| | Switching between Administrator and Power User accounts I created a new Power User account in Vista. The only other account that exists in Vista is the default Administrator account. After I created the Power User account, I logged out of the Administrator account, logged in to the Power User account and the profile created. I then logged out of the Power User account and back in to the Administrator account. Everything is fine at this point. I decided to try out Vista's Switch User feature. While I was logged in to Vista using the default Administrator account, I clicked on the Windows Orb, clicked on the right arrow and selected Switch User that is on top of the content menu. I logged in to the Power User account. When I switched back to the default Administrator account, the Administrator profile acted like it created a new desktop / profile. The previous shortcuts on the desktop, wallpaper, etc. were back at the default settings. After seeing this unexpected behavior in Vista and worried about loosing my Administrator profile settings, I switched back to the Power User account, log off out of the account, and logged back in to the default Administrator account. When I logged in to the default Administrator account, all my shortcuts and settings returned. I have no idea why at this time why all of my Administrator settings were lost when switching users. I logged off and back in to each account, the Power User and default Administrator account, to verify the accounts were still intact. Now when I switch between these two accounts, all settings retain. Anyone else experience this strange problem. I frequently use multiple profile in Windows, mostly for support and testing scenarios including learning more about the operating system, and never experienced this type of problem in Windows XP. Thanks. Mark, MCP |
| | Re: Switching between Administrator and Power User accounts On Sat, 17 Feb 2007 21:44:07 -0500, Mark <nipperspotREMOVE@gmail-dot-com> spake thusly: >I created a new Power User account in Vista. The only other account >that exists in Vista is the default Administrator account. After I >created the Power User account, I logged out of the Administrator >account, logged in to the Power User account and the profile created. I >then logged out of the Power User account and back in to the >Administrator account. Everything is fine at this point....... I recently read somewhere that MS decided to do away with Power User accounts in Vista. I'm surprised the option is still around. This may (or may not) have something to do with your problem. -- Scott http://angrykeyboarder.com A: Because it messes up the order in which people normally read text. Q: Why is top-posting such a bad thing? |
| | Re: Switching between Administrator and Power User accounts On 2/17/2007 9:57 PM, Scott: > On Sat, 17 Feb 2007 21:44:07 -0500, Mark > <nipperspotREMOVE@gmail-dot-com> spake thusly: > >> I created a new Power User account in Vista. The only other account >> that exists in Vista is the default Administrator account. After I >> created the Power User account, I logged out of the Administrator >> account, logged in to the Power User account and the profile created. I >> then logged out of the Power User account and back in to the >> Administrator account. Everything is fine at this point....... > > I recently read somewhere that MS decided to do away with Power User > accounts in Vista. I'm surprised the option is still around. > > This may (or may not) have something to do with your problem. The Power User may not be available in all Vista version, I have no idea. However, Vista's Help and Support has the Power Users documented and its available. You have to run MMC and add the Local Users and Groups snap-in to set an account to Power Users. The User Accounts in Control Panel only show Administrator and Standard users. |
| | Re: Switching between Administrator and Power User accounts On Sat, 17 Feb 2007 22:07:20 -0500, Mark <nipperspotREMOVE@gmail-dot-com> spake thusly: >On 2/17/2007 9:57 PM, Scott: >> On Sat, 17 Feb 2007 21:44:07 -0500, Mark >> <nipperspotREMOVE@gmail-dot-com> spake thusly: >> >>> I created a new Power User account in Vista. The only other account >>> that exists in Vista is the default Administrator account. After I >>> created the Power User account, I logged out of the Administrator >>> account, logged in to the Power User account and the profile created. I >>> then logged out of the Power User account and back in to the >>> Administrator account. Everything is fine at this point....... >> >> I recently read somewhere that MS decided to do away with Power User >> accounts in Vista. I'm surprised the option is still around. >> >> This may (or may not) have something to do with your problem. > >The Power User may not be available in all Vista version, I have no idea. > >However, Vista's Help and Support has the Power Users documented and its >available. You have to run MMC and add the Local Users and Groups >snap-in to set an account to Power Users. The User Accounts in Control >Panel only show Administrator and Standard users. Yup I just took a look at it. I used to be a Power User myself in XP. -- Scott http://angrykeyboarder.com A: Because it messes up the order in which people normally read text. Q: Why is top-posting such a bad thing? |
