manager? > >> > >> "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message > >> news:C0CC6CE9-25A7-4F1F-A458-D113A86FE88A@microsoft.com... > >> > Hi, just bought the Vista Business Ed. and after installing the OS (3 > >> > times > >> > already) everything its super slow. Even do the colors are great. it > >> > happens > >> > to be like if its freezed like when you try to open the start menu or > >> > anything it does it every 7 to 10 seconds as if it refreshes in that > >> > time, > >> > i > >> > went to ATI.COM and search for the vista 32 bit drivers for (Radeon > >> > X300 > >> > PCI > >> > Express 128mb) and its the same... Any suggestions. > >> > > |
| My System Specs |
| 02-07-2007 | #7 |
| | Re: ATI Display Driver Problems If you would like help then you need to tell us what your system specs are,what version of Vista you are running (RC2? RTM? Ultimate? Radeon X1300? Mobility X300? how many video cards you have in your system. There is no way to help you unless you tell us enough information for us to help you. Ben "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message news 938C836-D292-4DEC-84C2-2DAD46A37201@microsoft.com...> Well, i thought that would fix my problem but after rebooting, Vista > automaticly assingns the Driver again from their database, install them > for > me (they recognized the Video Card instantly) and the "Updated" Drivers > from > ATI where installed but, when its finally rebooted the PC comes with the > same > problem (im dissappointed) before i bought the Vista i read that > everything > was compatible but it turns out to be a headache, whatever the suggestions > are ill try them if you have them, thanks |
| My System Specs |
| 02-08-2007 | #8 |
| | Re: ATI Display Driver Problems Thanks Ben, i have a clean PC, Athlon 64 x2 4200, 2 Gb Ram, Asus A8S-X Motherboard, 250 Serial ATA HDD and Vista Business ED 32bit. I took away any other cards before to prevent issues with them. hope this can help to solve the problem, Thanks Again "Ben Enfield" wrote: > If you would like help then you need to tell us what your system specs > are,what version of Vista you are running (RC2? RTM? Ultimate? Radeon X1300? > Mobility X300? how many video cards you have in your system. > > There is no way to help you unless you tell us enough information for us to > help you. > > Ben > > "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message > news 938C836-D292-4DEC-84C2-2DAD46A37201@microsoft.com...> > Well, i thought that would fix my problem but after rebooting, Vista > > automaticly assingns the Driver again from their database, install them > > for > > me (they recognized the Video Card instantly) and the "Updated" Drivers > > from > > ATI where installed but, when its finally rebooted the PC comes with the > > same > > problem (im dissappointed) before i bought the Vista i read that > > everything > > was compatible but it turns out to be a headache, whatever the suggestions > > are ill try them if you have them, thanks > |
| My System Specs |
| 02-08-2007 | #9 |
| | Re: ATI Display Driver Problems on the ATI web site under the drivers section there is Release Notes where you should find Installing drivers, where you will find the instructions on how to MANUALLY remove ATI drivers in prep for installing new ones. the drivers you updated still exist on the hard drive and that is what vista keeps installing, you need to remove them as well. mikeyhsd@sport.rr.com "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message news DE96CAA-75AC-4833-83AB-BE8C9AF3B690@microsoft.com...Thanks Ben, i have a clean PC, Athlon 64 x2 4200, 2 Gb Ram, Asus A8S-X Motherboard, 250 Serial ATA HDD and Vista Business ED 32bit. I took away any other cards before to prevent issues with them. hope this can help to solve the problem, Thanks Again "Ben Enfield" wrote: > If you would like help then you need to tell us what your system specs > are,what version of Vista you are running (RC2? RTM? Ultimate? Radeon X1300? > Mobility X300? how many video cards you have in your system. > > There is no way to help you unless you tell us enough information for us to > help you. > > Ben > > "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message > news 938C836-D292-4DEC-84C2-2DAD46A37201@microsoft.com...> > Well, i thought that would fix my problem but after rebooting, Vista > > automaticly assingns the Driver again from their database, install them > > for > > me (they recognized the Video Card instantly) and the "Updated" Drivers > > from > > ATI where installed but, when its finally rebooted the PC comes with the > > same > > problem (im dissappointed) before i bought the Vista i read that > > everything > > was compatible but it turns out to be a headache, whatever the suggestions > > are ill try them if you have them, thanks > |
| My System Specs |
| 02-08-2007 | #10 |
| | Re: ATI Display Driver Problems Have you tried driver cleaner (http://www.drivercleaner.net/) to get rid of the old drivers before installing the new one's? I am not sure if it will work under Vista but it was wonderful in XP. Make sure you follow the directions. Also, an idea ... if windows goes out to the windows update site to find the drivers have you tried to shut off the internet before restarting? Or in Device manager try and update the drivers for the video card and point it to the new directory where you unzipped the ATI drivers instead of letting windows find and install the drivers automatically. "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message news:5C8F14AC-3A86-4BF6-967B-BB82FD1D7C03@microsoft.com... > Still with the same problem, Vista install the drivers from their database > and the "Updated" drivers from ATI dont work, im dissappointed, i checked > everything to see if it was compatible before buying it and its been a > problem, if you guys have any other suggestions im open to try them all, > thanks > > "SSI" wrote: > >> I had a similar4 problem a while ago with windows XP and what I needed to >> do >> was completely uninstall ATI including cleaning the registry of any >> remnants >> of ATI, searching for folders that ATI had installed and delete them then >> BEFORE >> restarting go to the Device manager and uninstall the >> card from the display adapter. Then reboot and go through the process of >> installing drivers etc. >> By the way I have an ATI card as well (1900 GT) and did not have any >> problems such as you experiencing.. >> Hope this helps. >> >> >> >> "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message >> news:296E4DFF-865D-4982-873F-54EECD59BECD@microsoft.com... >> > Well i went to display manager and uninstall the ATI display drivers >> > and >> > when >> > the PC restarted everything run like normal except that the video >> > drivers >> > where in 800x600 but Vista automatically installed the drivers again >> > and >> > when >> > restarted the PC again comes with the same problem any other >> > suggestions, >> > Thanks >> > >> > "Bill Condie" wrote: >> > >> >> I have an Ati x600 and didn't bother getting the software after my >> >> Business >> >> install. >> >> >> >> I suspect something else is going on. How's Device Manager? >> >> >> >> "RUMAR" <RUMAR@discussions.microsoft.com> wrote in message >> >> news:C0CC6CE9-25A7-4F1F-A458-D113A86FE88A@microsoft.com... >> >> > Hi, just bought the Vista Business Ed. and after installing the OS >> >> > (3 >> >> > times >> >> > already) everything its super slow. Even do the colors are great. it >> >> > happens >> >> > to be like if its freezed like when you try to open the start menu >> >> > or >> >> > anything it does it every 7 to 10 seconds as if it refreshes in that >> >> > time, >> >> > i >> >> > went to ATI.COM and search for the vista 32 bit drivers for (Radeon >> >> > X300 >> >> > PCI >> >> > Express 128mb) and its the same... Any suggestions. >> >> >> >> |
| My System Specs |
| Similar Threads for: ATI Display Driver Problems | ||||
| Display Driver Stopped Responding and Has Recovered - nvlddmkm nVidia Driver | Drivers | |||
| Getting new Vista Display Driver | Drivers | |||
| Display Driver nviddmkm | Drivers | |||
| Need help with display driver error | Vista General | |||
| Display driver problems | Vista hardware & devices | |||
