| | Installation problems I downloaded windows vista threw e-academy, i either had the option of dvd and cd. Since i dont have a dvd i got the 5 cds. I ran the windows vista advisor and my computer can support it, except that i should consider upgrading my video card. My problem is i cant install it. When i boot with the cd, it freezes on the loading screen (where you can see Microsoft Corporation and the progress loading bar) and when i run the installation from windows (XP pro), i get a 0x0 error. Does anyone know why this happends? Is it driver related or got it be compability with my laptop? |
| | Re: Installation problems What make and model of laptop? What are the specs of the laptop? How much RAM, what type of graphics processor etc. Did the Upgrade Advisor flag anything else as having potential issues? -- Jane, not plain 64 bit enabled :-)Batteries not included. Braincell on vacation ;-) "Raphael" <Raphael@discussions.microsoft.com> wrote in message news:51292817-1BF7-4EE2-A930-FA3841392961@microsoft.com... >I downloaded windows vista threw e-academy, i either had the option of dvd > and cd. Since i dont have a dvd i got the 5 cds. I ran the windows vista > advisor and my computer can support it, except that i should consider > upgrading my video card. My problem is i cant install it. When i boot with > the cd, it freezes on the loading screen (where you can see Microsoft > Corporation and the progress loading bar) and when i run the installation > from windows (XP pro), i get a 0x0 error. Does anyone know why this > happends? > Is it driver related or got it be compability with my laptop? |
| | RE: Installation problems I would recommend upgrading to the latest BIOS version. You should be able to install it afterwards. "Raphael" wrote: > I downloaded windows vista threw e-academy, i either had the option of dvd > and cd. Since i dont have a dvd i got the 5 cds. I ran the windows vista > advisor and my computer can support it, except that i should consider > upgrading my video card. My problem is i cant install it. When i boot with > the cd, it freezes on the loading screen (where you can see Microsoft > Corporation and the progress loading bar) and when i run the installation > from windows (XP pro), i get a 0x0 error. Does anyone know why this happends? > Is it driver related or got it be compability with my laptop? |
| | Re: Installation problems Its a presario 2100, 1 gig or ram, processor is a mobile AMD athlon XP 1800, video card is a ati 128, like i said vista advisor suggest upgrading my video card, 60 gig harddrive. Other than some software installed might not be compatible with vista, nothing else was flaged. Although, since i downloaded vista off e-academy (a website where i can get most of microsoft products, its in association with my university), i downloaded them in .iso format. Is it possible i didnt copy it on cds properly? "Jane C" wrote: > What make and model of laptop? What are the specs of the laptop? How much > RAM, what type of graphics processor etc. Did the Upgrade Advisor flag > anything else as having potential issues? > > -- > Jane, not plain 64 bit enabled :-)> Batteries not included. Braincell on vacation ;-) > "Raphael" <Raphael@discussions.microsoft.com> wrote in message > news:51292817-1BF7-4EE2-A930-FA3841392961@microsoft.com... > >I downloaded windows vista threw e-academy, i either had the option of dvd > > and cd. Since i dont have a dvd i got the 5 cds. I ran the windows vista > > advisor and my computer can support it, except that i should consider > > upgrading my video card. My problem is i cant install it. When i boot with > > the cd, it freezes on the loading screen (where you can see Microsoft > > Corporation and the progress loading bar) and when i run the installation > > from windows (XP pro), i get a 0x0 error. Does anyone know why this > > happends? > > Is it driver related or got it be compability with my laptop? > |
| Installation problems | Vista General | |||
| Installation Problems | Vista print fax & scan | |||
| Installation Problems | Vista installation & setup | |||
