| | NT Kernel & System is out of control. It's using CPU 56% everytime my CPU usage just keep going up from 56% and goes down to 1% all the time. It does this over and over. when i put my computer to sleep mode and use my computer again the cpu usage issue just disappear. Are there any issue with NT Kernel & system? |
| Vista Ultimate 32bit. | Re: NT Kernel & System is out of control. It's using CPU 56% everytime Just goto the bios setings off your computer and load defaut settings for you motherboard. start Vista en see problem solved. sometimes an bios update can also help. reinstall OS will NOT!! NOT work grtz Edwin |
| NT Kernel and System: problem | Vista General | |||
| NT kernel & system probs.... | General Discussion | |||
| nt kernel & system hi cpu | Vista General | |||
| Explorer crashes everytime i open the Control panel. | Vista General | |||
| User Account Control is blocking SAME program everytime I load it | Vista performance & maintenance | |||
