Vista - Help with icons.
Old 02-07-2007   #1 (permalink)
Bazcraig
Help with icons.
Hey, i just installed Vista Ultimate. So far loving it but there are a couple
of things that are bothering me that i haven't been able to find answers to:
1. I had an icon set installed on XP and after i did my all-in-place upgrade
all the icons are just the default White icon. (ill try to stop saying icon
so much.) Is there any way to reset all the vista icons back to default?
2. The little open/save display crashes in every program, whether its saving
in Firefox or loading in Word it always causes explorer to restart.
Any help with either of these issues is greatly appreciated.
Cheers!
Barry
Old 02-09-2007   #2 (permalink)
Bazcraig
RE: Help with icons.
*Bump* Nothing?
> Cheers!
> Barry
Old 02-09-2007   #3 (permalink)
Donald McDaniel
Re: Help with icons.
"Bazcraig" <Bazcraig@discussions.microsoft.com> wrote in message
newsDF47218-1EED-494E-9EB0-84A51F51C36E@microsoft.com...
> *Bump* Nothing?
>> couple
>> to:
>> upgrade
>> icon
>> saving
>> Cheers!
>> Barry
I guess that's the price one pays for doing an upgrade rather than a clean
installation.
Anyway, I use Icon Packager by Stardock. It works fairly well.
Donald L McDaniel
Please reply to the original newsgroup and thread.
Old 03-11-2007   #4 (permalink)
taavetti@gmail.com
> Cheers!
> Barry
I have exactly the same problem, unfortunately. I've also scoured the
internet for ways to fix it, and all I've come across are people
unhelpfully saying, "it's your own fault for using Vista."
In Firefox, I've just set a default download folder and moved my
downloads afterwards. And with files that will always bring up the
save dialog, like pictures, I just drag the picture from Firefox into
a Windows Explorer folder.
Missing icons in start menu (icons on the right hand side) General Discussion
What action causes dir icons to change to shortcut icons? Vista General
How do I restore Icons to display as icons rather than thumbnails? Vista General
Show only icons in menubar instead of icons+text Live Mail
desktop icons covered by unknown program icons Vista General
