Vista Tutorial - Product ID problems
Old 02-10-2007   #1 (permalink)
Mark
Guest
Product ID problems
I have Windows Vista 64bit upgrade retail and when I went to use
Microsoft chat support, it requires the PID. I choose what country I am
in, what version of software and then the product ID. After entering the
product ID it says
"The product ID number you entered is not supported in the country that
you have selected. Enter another product ID number or select a different
support option below."
Microsoft has told me my product is OEM, pirated, not 64 bit and finally
said it was downloaded from Digital River. Microsoft support is such a
mess.
I see on these groups I am not the only person having this problem but
yet MS says it is me or my software. MAYBE someone at MS would look into
this issue at a higher lever as opposed to keep pushing me off to a 3rd
world country support staff which is useless.
I have also ran the WGA tool and used every thing I can find to verify
my software as authentic and it passes them all. Does anyone have any
idea why this is happening?
Mark
Old 02-10-2007   #2 (permalink)
Jonathan Schwartz 2
Guest
RE: Product ID problems
Mark,
Likely you and Microsoft are each correct...
Perhaps better expressed, exactly how much did you pay for your Vista Version?
If the price that you paid is equal to the prices provided by Microsoft
Sales, you are correct.
If the price you paid is considerably less than the prices provided by
Microsoft Sales, well, Microsoft is correct.
Are you certain that you do not have retail Vista Upgrade OEM?
Windows Vista
Become Part of The Legacy!
> product ID it says
> mess.
> Mark
Old 02-10-2007   #3 (permalink)
molitar
Guest
Re: Product ID problems
No such thing as OEM upgrade. OEM is for new builds only so you can't have
an OEM Upgrade. But who knows M$ already given out wrong keys to users that
purchased Vista Home Premium with their retail version. M$ seems to be such
a damn mess it needs a structural overhaul.. what a mess.
Marvin
"Jonathan Schwartz 2" <JonathanSchwartz2@discussions.microsoft.com> wrote in
message news4A6DB1F-F640-4313-B182-D109D9770214@microsoft.com...
> Mark,
> Version?
> Windows Vista
>> product ID it says
>> mess.
>> Mark
Old 02-10-2007   #4 (permalink)
Mark
Guest
> have an OEM Upgrade. But who knows M$ already given out wrong keys to
> users that purchased Vista Home Premium with their retail version. M$
> seems to be such a damn mess it needs a structural overhaul.. what a mess.
> Marvin
> wrote in message news4A6DB1F-F640-4313-B182-D109D9770214@microsoft.com...
>> Mark,
>> Version?
>> Windows Vista
>>> product ID it says
>>> mess.
>>> Mark
Well, I went around in circles again today. It is so amazing MS does not
require the contractor to support their customers. I am again waiting
for an escalation call back. I am sure it will be from the Windows Vista
Research Team that is of no help.
Mark
Old 02-10-2007   #5 (permalink)
Synapse Syndrome
Guest
LOL.
ss.
Old 02-10-2007   #6 (permalink)
Jonathan Schwartz 2
Guest
Hello Mark,
Hindsight is such a marvelous teacher, unfortunately, sometimes the things
learned are simply sad.
>>Mark wrote<<
Mark, Microsoft *does* require OEMs to provide technical support to their
customers. Also, for specific not-defined reasons, Microsoft does not and
will not provide technical support for OEM product users.
So, you are between the proverbial rock and hard place.
Very seriously, my suggestion for your situation, bite the bullet and
attempt receiving a refund for the OEM (at least a credit) and then purchase
Genuine Microsoft Products.
Should you pay Microsoft for one or two technical support telephone calls,
likely that would equal or exceed the purchase price for Genuine Software
with free technical support.
Too many others before you experienced what currently you are experiencing.
Vista 64-bit has a much higher level of inherent security compared to Vista
32-bit, it will require OEMs a long time to self-educate regarding 64-bit
technology, be it XP or Vista.
Considering the inherent security provided by 64-bit technology, in the near
future 64-bit technology will be more common than 32-bit. Also, it will not
be long before 128-bit and higher technology will be the only options within
the market place and 32-bit will be equal to the original DOS OS, ancient
history.
Reference the below copy-and-paste from Microsoft (in part) as my premise
for the above conviction:
64-Bit Security Enhancements:
Kernel Patch Protection and Mandatory Driver Signing Some of the most dire
security issues arise from malicious software that manipulates the operating
system “kernel,” rendering malicious software undetectable to anti-virus
software and running unnoticed on a user’s system. These “rootkits” are often
used to cloak other potentially unwanted software, such as bots and spyware.
Beyond the serious security implications of rootkits, this class of malicious
software can reduce the stability, reliability and performance of the entire
system, including all user programs.
Addressing these problems has been difficult because many 32-bit Windows
drivers are not identified with a digital signature, or they modify the
kernel for legitimate purposes but by unsupported means. Implementing
stricter control over these modifications could create major compatibility
and performance issues. Some 32-bit security products that provide
behavior-blocking capabilities modify the kernel through unsupported methods;
accordingly, Microsoft is partnering with third-party security vendors to
investigate robust, secure and supported alternative platform mechanisms.
