| | #11 (permalink) |
| | RE: networking problem Vista & XP Posted this elsewhere - but this solved ALL my problems and without needing the NETBIOS fix ... You need to install the LLTD Responder update for XP, downloadable from MS at ... http://go.microsoft.com/fwlink/?LinkId=70582 It is mentioned in the Vista networking help, though it's slightly obscure and given that EVERYONE is having this problem it should be more prominent. If you go to your Network and Sharing Center in Vista there is an option top-right to "View Full Map". Click that and you will see that some devices are missing from your diagram. There is a question on the left "Why are some devices missing" which points to that link. Install the download on XP. Restart the machine (though mine didn't prompt for it) and it all works just fine. "ativar" wrote: > Thanks a bunch for this Eric! It helped me at least get my VISTA computer to > see and talk with my XP ones. Now if I can only figure out how to get the > other side to work properly!! > > Red Merchant > > > "Eric Haines" wrote: > > > I found this elsewhere on the forums, but it's worth posting everywhere - it > > worked great for me. I've also modified it a bit to match my Home Premium > > version of Vista. It is from Bruce Sanderson MVP Printing > > (http://members.shaw.ca/bsanders): > > > > You may need to enable NetBIOS over TCP/IP for TCP/IP V4 in the Network > > Connection's properties: > > > > 1. Click on Start in the lower left corner, then select Network > > 2. click Network and Sharing Center > > 3. Look at Sharing and Discovery, below on the right > > 4. make sure that Network Discovery is On (note - in a Windows Domain, this > > may need to be enabled by an administrator using a GPO) > > 5. make sure that File Sharing is On > > 6. make sure that Public folder sharing is Off > > 7. if you have a printer locally installed that you want other computers to > > use, make sure Printer Sharing is On > > 8. click Manage network connections (left pane) > > 9. right click the Local Area Connection (or whatever network connection is > > in use - e.g. a wireless connection) > > 10. select Properties > > 11. click Continue in the User Account Control prompt (or supply > > Administrative username and password) > > 12. select Internet Protocol Version 4 (TCP/IPv4) > > 13. click Properties > > 14. click Advanced... > > 14. select the WINS tab > > 15. select the Enable NetBIOS over TCP/IP radio button > > 16. click OK; click OK; click Close - this change will take affect > > immediately - no need to logoff or restart > > > > Also, as stated in other posts in this thread and others - make sure you > > don't have a third party firewall blocking the ports or programs needed. |
| | #12 (permalink) |
| | RE: networking problem Vista & XP it still hasn't helped me. It does allow me to "see" the XP machines in the "view full map", but other than seeing them in the map, nothing. I can map a drive to the XP machines share using IP addr, but not name. Even from the DOS prompt I can't see the XP share via name, only via IP. I've enabled NetBIOS even. I've also gone in and explicitly enabed all the correct ports. Nothing yet... "Mick Jennings" wrote: > Posted this elsewhere - but this solved ALL my problems and without needing > the NETBIOS fix ... > > You need to install the LLTD Responder update for XP, downloadable from MS > at ... > > http://go.microsoft.com/fwlink/?LinkId=70582 > > It is mentioned in the Vista networking help, though it's slightly obscure > and given that EVERYONE is having this problem it should be more prominent. > If you go to your Network and Sharing Center in Vista there is an option > top-right to "View Full Map". Click that and you will see that some devices > are missing from your diagram. There is a question on the left "Why are some > devices missing" which points to that link. Install the download on XP. > Restart the machine (though mine didn't prompt for it) and it all works just > fine. > > "ativar" wrote: > > > Thanks a bunch for this Eric! It helped me at least get my VISTA computer to > > see and talk with my XP ones. Now if I can only figure out how to get the > > other side to work properly!! > > > > Red Merchant > > > > > > "Eric Haines" wrote: > > > > > I found this elsewhere on the forums, but it's worth posting everywhere - it > > > worked great for me. I've also modified it a bit to match my Home Premium > > > version of Vista. It is from Bruce Sanderson MVP Printing > > > (http://members.shaw.ca/bsanders): > > > > > > You may need to enable NetBIOS over TCP/IP for TCP/IP V4 in the Network > > > Connection's properties: > > > > > > 1. Click on Start in the lower left corner, then select Network > > > 2. click Network and Sharing Center > > > 