Vista - Vista freezes, what's the problem?
Old 02-09-2007   #1 (permalink)
Saman Rahbari
Hello,
My Dell Inspiron 6400 with Vista Business just keeps freezing randomly every
10-30min. Is there any way to see if it's a driver or application that is
causing this problem?
The computer completely stalls, I can't do anything except a hard reset.
Thank you,
Saman Rahbari
Old 02-09-2007   #2 (permalink)
Jane C
Re: Vista freezes, what's the problem?
Check entries in Event Viewer. There may be something there to give you an
indication.
Jane, not plain 64 bit enabled :-)
Batteries not included. Braincell on vacation ;-)
"Saman Rahbari" <SRahbari@thgri.org> wrote in message
news:OSGzoEBTHHA.996@TK2MSFTNGP02.phx.gbl...
> Hello,
> every 10-30min. Is there any way to see if it's a driver or application
> that is causing this problem?
> Thank you,
> Saman Rahbari
Old 02-09-2007   #3 (permalink)
Chad Harris
Speed PC and Control CPU Tips/Steps
SPEED AND CPU:
_______________
1) Trim processes you don't need in TM. Google them or "search engine of
your choice them" if you have to.
2) Go to
services.msc in run box and turn off services not needed and there are some.
SERVICE CONFIGURATION REFERENCES*
*Vista Services*
Part One
http://www.tweakvista.com/article38662.aspx
Part Two
http://www.tweakvista.com/article38664.aspx
Windows Vista Services Tweak Guide v1.0
http://www.msfn.org/board/index.php?showtopic=87443
3) Run System File Checker.
SFC: http://www.updatexp.com/scannow-sfc.html
In Vista run it from an elevated command prompt. Right click command on
start and run as administrator.
4) Run 3 or so spyware scans Windows Defender, , Adaware, and Spybot
5) Probably the most important for speed consistently and efficient resource
use DEFRAG with www.raxco.com or www.diskeeeper.com with 15% free space on
drive if DK and or >5% if Raxco's Perfect Disk.
http://groups.msn.com/windowsxpcentral/spyware.msnw
Download Adaware and
Spybot from here.
GOOD Overall Review for Defending Your PC:
http://defendingyourmachine.blogspot.com/
MSFT Defense Site MSFT Security:
http://www.microsoft.com/security/default.mspx
Protect Your PC from MSFT Security:
http://www.microsoft.com/athome/secu...t/default.mspx
MSFT Windows Defender
http://www.microsoft.com/athome/secu...e/default.mspx
MSFT MSRT: (Malicious Software Removal Tool)
http://www.microsoft.com/security/ma...e/default.mspx
MSFT "Windows One Care" in Wings (AV and Spyware Scans)
http://www.microsoft.com/presspass/p...OneCarePR.mspx
6) Unck items from msconfig start tab you don't need starting and some
won't start--peoiple who think just uncking for many are naive because there
are 12 places things can be started including several reg keys like Run Once
keys and there are serveral.
7) Turn off Messaging service--it's a security vulnerability and it slows
you
8) Defrag very often every other day actually.
9) Turn off indexing.
10) Clear TIF and %temp% files (delete) and go to safe mode to get as many
as u can.
10) Do troubleshooting with msconfig.
11) Do Clean boot with msconfig utility and search for the directions here:
Vista RTM Tweak Guide (Tweaks to Improve Performances)
http://www.google.com/search?sourcei...tm+tweak+guide
1) Task Manager lists the services on the services tab in Vista.
2) Type services.msc in run box and using the list of services, click the
service and you'll get a description of services.
3) There is a list here of the default services and a description>>click
"default settings for services" in the left pane.
http://technet2.microsoft.com/Window....mspx?mfr=true
4) To view service dependencies
1.
Open Services.
2.
In the details pane, right-click the service that you want to view
dependencies for, and then click Properties.
3.
Click the Dependencies tab.
4.
To view services that are associated dependencies of the selected service,
in the list on the Dependencies tab, click the plus sign next to the
service.
Many of the services but not all in Vista are the same as in XP, so in that
context:
http://www.mvps.org/winhelp2002/services.htm
Also see the extremely helpful site:
Black Viper's Service List
http://www.dead-eye.net/WinXP%20Services.htm
Black Viper's Site (Many of the same services in Vista)
http://www.z123.org/techsupport/xpservices.htm
http://www.geocities.com/ziyadhosein/xpserv1.htm
http://www.pacs-portal.co.uk/startup_content.php
This will be helpful
http://web.archive.org/web/200411280...servicecfg.htm
______________________________________________________________________________________________
How to troubleshoot by using the System Configuration utility in Windows XP
http://support.microsoft.com/kb/310560/
Resources for troubleshooting startup problems in Windows XP
http://support.microsoft.com/kb/308041/
How to perform advanced clean-boot troubleshooting in Windows XP
http://support.microsoft.com/default...b;en-us;316434
How to perform a clean boot in Windows XP
http://support.microsoft.com/kb/310353/
How to Disable a Service or Device that Prevents Windows from Starting
http://support.microsoft.com/kb/310602/
Also ck out these references:
http://www.extremetech.com/article2/0,1558,5155,00.asp
http://www.speedupyourcomputer.windo....com/index.htm
and
http://www.extremetech.com/search_re...app=&site=4P.S.
Defragging with a decent defrag every day will make a huge dent inefficient
resource/CPU use.
Perfect Disk has a 5 month full functionality trial on now for Windows
Vista.
Good luck,
CH
> Hello,
> Thank you,
> Saman Rahbari
Vista freezes at green start up bar/freezes for a few seconds on desktop General Discussion
Vista freezes! General Discussion
Attention Vista Freezes Problem Solved! Vista General
Vista 64 bit occasionally freezes-my last Vista problem to be resolved! Vista General
Movie Maker Freezes - problem report details Vista music pictures video
