Derek,
the "workaround" was my suggestion to set Help once to offline-mode and then
back to online-mode.
For that user in the german ng it helped indeed.
If that does not the trick on your system then I have no other ideas.
I am no MS employee, so I can only try-and-error on my own.
When it comes to myself : I use the german Ultimate edition x86 as a clean
installed vista and can not confirm these errors at all, but when you read
through all these newsgroups one can get the idea that vista behaves very
individual on each different pc.. some people get errors like hell , some
other have not a single one.
also the x64versions seems to make more trouble than the x86 versions.
this is really something weired. Maybe a MS guy can help out here ?
SJ /germany
"Derek" <Derek@discussions.microsoft.com> schrieb im Newsbeitrag
news:8286119F-0B3A-48F3-A371-667B169F8C10@microsoft.com...
> Is there some one here that can get the workaround to that issue. I don't
> speak german so looking for the workgroup post would be very difficult.
> "Sascha Benjamin Jazbec" wrote:> sounds like a bug then.
>> Somebody in the german newsgroup reported that issues and was succesful
>> with
>> that workaround.
>> for activation - you can phone the support hotline free, if activation
>> over
>> internet is not permitted.
>> As long as you reinstall on the very same machine you are under no
>> limitations to the count.
>> SJ /germany
>> news:F1627FB0-0A1C-4355-9137-97207C42180D@microsoft.com...
>> > It didn't work. I still get the red x's. All the icons where there when
>> > I
>> > first loaded Vista. I want to do a clean install, but Im afraid that I
>> > would
>> > lose all my activation information.
>> >> that happens if you have set the help center to use "get online help"
>> >> and you have deleted your temorary internet files in Internet Explorer
>> >> delete browsing history )
>> >> - just set help center once to offline help, then again to "online" -
>> >> and
>> >> it will reload the content from the web.
>> >> hope this helps
>> >> SJ /germany
>> >> news:5075EBAA-2F40-4361-BD80-A2681CA2CE88@microsoft.com...
>> >> >I have these little red x's all over the Help and Support dialog box.
>> >> >Is
>> >> > there a way to fix this prolem. Its very annoying when you paid $400
>> >> > for
>> >> > Vista Ultimate only to get broken features. Here is how the boxes
>> >> > look:
>> >> > http://i74.photobucket.com/albums/i2...s/Untitled.jpg
>> >> > There should be icons or pictures were those little red x's are.
>> >> > Please,
>> >> > someone help.
