| | Avoid "System32": Where to place an INI file? Friends, Our application uses a few INI entries in our own ZZZ.INI file located in "System32". (We use database records most all configuration, but some entries must be handled before a DB connection is established.) The INI file use is part legacy, and partly for ease of editing; we hesitate to have customers make registry entries. Anyway, Vista "UAC virtualization" ensures that writes to the INI file do not actually alter the "System32" INI file, but this results in per-user entries. We plan to add an "AsInvoker manifest" to our next build to prohibit "virtualization". But, we want to change the location for the INI file to someplace acceptable to Vista. Such a location must be referenced by something in the environment, similar to %SYSTEMROOT%. The best I've found so far is %ALLUSERSPROFILE% Is this an acceptable location for our INI file? IS there a more standard place for such things? Should I bite the bullet and use the registry? (Accompanied by a little user app to read/write registry entries, so as to isolate our users from regedit.) There are some other common read/write files that we plan to place in this new location too, so I want to get things right. Any words of advice will be greatly appreciated. Thanks in advance! James |
| "Extensible Authentication Protocol" service gives "The system cannot find the file specified" error | Vista networking & sharing | |||
| Windows mail shuts down when "Insert" - "File Attachments" is sele | Vista mail | |||
| Avoid "carriage return" in text file | PowerShell | |||
| how to create file under "system32"? | Vista General | |||
| How to avoid "The requested operation requires elevation" | Vista General | |||
