| | Solution to Vista Sleep Problem I had a problem with my HP desktop going to sleep. I would put it to sleep, and it would immediately wake up. I tried everything suggested, and finally stumbled on a solution (at least it solved the problem on my pc) Go to Control Panel Device Manager Network Adaptors click on the first listed (NVIDIA....) Go to the Power Management tab and uncheck - "Allow device to wake computer" There is even a paragraph on that tab warning that allowing the device to wake your computer may cause it to "wakeup" when you don't want it to!!!!!!!!!!!! This worked for me, hope it works for others having the same problem. |
| | Re: Solution to Vista Sleep Problem On Feb 18, 9:18 am, charla13 <charl...@discussions.microsoft.com> wrote: > I had a problem with my HP desktop going to sleep. I would put it to sleep, > and it would immediately wake up. I tried everything suggested, and finally > stumbled on a solution (at least it solved the problem on my pc) > > Go to Control Panel > Device Manager > Network Adaptors > click on the first listed (NVIDIA....) > > Go to the Power Management tab and uncheck - "Allow device to wake computer" > > There is even a paragraph on that tab warning that allowing the device to > wake your computer may cause it to "wakeup" when you don't want it > to!!!!!!!!!!!! > > This worked for me, hope it works for others having the same problem. Thanks for this post. It solved my problem also. |
| Solution to WMP 11 problem in Vista | General Discussion | |||
| Using Vista x64.... need a solution for my problem | Vista General | |||
| Possible Solution To Vista Problem | Vista installation & setup | |||
| My solution for sleep problems | Vista General | |||
| Sleep & Loss of Internet connection solution | Vista networking & sharing | |||