3. Look at Sharing and Discovery, below on the right > > > 4. make sure that Network Discovery is On (note - in a Windows Domain, this > > > may need to be enabled by an administrator using a GPO) > > > 5. make sure that File Sharing is On > > > 6. make sure that Public folder sharing is Off > > > 7. if you have a printer locally installed that you want other computers to > > > use, make sure Printer Sharing is On > > > 8. click Manage network connections (left pane) > > > 9. right click the Local Area Connection (or whatever network connection is > > > in use - e.g. a wireless connection) > > > 10. select Properties > > > 11. click Continue in the User Account Control prompt (or supply > > > Administrative username and password) > > > 12. select Internet Protocol Version 4 (TCP/IPv4) > > > 13. click Properties > > > 14. click Advanced... > > > 14. select the WINS tab > > > 15. select the Enable NetBIOS over TCP/IP radio button > > > 16. click OK; click OK; click Close - this change will take affect > > > immediately - no need to logoff or restart > > > > > > Also, as stated in other posts in this thread and others - make sure you > > > don't have a third party firewall blocking the ports or programs needed. |
| | #13 (permalink) |
| | RE: networking problem Vista & XP Like Mark, I have performed the steps listed in this thread. And I, too, have a great topology map. Except for a brief period when we first booted the Vista computer, I have had no luck listing the netword shares, which are all XP Pro machines. Has anyone else found out any more information that could help? Thanks! |
| | #14 (permalink) |
| | RE: networking problem Vista & XP Search for a slightly more recent post on this by me(Mark). It would be maybe a week newer than the last one I posted on here. It's been awhile, but I did solve the problem. I don't remember all the details, but it was the firewall. My machine came with Norton pre-installed. I had set all the settings to "off" with no luck. I had also checked the Windows firewall settings and they were all set to off. I even went so far as to go to the specific details to make sure it was very much off. I uninstalled Norton and it all sprang to life. Even with everything set to "off" something was still "on". I still have Windows firwall off and as time goes on I'll be re-integrating it back in. Norton security programs and Vista do not mix. Look back on my writeup on this just to make sure I didn't leave something out in this one. Good luck, Mark "whcinc" wrote: > Like Mark, I have performed the steps listed in this thread. And I, too, have > a great topology map. Except for a brief period when we first booted the > Vista computer, I have had no luck listing the netword shares, which are all > XP Pro machines. Has anyone else found out any more information that could > help? > > Thanks! |
| | #15 (permalink) |
| | RE: networking problem Vista & XP Thanks Mark. Yes, Norton is pre-installed. I think I will download the clean uninstaller from Norton to make sure it is ALL gone. Wish me luck. "Mark" wrote: > Search for a slightly more recent post on this by me(Mark). It would be maybe > a week newer than the last one I posted on here. It's been awhile, but I did > solve the problem. I don't remember all the details, but it was the firewall. > > My machine came with Norton pre-installed. I had set all the settings to > "off" with no luck. I had also checked the Windows firewall settings and they > were all set to off. I even went so far as to go to the specific details to > make sure it was very much off. > > I uninstalled Norton and it all sprang to life. Even with everything set to > "off" something was still "on". I still have Windows firwall off and as time > goes on I'll be re-integrating it back in. > > Norton security programs and Vista do not mix. Look back on my writeup on > this just to make sure I didn't leave something out in this one. > > Good luck, > Mark > > "whcinc" wrote: > > > Like Mark, I have performed the steps listed in this thread. And I, too, have > > a great topology map. Except for a brief period when we first booted the > > Vista computer, I have had no luck listing the netword shares, which are all > > XP Pro machines. Has anyone else found out any more information that could > > help? > > > > Thanks! |
| | #16 (permalink) |
| | RE: networking problem Vista & XP Hey Guys.. I have tried the LLD update, my xp puter is now shown in the network map. I also setup a basic network from xp and to my wonder it was successful, i could browse files from xp and vice-versa. But after i restarted my laptop i noticed that i can see my xp pc ico is seen in the network map but it cannot be clicked.. also when i go to network from startmenu i cannot view my xp puters icon there but just my local vista laptops ico. though i can browse the files from xp seamlessly, also //devicename from run can get me to view and browse files of xp. This is not a big problm for me as i can browse files etc, but how can i make the icon appear in the network in vista? |
