| | Lotus Organizer compatibility problems? I've used Lotus Organizer 2.1 since early 90s. I loaded it on my new computer as part of Lotus SmartSuite release 4. I imported *.or2 files from my old computer and all programs that I tried (123W, Organizer, & Word Pro) seemed to work fine except I was not getting and audible alarm with the alarm dialog box. This morning I got a premature alarm (7:30 am for an 11 am appointment) and when I cleared the alarm and double clicked on the calendar listing the program stopped responding. I closed the program, compacted the file, relaunched the program and clicked the appointment icon and got the same results. I have tried several times with same results. I am able to create tasks, addresses, anniversaries, but time related function cause the program to lockup (not responding). Are others experiencing similar problems? Dale I. Jones |
| | Re: Lotus Organizer compatibility problems? Here's the location of IBM/Lotus' statement about VISTA and Smartsuite: http://www-1.ibm.com/support/docview...id=swg21253536 << -- While no major compatibility issues have been reported when running SmartSuite or Organizer on the Vista 32-bit (x86) version, these applications are not supported by IBM/Lotus Product Development on the Vista platform. -- The 64-bit version Vista does not allow proper functionality because of the legacy computer code within SmartSuite and Organizer. Do NOT install SmartSuite or Organizer on the Vista 64-bit version. >> Do you know about the XPERTSS website? It's run by a bunch of enthusiasts including a number who were on the Lotus L-Team on Compuserve. Check them out at: http://www.xpertss.com/ NOTE the second "S"! ! |
| Need Ebook organizer | Software | |||
| Any known fixes for problems using email with Lotus Domino Web Acc | Vista General | |||
| Compatibility Problems | Vista General | |||
| Clip Organizer Error#0x80040E19 | Vista General | |||
| Re: Lotus Organizer 2.0 | Vista General | |||