| | Re: Switching between Administrator and Power User accounts "Mark" <nipperspotREMOVE@gmail-dot-com> wrote in message news:uKyxDnwUHHA.1212@TK2MSFTNGP03.phx.gbl... > On 2/17/2007 9:57 PM, Scott: >> On Sat, 17 Feb 2007 21:44:07 -0500, Mark >> <nipperspotREMOVE@gmail-dot-com> spake thusly: >> >>> I created a new Power User account in Vista. The only other account >>> that exists in Vista is the default Administrator account. After I >>> created the Power User account, I logged out of the Administrator >>> account, logged in to the Power User account and the profile created. I >>> then logged out of the Power User account and back in to the >>> Administrator account. Everything is fine at this point....... >> >> I recently read somewhere that MS decided to do away with Power User >> accounts in Vista. I'm surprised the option is still around. >> >> This may (or may not) have something to do with your problem. > > The Power User may not be available in all Vista version, I have no idea. > > However, Vista's Help and Support has the Power Users documented and its > available. You have to run MMC and add the Local Users and Groups snap-in > to set an account to Power Users. The User Accounts in Control Panel only > show Administrator and Standard users. > Wow... those sneaky B*st**ds! LOL. And after all that "no more power user" hype! Shame.-Frank |
| | #6 (permalink) |
| | Re: Switching between Administrator and Power User accounts On Sat, 17 Feb 2007 20:26:18 -0700, "Frankster" <Frank@SPAM2TRASH.com> spake thusly: > >"Mark" <nipperspotREMOVE@gmail-dot-com> wrote in message >news:uKyxDnwUHHA.1212@TK2MSFTNGP03.phx.gbl... >> On 2/17/2007 9:57 PM, Scott: >>> On Sat, 17 Feb 2007 21:44:07 -0500, Mark >>> <nipperspotREMOVE@gmail-dot-com> spake thusly: >>> >>>> I created a new Power User account in Vista. The only other account >>>> that exists in Vista is the default Administrator account. After I >>>> created the Power User account, I logged out of the Administrator >>>> account, logged in to the Power User account and the profile created. I >>>> then logged out of the Power User account and back in to the >>>> Administrator account. Everything is fine at this point....... >>> >>> I recently read somewhere that MS decided to do away with Power User >>> accounts in Vista. I'm surprised the option is still around. >>> >>> This may (or may not) have something to do with your problem. >> >> The Power User may not be available in all Vista version, I have no idea. >> >> However, Vista's Help and Support has the Power Users documented and its >> available. You have to run MMC and add the Local Users and Groups snap-in >> to set an account to Power Users. The User Accounts in Control Panel only >> show Administrator and Standard users. >> > >Wow... those sneaky B*st**ds! LOL. And after all that "no more power user" >hype! Shame.Cool. I wasn't the only one who'd read that. -- Scott http://angrykeyboarder.com A: Because it messes up the order in which people normally read text. Q: Why is top-posting such a bad thing? |
| | #7 (permalink) |
| | Re: Switching between Administrator and Power User accounts As a side note, there's no real difference between Power Users and Administrators security-wise. See links below: A member of the Power Users group may be able to gain administrator rights and permissions in Windows Server 2003, Windows 2000, or Windows XP http://support.microsoft.com/kb/825069 The Power in Power Users http://web.archive.org/web/200605111...wer-users.html Proof that LUA makes you safer http://silverstr.ufies.org/blog/archives/000913.html As for me, in the last several years I was running either as standard user (at home) or as an administrator with restricted token (much like UAC behavior in Vista) using RunAsAdmin program which allowed quick and easy elevation: http://sourceforge.net/projects/runasadmin In Vista I'm running as standard user. -- Alexander Suhovey "Mark" <nipperspotREMOVE@gmail-dot-com> wrote in message news:%23AjnEawUHHA.1636@TK2MSFTNGP02.phx.gbl... >I created a new Power User account in Vista. The only other account that >exists in Vista is the default Administrator account. After I created the >Power User account, I logged out of the Administrator account, logged in to >the Power User account and the profile created. I then logged out of the >Power User account and back in to the Administrator account. Everything is >fine at this point. > > I decided to try out Vista's Switch User feature. While I was logged in > to Vista using the default Administrator account, I clicked on the Windows > Orb, clicked on the right arrow and selected Switch User that is on top of > the content menu. I logged in to the Power User account. When I switched > back to the default Administrator account, the Administrator profile acted > like it created a new desktop / profile. The previous shortcuts on the > desktop, wallpaper, etc. were back at the default settings. After seeing > this unexpected behavior in Vista and worried about loosing my > Administrator profile settings, I switched back to the Power User account, > log off out of the account, and logged back in to the default > Administrator account. When I logged in to the default Administrator > account, all my shortcuts and settings returned. > > I have no idea why at this time why all of my Administrator settings were > lost when switching users. > > I logged off and back in to each account, the Power User and default > Administrator account, to verify the accounts were still intact. Now when > I switch between these two accounts, all settings retain. > > Anyone else experience this strange problem. I frequently use multiple > profile in Windows, mostly for support and testing scenarios including > learning more about the operating system, and never experienced this type > of problem in Windows XP. > > > Thanks. > Mark, MCP |
| switching between email user accounts | Vista mail | |||
| User Accounts can't be set to Administrator | Vista account administration | |||
| Administrator/Power User authority | Vista General | |||
| User Accounts - Administrator | Vista General | |||
| Administrator verses User accounts | Vista General | |||
