Vista - Explorer window size does not remember it's location after reboot
Old 02-08-2007   #1 (permalink)
malaac
Any ideas on how to fix this issue? Everytime I reboot the windows explorer
forgets it's default size. It's a real pain in the rear to keep resizing
it. Secondly is it possible to make windows explorer open to C drive? I
hate opening my documents folder as root folder.. I always changed it in XP.
Old 02-08-2007   #2 (permalink)
R. McCarty
Re: Explorer window size does not remember it's location after reboot
Use Folder Options in Control Panel (Classic). Under the View options
make sure the "Remember each folder's view settings" is checked.
*Sometimes it helps after customizing a window to close the window
while holding down the Shift Key.
Modify the Explorer shortcut to include /n, /e, C:
"malaac" <malaac@tampabay.rr.com> wrote in message
news:6F2C3140-5252-4D68-8C2E-EB9B95117A9E@microsoft.com...
> explorer forgets it's default size. It's a real pain in the rear to keep
> resizing it. Secondly is it possible to make windows explorer open to C
> drive? I hate opening my documents folder as root folder.. I always
> changed it in XP.
Old 02-08-2007   #3 (permalink)
Chad Harris
Remembering settings in folder options will not have any particular effect
on explorer **window size in my experience, not will regedits to increase
these settings to 8000 folders in Vista or XP in my experience. It will
impact folder organization though whether view is list, tiles, etc.
What does help for me for both explorer and IE window size but is not
perfect at all times, is to manually resize the folder and the close down
holding the Ctrl key down. IE windows are often impacted by pop unders
behind the scenes.
CH
> changed it in XP.
Old 02-09-2007   #4 (permalink)
malaac
This is the most annoying bug in Vista. If you have to use the browse
button.. there goes your remembered windows explorer setting.. can't M$ fix
a simple stupid bug like this? Damn what they spending all their money on
in Vista? This bug was just about gone in XP and it's back in Vista even
worse.
"Chad Harris" <vistaneedsmuchowork.net> wrote in message
news:epyHch8SHHA.928@TK2MSFTNGP02.phx.gbl...
> behind the scenes.
> CH
>> changed it in XP.
Windows Explorer (Vista Ultimate) won't remember size Vista General
Window Explorer startup location Vista file management
Vista will not remember Explorer window sizes Vista General
Remember size of window Vista performance & maintenance
Windows explorer does not remember size and position in vista? Vista General
