| | Vista hardware initialization problems I am having spuratic problems with device drivers loading and hardware initializing properly under Vista. 1> About 1 out of ever 4 times I boot the system, Vista does not detect the audio hardware on my motherboard and load the device drivers for it. If I reboot the system, it loads up and works fine though. 2> For months the DVD burner in my system was working fine, but in the last few days it stopped working. Vista detects it and loaded the device drivers, but it does not initialize the hardware properly. (I always get error "code 37".) Note that the system does detect that the DVD drive is there, and the driver does get the model number from the drive. 3> I sometimes have trouble with dual monitors in Vista. I have an Nvidia 7800GS card with monitors connected to both "heads", and the second monitor occationally comes up in the wrong resolution or does not display anything. Rebooting the system always seems to resolve this. I have verified that the hardware is working properly by running hardware diagnostics from DOS. I also tried replacing the DVD drive just to make sure, but I had the same problem with the new drive. I have also tried looking for newer drivers, but in all cases I am running the most recent version. Anyone have any suggestions? |
| | RE: Vista hardware initialization problems I've had the same issues. You just have to follow through all the steps everytime it gives you the error messages. they eventually go away and everything works fine. I have spent days upgrading & downloading just to have it tell me everything is fine and then not work the next boot. Have fun! They don't seem to know why any of this is happening either. Hard to think they didn't come up with any of these issues over the Past 5+ years putting it together. Hopefully, they'll get something right soon... "dot" <"mediawizrd (at) hotmail (dot) com" wrote: > I am having spuratic problems with device drivers loading and hardware > initializing properly under Vista. > > 1> About 1 out of ever 4 times I boot the system, Vista does not detect > the audio hardware on my motherboard and load the device drivers for > it. If I reboot the system, it loads up and works fine though. > > 2> For months the DVD burner in my system was working fine, but in the > last few days it stopped working. Vista detects it and loaded the > device drivers, but it does not initialize the hardware properly. (I > always get error "code 37".) Note that the system does detect that the > DVD drive is there, and the driver does get the model number from the drive. > > 3> I sometimes have trouble with dual monitors in Vista. I have an > Nvidia 7800GS card with monitors connected to both "heads", and the > second monitor occationally comes up in the wrong resolution or does not > display anything. Rebooting the system always seems to resolve this. > > I have verified that the hardware is working properly by running > hardware diagnostics from DOS. I also tried replacing the DVD drive > just to make sure, but I had the same problem with the new drive. > > I have also tried looking for newer drivers, but in all cases I am > running the most recent version. > > Anyone have any suggestions? > |
| Vista 32-bit problems with resolution and hardware acceleration | Drivers | |||
| hardware problems with Vista 64..ram and Nvidia | Vista hardware & devices | |||
| Vista 64: Major problems after hardware upgrade | General Discussion | |||
| Initialization or re start Vista | Vista performance & maintenance | |||
| Vista hardware initialization problems | Vista hardware & devices | |||