| | #17 (permalink) |
| | Re: networking problem Vista & XP "Eric Haines" wrote: > > > "wacko163" wrote: > > > I'm having similar issues with my new Vista loaded laptop. My other computers > > all have XP and I can see the new laptop from them, but, Vista can't seem to > > find anything else in the workgroup. I have spent several hours trying > > everything to get this system to find the other workgroup computers and > > printers, to no avail. > > > > Thus far, I'm not overly impressed with Microsofts latest offering. It's not > > overly user friendly nor compatible with anything XP or previous. I'm not > > going to upgrade any of my other hardware until they get these connectivity > > issues fixed. > > > > "BooAngel03" wrote: > > > > > I shut down the firewall and I am still not able to see the other computers > > > on the network. The only thing I can see is their media players so I know > > > we're connected. Do you have any other suggestions??? > > > > > > "JP" wrote: > > > > > > > Try disabling the Windows Firewall and then see if you can connect. > > > > You might have to explicitly allow file and print sharing in the Windows Firewall. > > > > > > > > > > > > > > > > "Robert de Ridder" <ridder@remove.bigfoot.com> wrote in message > > > > news:uu0qr$%23SHHA.1016@TK2MSFTNGP04.phx.gbl... > > > > >I bought a new notebook with Vista Home Premium on it. > > > > > I changed the workgroup name to be the same as on my home network. > > > > > When trying to connect to a XP Pro system I can't see that computer or its shared folders in the > > > > > network group, only as a windows media player device. > > > > > Anyone know of a solution for this. > > > > > > > > > > Thanks in advance, > > > > > Robert > > > > > > > > > > > > |
| | #18 (permalink) |
| | Re: networking problem Vista & XP It wont be long before I downgrade my new computer back to XP Pro.. Im an mcsa and cant even get vista to change my internal network name from unidentified network. This os is a severe pile of.... |
| | #19 (permalink) |
| | Re: networking problem Vista & XP There's nothing wrong with Vista that getting rid of the AOL design engineers & putting real geeks back in charge won't fix. But it doesn't look like that is going to happen; so enjoy the new Fisher-Price front end and AOL back end. AOL took over the world by making their software for beginners (and protecting them from themselves) and ignoring power users... they are the #1 internet provider and software company now...aren't they? -- A Professional Amateur...If anyone knew it all, none of would be here! CarGodZeroOne@hotmail.com Change Alpha to Numeric to reply "rick" <rick@discussions.microsoft.com> wrote in message news:118FC4EA-4A1E-4F0A-A6A4-709D68F284C5@microsoft.com... > It wont be long before I downgrade my new computer back to XP Pro.. Im an > mcsa and cant even get vista to change my internal network name from > unidentified network. This os is a severe pile of.... |
| | #20 (permalink) |
| | RE: networking problem Vista & XP WARNING: Long post! This is a transcript of a "chat" with HP. Hi. Listen very carefully. I'm frustrated. I don't want to take it out on you. To avoid repeating vast amounts of information, I'm going to start with basic facts and continue to the more complex observations and THEN ask my questions. You are about to read a lot of information. Please be patient. I've pre-written most of this, and when we get to a point where I haven't, I type slowly. I know this isn't the way you're scripted to work but... thank you for bearing with me. I have a Compaq Presario F572US Notebook PC. The computer is running under Windows Vista Home Premium. My network workgroup is MSHOME. My home network is called Particles. I was sent a Recovery CD, so I deleted my D: drive and now my C:\ shows 66.5GB used space and 7.95GB free space. I have a WRT54G S/N:xxxxxxxxxxx; ver. 6; MAC: xxxxxxxxxA. Feel free to refer back to these primary notes. Do you understand everything I've typed so far? Note: I am not asking for solutions yet, just confirmation of understanding. I am sitting in a room with a router connected (wired) to three (3) other computers. One of them is runnung Windows Vista Ultimate. I am not concerned about this computer yet. I will not refer to it in the future. The other two desktop computers ("Blackbox" and "Tachyon") are wired, running under Windows XP (SP2). "Tachyon" is directly connected to the router. I'm going to move there now. They are also belong