However, as computing moves from a 32-bit to a 64-bit architecture, the
smaller installed base of 64-bit software makes it possible to make
significant enhancements to the security of the kernel, reducing the
potential for rootkits and similar types of malicious software to negatively
impact users’ systems.
Kernel Patch Protection for x64. The 64-bit versions of Windows Vista
support Microsoft’s kernel patch protection technology (sometimes referred to
as PatchGuard), which prevents unauthorized software from modifying the
Windows kernel. Kernel patch protection works by preventing kernel-mode
drivers from extending or replacing operating system kernel services, and by
prohibiting all software from performing unsupported patches in the kernel.
In addition to improving security and making it more difficult for hackers to
modify the kernel for malicious purposes, kernel patch protection also helps
prevent other software from making unauthorized or unsupported modifications
to operating system data structures (such as the interrupt dispatch table),
thereby greatly improving the overall security, reliability and performance
of Windows.
Kernel patch protection is not a guarantee of security, but by blocking
unsupported and potentially malicious behavior in the kernel environment, it
improves the security and reliability of Windows Vista and enables future
improvements in the kernel environment that can address the evolving changes
in the landscape of malicious software. More information about kernel patch
protection is available at
http://www.microsoft.com/whdc/driver...tpatching.mspx.
Mandatory Kernel Module and Driver Signing for x64.
To give users visibility into the source of drivers and other software
running in the operating system kernel, Microsoft introduced the concept of
“signed drivers” beginning with Windows 2000. Although it was possible to
prevent unsigned drivers from installing, the default configuration only
warned users if they were about to install an unsigned driver. IT
administrators could also block installation of unsigned drivers via Group
Policy, but the large installed base of unsigned drivers made this
impractical in most situations. Malicious kernel software typically tries to
install silently, with no user consent — and because no kernel load-time
check existed before Windows Vista, malicious kernel software was likely to
run successfully, assuming these actions were performed by a user with
administrative privileges.
With Windows Vista on 64-bit systems, security at the kernel level has been
greatly enhanced by requiring that all kernel-mode drivers be digitally
signed. Digital signing provides identity as well as integrity for code. A
kernel module that is corrupt or has been subject to tampering will not load.
Any driver that is not properly signed cannot enter the kernel space and will
fail to load.
Although a signed driver is not a guarantee of security, it does help
identify and prevent many malicious attacks, while allowing Microsoft to help
developers improve the overall quality of drivers and reduce the number of
driver-related crashes.
Mandatory driver signing also helps improve the reliability of Windows Vista
because many system crashes result from vulnerabilities in kernel-mode
drivers. Requiring the authors of these drivers to identify themselves makes
it easier for Microsoft to determine the cause of system crashes and work
with the responsible vendor to resolve the issue. System administrators also
benefit from digitally signed and identified drivers because they get
additional visibility into software inventory and install state on client
machines. From a compatibility perspective, existing Windows Hardware Quality
Labs certified x64 kernel drivers are considered validly signed in Windows
Vista.
Windows Vista
Old 02-10-2007   #7 (permalink)
Jupiter Jones [MVP]
Guest
"No such thing as OEM upgrade"
Not always true.
When Windows XP came out more than 5 years ago, some OEMs did similar to
what they are doing today.
At that time some shipped OEM Upgrade CDs.
They had a very short and limited availability.
Whether there will also be OEM upgrades for Vista is yet to be seen.
Jupiter Jones [MVP]
http://www3.telus.net/dandemar
http://www.dts-l.org
"molitar" <molitar@gmail.com> wrote in message
news:FAF7A0A7-B6FF-4454-BF6D-1DE746A663F4@microsoft.com...
> Marvin
>> Mark,
>> Version?
>> Windows Vista
>>> product ID it says
>>> mess.
>>> Mark
Old 02-10-2007   #8 (permalink)
Quiztar
Guest
You would laugh however I have seen OEM Upgrade CD's for sale on the market
from legitimate online retailers who shall remain nameless.
> LOL.
> ss.
Old 02-10-2007   #9 (permalink)
Mark
Guest
I paid $259 for the Ultimate Upgrade and bought it from Staples.
Software came in that plastic container sealed like mad with 2 CDs (64
bit and 32 bit)and my software passes all the WGA verification yoiu can
throw at it.
I am right and Microsoft is wrong or should I say their lame 3rd world
country support is wrong and just Microsoft's PID database is broken.
I think it maybe for the business versions and 64 bit versions this
problem exists.
I sure would like to speak with someone at Microsoft in Washington about
this because this brings back memories of Win956,98 and Millennium which
all had Key and PID issues that took months for Microsoft to admit
Mark
Jonathan Schwartz 2 wrote:
> Mark,
Old 02-10-2007   #10 (permalink)
Mark
Guest
Mine is not OEM but even if it was, MS did it by packaging it in the
retail box which was sealed with all kind of security seals.
Ms is broken with their PID database and such and needs to fix it either
by releasing a patch or allowing owners to get Keys that will generate
working PIDs
Mark
>> LOL.
>> ss.
Product Key Problems Vista installation & setup
Product Key problems Vista account administration
Product Problems with Vista Vista General
product key problems Vista General
Annoying product key problems Vista hardware & devices
Designer Media Ltd
