Vista - Problem with screen saver in Vista
Old 02-17-2007   #1 (permalink)
Dorje Samten
I set up a screen saver in Windows Vista, but it never comes on. I can
activate it by previewing, but it never starts on its own.
Old 02-17-2007   #2 (permalink)
Mark
Re: Problem with screen saver in Vista
A background process is active preventing the screen saver to activate.
On 2/17/2007 7:20 PM, Dorje Samten:
Old 02-17-2007   #3 (permalink)
Jane C
Are you using a wireless Microsoft mouse?
Jane, not plain 64 bit enabled :-)
Batteries not included. Braincell on vacation ;-)
"Dorje Samten" <Dorje Samten@discussions.microsoft.com> wrote in message
news:E3795EF1-2737-49DF-B3CB-658E22E6758D@microsoft.com...
Old 02-17-2007   #4 (permalink)
StevenW
Try this:
In taskmanager\processes tab Right-click ehtray.exe, and then click End
Process
Old 02-18-2007   #5 (permalink)
Randor
Hi!
Last June, I installed Vista Beta and bought Microsoft USB wireless Keybord
and Mouse 6000.
The Screen saver and Power options did not work.
Th same problem with Vista RC1.
The same problem with with Vista RC2
The same problem with Vista RTM Ultimate.
But, now, it works . . . at last!
The only thing I installed is this update coming from Windows
updates:
Microsoft - Other Hardware - HID Non-User Input Data Filter
Installation date: 2007-02-05 20:13
Installation status: Successful
Update type: Optional
Microsoft Other Hardware sofware update released in January, 2007
More information:
http://winqual.microsoft.com/support/?driverid=20031770
More information:
http://support.microsoft.com/select/?target=hub
And it works!!!!
Have a nice day!
P.S. At last, I see the beautiful Bubbles screen saver!
PC : ASUS P5N32-Sli Deluxe, 4 GIG, Nvidia 7900GTX
Old 02-18-2007   #6 (permalink)
Robin
"StevenW" wrote:
> Try this:
> Process
Thank you very much. Too bad windows help has nothing to offer put to tell
me how to turn it on which I did at least a dozen times to no avail until I
followed your advice.
Old 03-18-2007   #7 (permalink)
Zipper
Randor,
Thanks for the Windows Update info, I downloaded it and now my screen
saver is working great and I still have my wireless mouse and keyboard going.
"Randor" wrote:
> Hi!
> and Mouse 6000.
> updates:
> More information:
> More information:
> And it works!!!!
> Have a nice day!
Old 03-18-2007   #8 (permalink)
Madhat
I have the same problem, how do you get to the taskmanager\processes Tab??
Thanks
"StevenW" wrote:
> Try this:
> Process
Old 03-22-2007   #9 (permalink)
Braciosaurus
Press Ctrl+Alt+Del
This brings up a menu screen, the last option is "Start Task Manager". Click
on it and then select the tab "Processes".
> Thanks
> "StevenW" wrote:
> > Try this:
> > Process
password protection, log on screen, hibernate & screen saver problem General Discussion
Windows Vista Screen Saver Problem Vista General
Problem with screen saver Vista General
screen saver problem Vista performance & maintenance
Screen saver problem Vista General
