| | need help disabling item from startup I keept getting a program compatibility assistant for Sonic Solutions DLA. I have disabled all items from startup except Windows Defender Intel Common User Interface (3 entries commands are system32\igfxtray.exe, hkcmd.exe and igfxpers.exe My mouse pad (laptop) My Wifi driver Google Desktop I haven't been able to find a resolution for this so for now I just want to disable it. I'd rather not uninstall the software because I know I'll just have to put it back on later. |
| | Re: need help disabling item from startup You need to uninstall it, it is not Vista compatible. -- ---- Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm How to ask a question http://support.microsoft.com/kb/555375 How to Post http://www.dts-l.org/goodpost.htm http://www.db-pc.com ---------------------------------------------------------------------------------------------------------------------- "Rob" <nospam@nospam.com> wrote in message news:OcEsUI7SHHA.1228@TK2MSFTNGP06.phx.gbl... >I keept getting a program compatibility assistant for Sonic Solutions DLA. >I have disabled all items from startup except > Windows Defender > Intel Common User Interface (3 entries commands are system32\igfxtray.exe, > hkcmd.exe and igfxpers.exe > My mouse pad (laptop) > My Wifi driver > Google Desktop > > I haven't been able to find a resolution for this so for now I just want > to disable it. I'd rather not uninstall the software because I know I'll > just have to put it back on later. > |
| | Re: need help disabling item from startup Seems stupid for them to have included it with a brand new pc :/ Okay thanks. "Dave B." <mail@nomail.net> wrote in message news:e9YbqK7SHHA.4076@TK2MSFTNGP05.phx.gbl... > You need to uninstall it, it is not Vista compatible. > > -- > ---- > Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm > How to ask a question http://support.microsoft.com/kb/555375 > How to Post http://www.dts-l.org/goodpost.htm > http://www.db-pc.com > ---------------------------------------------------------------------------------------------------------------------- > "Rob" <nospam@nospam.com> wrote in message > news:OcEsUI7SHHA.1228@TK2MSFTNGP06.phx.gbl... >>I keept getting a program compatibility assistant for Sonic Solutions DLA. >>I have disabled all items from startup except >> Windows Defender >> Intel Common User Interface (3 entries commands are >> system32\igfxtray.exe, hkcmd.exe and igfxpers.exe >> My mouse pad (laptop) >> My Wifi driver >> Google Desktop >> >> I haven't been able to find a resolution for this so for now I just want >> to disable it. I'd rather not uninstall the software because I know I'll >> just have to put it back on later. >> > > |
| | Re: need help disabling item from startup Hello, Check out the support forums at Roxio. This was caused by a particular Vista update (I don't remember which one right now) that came out recently. They (Roxio) are working on a fix. In the mean time, they recommend either uninstalling the offending Vista update or simply ignoring the error message. I have chosen to ignore the message (Roxio still works fine) and wait for their permanent fix. Tim "Rob" wrote: > Seems stupid for them to have included it with a brand new pc :/ > > Okay thanks. > > "Dave B." <mail@nomail.net> wrote in message > news:e9YbqK7SHHA.4076@TK2MSFTNGP05.phx.gbl... > > You need to uninstall it, it is not Vista compatible. > > > > -- > > ---- > > Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm > > How to ask a question http://support.microsoft.com/kb/555375 > > How to Post http://www.dts-l.org/goodpost.htm > > http://www.db-pc.com > > ---------------------------------------------------------------------------------------------------------------------- > > "Rob" <nospam@nospam.com> wrote in message > > news:OcEsUI7SHHA.1228@TK2MSFTNGP06.phx.gbl... > >>I keept getting a program compatibility assistant for Sonic Solutions DLA. > >>I have disabled all items from startup except > >> Windows Defender > >> Intel Common User Interface (3 entries commands are > >> system32\igfxtray.exe, hkcmd.exe and igfxpers.exe > >> My mouse pad (laptop) > >> My Wifi driver > >> Google Desktop > >> > >> I haven't been able to find a resolution for this so for now I just want > >> to disable it. I'd rather not uninstall the software because I know I'll > >> just have to put it back on later. > >> > > > > > > > |
| | Re: need help disabling item from startup I opted to uninstalled because the user is unexperienced and I know it's going to be a problem. Will reinstall when needed. Thanks. |
| | #6 (permalink) |
| | Re: need help disabling item from startup I have uninstalled the Maxtor software, but still get the Sonic Solutions DLA driver error message on Startup (probably because the driver was running at the time and couldn't be deleted. I can't find the driver in the task manager list. Do you know how I can delete the driver? Thanks. "Rob" wrote: > I opted to uninstalled because the user is unexperienced and I know it's > going to be a problem. Will reinstall when needed. Thanks. > > > |
| | #7 (permalink) |
| | RE: need help disabling item from startup try this: http://support.dell.com/support/topi...789&l=en&s=gen "Rob" wrote: > I keept getting a program compatibility assistant for Sonic Solutions DLA. I > have disabled all items from startup except > Windows Defender > Intel Common User Interface (3 entries commands are system32\igfxtray.exe, > hkcmd.exe and igfxpers.exe > My mouse pad (laptop) > My Wifi driver > Google Desktop > > I haven't been able to find a resolution for this so for now I just want to > disable it. I'd rather not uninstall the software because I know I'll just > have to put it back on later. > > > |
| | #8 (permalink) |
| | Re: need help disabling item from startup Hi Roxio ahve released a fix. File d2D3290.exe - ahve a poke about on their sitre, i am sure you will find it (eventually!) Ciao Lewej "Tim Feld" wrote: > Hello, > > Check out the support forums at Roxio. This was caused by a particular Vista > update (I don't remember which one right now) that came out recently. They > (Roxio) are working on a fix. In the mean time, they recommend either > uninstalling the offending Vista update or simply ignoring the error message. > I have chosen to ignore the message (Roxio still works fine) and wait for > their permanent fix. > > Tim > > > "Rob" wrote: > > > Seems stupid for them to have included it with a brand new pc :/ > > > > Okay thanks. > > > > "Dave B." <mail@nomail.net> wrote in message > > news:e9YbqK7SHHA.4076@TK2MSFTNGP05.phx.gbl... > > > You need to uninstall it, it is not Vista compatible. > > > > > > -- > > > ---- > > > Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm > > > How to ask a question http://support.microsoft.com/kb/555375 > > > How to Post http://www.dts-l.org/goodpost.htm > > > http://www.db-pc.com > > > ---------------------------------------------------------------------------------------------------------------------- > > > "Rob" <nospam@nospam.com> wrote in message > > > news:OcEsUI7SHHA.1228@TK2MSFTNGP06.phx.gbl... > > >>I keept getting a program compatibility assistant for Sonic Solutions DLA. > > >>I have disabled all items from startup except > > >> Windows Defender > > >> Intel Common User Interface (3 entries commands are > > >> system32\igfxtray.exe, hkcmd.exe and igfxpers.exe > > >> My mouse pad (laptop) > > >> My Wifi driver > > >> Google Desktop > > >> > > >> I haven't been able to find a resolution for this so for now I just want > > >> to disable it. I'd rather not uninstall the software because I know I'll > > >> just have to put it back on later. > > >> > > > > > > > > > > > > |
| Please help startup item!!!!!! | General Discussion | |||
| Enabling / disabling network connections on startup and/or shutdown | Vista General | |||
| Disabling Administrator Option at Startup | Vista General | |||
| disabling startup sound after boot | Vista General | |||
