| | Vist Will Not Recognize Blank CDR Disk I have two different plextor drives (different models) both fairly new. They read media fine but when I put a blank CDROM into the drive Vista never recognizes the disk are there. There is no autoplay option available to make the disk writeable. Anybody have the same problem. Thanks, Bryan Vista Ultimate Ed. |
| | Re: Vist Will Not Recognize Blank CDR Disk It's likely this is a firmware issue. Check either with your Computer manufacturer or Plextor for an update. "Bryan Krossley" <krossley@mindspring.com> wrote in message news:328C9733-0B54-40E0-A322-B27236BEB07C@microsoft.com... >I have two different plextor drives (different models) both fairly new. > They read media fine but when I put a blank CDROM into the drive Vista > never > recognizes the disk are there. There is no autoplay option available to > make the disk writeable. Anybody have the same problem. > > Thanks, > > Bryan > Vista Ultimate Ed. |
| | Re: Vist Will Not Recognize Blank CDR Disk I thought the same thing. I have updated the firmware to the latest release. Bryan "LaRoux" <hlx@newsgroup.nospam> wrote in message news:eFMHxftTHHA.3652@TK2MSFTNGP04.phx.gbl... > It's likely this is a firmware issue. Check either with your Computer > manufacturer or Plextor for an update. > > "Bryan Krossley" <krossley@mindspring.com> wrote in message > news:328C9733-0B54-40E0-A322-B27236BEB07C@microsoft.com... >>I have two different plextor drives (different models) both fairly new. >> They read media fine but when I put a blank CDROM into the drive Vista >> never >> recognizes the disk are there. There is no autoplay option available to >> make the disk writeable. Anybody have the same problem. >> >> Thanks, >> >> Bryan >> Vista Ultimate Ed. > > |
| | Re: Vist Will Not Recognize Blank CDR Disk On Mon, 12 Feb 2007 12:52:21 -0500, "Bryan Krossley" <krossley@mindspring.com> wrote: >I have two different plextor drives (different models) both fairly new. >They read media fine but when I put a blank CDROM into the drive Vista never >recognizes the disk are there. There is no autoplay option available to >make the disk writeable. Anybody have the same problem. > >Thanks, > >Bryan >Vista Ultimate Ed. I had same problem with my SATA DVD/CD writer. It turned out to be a virtual drive (Deamon Tools) that was conflicting with it. |
| | Re: Vist Will Not Recognize Blank CDR Disk I have the same problem with the LightScribe drive in my HP a1440n computer. HP hasn't come out with any updated firmware/driver, so right now I'm using an external usb cd/dvd burner, it's working fine. "Bryan Krossley" <krossley@mindspring.com> wrote in message news:328C9733-0B54-40E0-A322-B27236BEB07C@microsoft.com... >I have two different plextor drives (different models) both fairly new. > They read media fine but when I put a blank CDROM into the drive Vista > never > recognizes the disk are there. There is no autoplay option available to > make the disk writeable. Anybody have the same problem. > > Thanks, > > Bryan > Vista Ultimate Ed. |
| | #6 (permalink) |
| | Re: Vist Will Not Recognize Blank CDR Disk BP, I have deamon tools loaded as well. I use this program all the time. Did you find a solution? Thanks, Bryan "bp" <6ball@comcast.net> wrote in message news:s1m1t2po98lq1kau0720hgc8andhq95dcn@4ax.com... On Mon, 12 Feb 2007 12:52:21 -0500, "Bryan Krossley" <krossley@mindspring.com> wrote: >I have two different plextor drives (different models) both fairly new. >They read media fine but when I put a blank CDROM into the drive Vista never >recognizes the disk are there. There is no autoplay option available to >make the disk writeable. Anybody have the same problem. > >Thanks, > >Bryan >Vista Ultimate Ed. I had same problem with my SATA DVD/CD writer. It turned out to be a virtual drive (Deamon Tools) that was conflicting with it. |
| | #7 (permalink) |
| | Re: Vist Will Not Recognize Blank CDR Disk This is confirmed. I have just uninstalled Daemon Tools and the Vista recogizes my blank cdr. Hope this gets fixed. I used Daemon all the time. BK "Bryan Krossley" <krossley@mindspring.com> wrote in message news:ODLjBCvTHHA.1552@TK2MSFTNGP05.phx.gbl... BP, I have deamon tools loaded as well. I use this program all the time. Did you find a solution? Thanks, Bryan "bp" <6ball@comcast.net> wrote in message news:s1m1t2po98lq1kau0720hgc8andhq95dcn@4ax.com... On Mon, 12 Feb 2007 12:52:21 -0500, "Bryan Krossley" <krossley@mindspring.com> wrote: >I have two different plextor drives (different models) both fairly new. >They read media fine but when I put a blank CDROM into the drive Vista never >recognizes the disk are there. There is no autoplay option available to >make the disk writeable. Anybody have the same problem. > >Thanks, > >Bryan >Vista Ultimate Ed. I had same problem with my SATA DVD/CD writer. It turned out to be a virtual drive (Deamon Tools) that was conflicting with it. |
| | #8 (permalink) |
| | Re: Vist Will Not Recognize Blank CDR Disk Try a different make of media? I had to update the firmware in my PX 760 and PX 716SA drives to get VISTA to see them but you say you have checked this. |
| | #9 (permalink) |
| | Re: Vist Will Not Recognize Blank CDR Disk On Mon, 12 Feb 2007 16:55:25 -0500, "Bryan Krossley" <krossley@mindspring.com> wrote: >BP, > >I have deamon tools loaded as well. I use this program all the time. Did you find a solution? > >Thanks, Yes, unistalled Deamon tools wait for update. > >Bryan > "bp" <6ball@comcast.net> wrote in message news:s1m1t2po98lq1kau0720hgc8andhq95dcn@4ax.com... > On Mon, 12 Feb 2007 12:52:21 -0500, "Bryan Krossley" > <krossley@mindspring.com> wrote: > > >I have two different plextor drives (different models) both fairly new. > >They read media fine but when I put a blank CDROM into the drive Vista never > >recognizes the disk are there. There is no autoplay option available to > >make the disk writeable. Anybody have the same problem. > > > >Thanks, > > > >Bryan > >Vista Ultimate Ed. > > I had same problem with my SATA DVD/CD writer. It turned out to be a > virtual drive (Deamon Tools) that was conflicting with it. |
| | #10 (permalink) |
| | Re: Vist Will Not Recognize Blank CDR Disk Yes. I just did a update to my PX-755A and PX-712A. They work fine when I uninstall Daemon Tools as stated in my last post. Hugh are you running Daemon Tools? Thanks, Bryan "Hugh Wyn Griffith" <huwyngr@tampabay.rr.com> wrote in message news:VA.00000112.007c4059@tampabay.rr.com... Try a different make of media? I had to update the firmware in my PX 760 and PX 716SA drives to get VISTA to see them but you say you have checked this. |
| DVD burner won't recognize blank DVD's | Vista hardware & devices | |||
| Hard disk access non stop on new Vist Home Premium 64 bit | Vista General | |||
| a labeled readyboost USB flasdrive "not recognize unknown" in Vist | Vista performance & maintenance | |||
| Sata DVD don't recognize blank media | Vista hardware & devices | |||
| Re: My LG GSA-H21L DVD/CD burner doesn't recognize blank media | Vista hardware & devices | |||
