| | Very weird display problems...help...Thanks Please help. I have an inspiron 6000 (ATI x300 128 Meg) I have an external dispay of a Dell 2405 FPW and I just received my Windows Vista Home Prem. I get everything installed and it works ok. However when I view with my external display, There is a screen jitter on the screen. It starts from the top of the screen, jitters left to right a few times very fast, then goes down an inch and does it again, all the way down, then starts over. I have updated all drivers...What could be causing this? Thanks so much.. Rob |
| | RE: Very weird display problems...help...Thanks Well no one seems to have this problem, and XP does not display it, so I am going to return Vista. Thanks. "Rob" wrote: > Please help. > I have an inspiron 6000 (ATI x300 128 Meg) > I have an external dispay of a Dell 2405 FPW > and I just received my Windows Vista Home Prem. > > I get everything installed and it works ok. However when I view with my > external display, There is a screen jitter on the screen. It starts from the > top of the screen, jitters left to right a few times very fast, then goes > down an inch and does it again, all the way down, then starts over. > > I have updated all drivers...What could be causing this? > > Thanks so much.. > > Rob |
| | RE: Very weird display problems...help...Thanks Rob Same problem, only in IE when I open Favorites. This is when I get the screen jitter, very fast. I have Ultimate and did a conversion from XP. I have no solution other than the one you suggest...return.....Rogue "Rob" wrote: > Please help. > I have an inspiron 6000 (ATI x300 128 Meg) > I have an external dispay of a Dell 2405 FPW > and I just received my Windows Vista Home Prem. > > I get everything installed and it works ok. However when I view with my > external display, There is a screen jitter on the screen. It starts from the > top of the screen, jitters left to right a few times very fast, then goes > down an inch and does it again, all the way down, then starts over. > > I have updated all drivers...What could be causing this? > > Thanks so much.. > > Rob |
| | RE: Very weird display problems...help...Thanks Well I figured it out last night. Dell sent me a new monitor even though I told them I thought it was a driver problem. I sent back my 2405 and they gave me a 2407, same problem was there. Last night I got fed up and said I am going to figure it out. I uninstalled all the video drivers, then set the ATIx300 XP driver. Once done I had no aero, but there was no jiggle or wiggle. I then went to ATI's site and downloaded the ATI Radeon Catalyst Beta VISTA RTM drivers. IT WORKS!!!!! No screen problems at all, so this is 100% a driver issue on Dell/ATI's part and needs to be corrected. Thanks "Rogue" wrote: > Rob > > Same problem, only in IE when I open Favorites. This is when I get the > screen jitter, very fast. I have Ultimate and did a conversion from XP. > > I have no solution other than the one you suggest...return.....Rogue > > "Rob" wrote: > > > Please help. > > I have an inspiron 6000 (ATI x300 128 Meg) > > I have an external dispay of a Dell 2405 FPW > > and I just received my Windows Vista Home Prem. > > > > I get everything installed and it works ok. However when I view with my > > external display, There is a screen jitter on the screen. It starts from the > > top of the screen, jitters left to right a few times very fast, then goes > > down an inch and does it again, all the way down, then starts over. > > > > I have updated all drivers...What could be causing this? > > > > Thanks so much.. > > > > Rob |
| Anyone else having weird problems with comcast.net email | Live Mail | |||
| weird boot up problems | General Discussion | |||
| Re: Weird keyboard problems / Possible keylogger? | Vista General | |||
| Weird problems I just cant figure out.. | Vista performance & maintenance | |||
| Weird problems with startup | Vista performance & maintenance | |||
