Vista - power issues in vista ultimate
Old 02-11-2007   #1 (permalink)
aarbie
Hi
I have a bespoke system built around an ASUS AM2 M2n-E motherboard and AMD
64 X2 4200+ CPU with Vista ultimate 32bit installed.
Under windows Xp SP2 I used to rely on AMD's cool and quiet functionality
which was both bios enabled and driver installed. Since Vista, these settings
have been disabled in the bios and as no C+Q driver exists in Vista, nothing
has been installed.
Since migrating to Vista ultimate - as a clean install - I am unable to
control power settings so that:
1. screensaver activates after 'X' minutes - whatever i try, SS does not
activate
2. in power savings, I have opted for 'balanced plan' even with 'turn off
display after' 10 mins and 'put computer to sleep': 1 hour - nothing happens.
Any advice on finding a solution to this would be greatly apprecaited.
thanks
RB
Old 02-11-2007   #2 (permalink)
Ed Stoddard
RE: power issues in vista ultimate
You will have to trun OFF User Account Control (UAC) by going to
START/CONTROL PANEL/ USER ACCOUNTS and clicking on the link, "Turn User
Account Control on or off." You will required to reboot. Then make all your
adjustment as you want them. When done go back and turn UAC ON. You will be
require to reboot. Your settings will remain from boot to boot.
"aarbie" wrote:
> Hi
> has been installed.
> activate
> thanks
> RB
Old 02-12-2007   #3 (permalink)
aarbie
Hi Ed
thnaks for the advice. I tried this, and sadly no screensaver or ohter power
saving features kicked in.
For ref, I am running an ASUS M2n-E AM2 board with AMD 64 X2 4000+ CPU.
Could there be some pwer saving conflict going on?
RB
> "aarbie" wrote:
> > Hi
> > has been installed.
> > activate
> > thanks
> > RB
Old 02-12-2007   #4 (permalink)
jggillette
I'm having the same exact problem. I have an Asus P5N32-SLI Premium/ WiFi-AP
motherboard running a Intel E6600 processor.
"aarbie" wrote:
> Hi Ed
> RB
> > "aarbie" wrote:
> > > Hi
> > > has been installed.
> > > activate
> > > thanks
> > > RB
Old 02-17-2007   #5 (permalink)
Fearz
Re: power issues in vista ultimate
Well, I understand the AMD cool&nquiete + AMD drivers are already packaged
with Vista?
"aarbie" <aarbie@discussions.microsoft.com> wrote in message
news:34A4D8E6-E690-4275-8888-68FD0A4B680E@microsoft.com...
>I cannot explain it- all power features are now working!
> The only thing I did was download an HID patch driver during a windows
> update and all is fine,
> R
>> WiFi-AP
>> "aarbie" wrote:
>> > Hi Ed
>> > power
>> > RB
>> > > User
>> > > all your
>> > > will be
>> > > "aarbie" wrote:
>> > > > Hi
>> > > > and AMD
>> > > > functionality
>> > > > these settings
>> > > > Vista, nothing
>> > > > has been installed.
>> > > > unable to
>> > > > does not
>> > > > activate
>> > > > 'turn off
>> > > > nothing happens.
>> > > > apprecaited.
>> > > > thanks
>> > > > RB
Old 02-18-2007   #6 (permalink)
aarbie
R
> "aarbie" wrote:
> > Hi Ed
> > RB
> > > "aarbie" wrote:
> > > > Hi
> > > > has been installed.
> > > > activate
> > > > thanks
> > > > RB
Old 02-18-2007   #7 (permalink)
jggillette
I narrowed my problem down to my Microsoft Wireless Laser Keyboard/ Mouse
combo. With the receiver plugged in Vista wouldn't go into Power Saving mode.
So the HID patch would make sense (HID = Human Interface Device). I'm going
to reload Windows Vista and give it another shot. I'll let you know my
results.
As a side note, I think it's rediculous that Microsoft's own hardware that
is touted as being Vista compatable right on the packaging causes problems
with it's own software.
> R
> > "aarbie" wrote:
> > > Hi Ed
> > > RB
> > > > "aarbie" wrote:
> > > > > Hi
> > > > > has been installed.
> > > > > activate
> > > > > thanks
> > > > > RB
Old 02-19-2007   #8 (permalink)
jggillette
I reloaded windows, downloaded the HID patch available through Microsoft
Update and the power saving mode works perfect with my Microsoft Laser
Keyboard/ Mouse combo.
> results.
> > R
> > > "aarbie" wrote:
> > > > Hi Ed
> > > > RB
> > > > > "aarbie" wrote:
> > > > > > Hi
> > > > > > has been installed.
> > > > > > activate
> > > > > > thanks
> > > > > > RB
Old 03-29-2007   #9 (permalink)
RickP182
The HID patch solved the issues!
> > results.
> > > R
> > > > "aarbie" wrote:
> > > > > Hi Ed
> > > > > RB
> > > > > > "aarbie" wrote:
> > > > > > > Hi
> > > > > > > has been installed.
> > > > > > > activate
> > > > > > > thanks
> > > > > > > RB
Power Options problems Vista Ultimate Virtual PC
Vista Ultimate 64 ideal Power Settings? General Discussion
Vista Ultimate 64bit power(?) problem!!! Vista installation & setup
3rd Time Vista Ultimate (x64) won't Boot After Power-Off Vista General
Vista Ultimate and Media Center - Recording TV after power failure Vista music pictures video