to the network "Particles" and share the workgroup "MSHOME". Let's call them"Blackbox" and"Tachyon". Tachyon is directly connected to the router. Is everything I've typed so far clear? Do you have any questions? Note: I am not asking for solutions yet, just confirmation of understanding. History: I replaced an Ethernet cable to one of the computers yesterday. It involved drilling and crawling under my house. It was not fun. I labled all the wires as they came out of the floor and again as they went back in (or out of the house in the case of the coax cables). When I was done all the wired computers could connect to each other and to the Internet. I didn't think to check the wireless connection as it's always worked. REPLETE: Up until I messed with the router connections, My Vista laptop could see each XP machines and visa versa. Today I find that I can't connect. Troubleshooting: The router works. As I say, "Blackbox" can see "Tachyon" and "Tachyon" can see "Blackbox". I've just spent a half hour on the phone with Linksys verifying this. It's just that neither can see the VISTA laptop. I went to Start>Network>Network and Sharing Center on the wireless Vista laptop which showed that I was connected to Particles (my network) and the Internet. The connection status states: IPv4 Connectivity: Internet IPv6 connectivity: Limited Media state: Enabled SSID: Particles Duration 13:15:11 Speed: 54.Mbps Signal quality: 4/5 bars (Very good) Network Discovery is ON (firewall is on and configured. Turning it off doesn't improve/change anything.) The IP addresses of the boxes are: Tachyon = 192.xxx.x.100 Blackbox = 192.xxx.1.2 Presario = 192.xxx.1.1 I mention this because from the laptop I can ping the desktops. Even though I've done this before, I downloaded the Link Layer Topology Discovery (LLTD) Responder (KB922120) and re-installed it on the XP machines. I unplugged both the router and my cable modem and turned off each machine. I went to the kitchen, got a refill on my coffee and came back. I then connected the cable, cooled my coffee off with Irish Cream and connected the router. When all the pretty lights were on, I booted the computer(s). After waiting a lifetime (it's XP on a slow machine), I went to START>Accessories>Windows Explorer>My Network Places> Entire Network>Microsoft Windows Network to see what was showing. Answer: Just the two XP machines. Before going on, do you understand everything I've typed so far? Do you have any questions? Note: I am not asking for solutions yet, just confirmation of understanding. Of course I'll hold on while you read/re-read/look up/ask for help/deal with another customer. I then went to START>Control Panel>Network and Internet Connections>Network Connections>Local Area Connection (Connected, Firewalled)>Status. There, I found: Status: Connected Duration: 6:46 Speed: 100.0Mbps In the Support tab, I found: Address Type: Assigned by DHCP IP Address: 192.xxx.x.xxx Subnet 255.xxx.xxx.x Default: 192.xxx.x.xxx You probably don't even need to know this stuff. HP stated that this is a "known issue" with Vista. they said to contact MS. I responded that "However I might wish to talk to Microsoft about these issues, this Vista is an OEM version and they won't talk to me. I HAVE to get my answers from you." They assured me that MS would talk to me. Of course, they won't. Interesting note: On my laptop, if I go to START and type RUN in the search bar, then type "\\ and then the IP address of the computer I want, it will find and display the computer. At the end of the chat, they said this would take care of it and then stopped responding. After 5 minutes, I logged off. I then went to my web mail to retrieve my transcript only to find a note thaT SAID THAT SINCE i HAD LOGGED OFF, NO TRANSCRIPT WAS SAVED. This represented over two hours "Talking" to them. I still don't have an answer. I tried the above thing with NetBios over TP but it didn't work for me. Unlike many of you, my laptop can't see the XP machines and the XP machines can't see the Vista laptop. Needless to say, I'm getting a little pissed off. I just don't know who I should be more pissed at. "Mick Jennings" wrote: Quote: > Posted this elsewhere - but this solved ALL my problems and without needing > the NETBIOS fix ... > > You need to install the LLTD Responder update for XP, downloadable from MS > at ... > > http://go.microsoft.com/fwlink/?LinkId=70582 |
| Problem networking XP & Vista | Vista networking & sharing | |||
| Vista to XP networking problem | Vista networking & sharing | |||
| Another XP & Vista networking problem. | Vista networking & sharing | |||
| Vista Networking problem with VPN | Vista networking & sharing | |||
| Different Vista XP networking problem | Vista networking & sharing | |||
