No power icon
  1. #1
    DannyBoi Guest
    No power icon
    I have put Vista Ultimate on my laptop but I can't select to put the Power
    Icon in the taskbar. Can someone help?
    Many thanks,
    DannyBoi
  2. #2
    Navilyn Guest
    Re: No power icon
    'Power Icon in the taskbar', do you mean the power icon in the systray? If
    yes, in control panel, power, is the option set there?
    "DannyBoi" <someone@here.com> wrote in message
    news:uIrjKw7SHHA.5012@TK2MSFTNGP04.phx.gbl...
    > Hi,
    > Many thanks,
    > DannyBoi
  3. #3
    Sascha Benjamin Jazbec Guest
    Re: No power icon
    1. Make sure you have installed all necessary drivers and System software
    that came with your Laptop.
    Some Power Options will only be accessable after the software has
    enabled them.
    ( i did a vista install on a IBM T23 with exact the same issue, after
    installing IBMs "BatteryMaxiMiser" the Vista Power icon was showing up )
    2. Make sure you have the icon turned on to be visible :
    Properties of Taskbar and Startmenu ( rightclick taskbar) :
    there are tabs with more options - the third tab has Options for what is
    shown or hidden in systray.
    ( I have a german vista - there is no logical translation in my mind .. but
    its somewhere on the 3rd tab )
    SJ /germany
    "DannyBoi" <someone@here.com> schrieb im Newsbeitrag
    > Hi,
    > Many thanks,
    > DannyBoi
  4. #4
    Xeno326 Guest
    Re: No power icon
    I also am having an issue with the "Power System Icon" being displayed in the
    "System Tray" area. I use the power icon in a different manner than what
    laptops use it for. I use it for specific direct access to enable or disable
    the 1 minute auto-turn off option for my monitor display. When I turn my PC
    on and I want the display on I don't want it shutting off after one minute,
    but since the PC is in the same room I sleep I want to have a quick
    easy-access option to turn it off since I use my PC as an alarm clock as
    well. This option was available in Windows XP, why is it disabled
    "greyed-out" for every-time use in Windows Vista?
    > enabled them.
    > SJ /germany
    > > Hi,
    > > Many thanks,
    > > DannyBoi
No power icon problems?
Taskbar issues - missing power meter, network icon, and sound icon The Shadow Vista General 9 27 Apr 2009
RE: No power icon DannyBoi Vista General 2 23 Nov 2008
Power Icon Animation J. Howlett Vista General 1 02 May 2008
Power icon only for laptops/UPS LordLiverpool Vista General 4 08 Apr 2008
Power icon JPFS Vista performance & maintenance 1 18 Jun 2006
