Vista - Why no system tray icon for Defender?
Old 02-18-2007   #1 (permalink)
Pipboy
A friend told me in the Vista beta there was an icon in the system tray to
control Windows Defender. I don't have one so where did it go? I want to be
able to temporarily disable defender and start running it again when I want
because I don't want it running in the background when I play computer
games. I looked in the options for Defender and I see nothing that allows
me to do this. WTF? No disable internet connection on the icon Microsoft
puts there, no disable Defender either. Seems to me Vista takes away a lot
of the control I had in XP and is trying to dumb it all down for the noob.
Old 02-18-2007   #2 (permalink)
Richard Urban
Re: Why no system tray icon for Defender?
You have to option it to be on in tools/options.
Regards,
Richard Urban
Quote from George Ankner:
If you knew as much as you think you know,
You would realize that you don't know what you thought you knew!
"Pipboy" <no@email.invalid> wrote in message
news:19lus0vx59osa.10nd4ucfq06lo.dlg@40tude.net...
> be
> want
> lot
Old 02-18-2007   #3 (permalink)
Pipboy
Tou talking about the icon in control panel? I want a quick access icon in
my system tray to disable/enable when I run games. Just as I want a quick
access enable/disable for my internet connection too. When I play resource
hungry offline games I want to not be connected to the internet and I don't
want things like Defender, antivirus etc. running in the background. I
don't want to have to go all the way to control panel to do it every time.
Why was the Defender icon removed if it was in the beta?
Old 02-18-2007   #4 (permalink)
Joe Medford
Click Windows Orb, and type defender. In the defender interface go to
tools, user tools go to options, in options scroll down to "Choose when the
Windows Defender icon appears in the notication" select always. This is
the same as the XP verison.
Defender does not check to see what programs connect to the internet. It
only checks to see what programs are spyware, etc. To close Defender right
click on the icon and click close. To reopen defender Click Windows Orb,
and type defender
Hope that helps
> be
> want
> lot
Old 02-18-2007   #5 (permalink)
Bill Condie
There wasn't one in my XP either. I hd to run it frpm Start if I needed.
I'm on OneCare in Vista where's it's off, because it's part of Vista, in
another form, I guess
> be
> want
> lot
Old 02-19-2007   #6 (permalink)
Pipboy
> and type defender
> Hope that helps
OK, thanks, in XP right now but will check it later.
Old 02-20-2007   #7 (permalink)
Pipboy
> and type defender
> Hope that helps
Ooops, that was where I was all along, which can be accessed via control
panel too, but I didn't notice there was a scroll bar so never saw the
other options. Thanks again.
Old 03-31-2007   #8 (permalink)
Irv
I have done all of that and it still will not appear in the tray.
If I go to Control panel, Security, Windows Defender the icon pops right up
in the tray. I have chosen "Choose when WD appears in the tray" I selected
"Always"
Can anyone help me?
> > be
> > want
> > lot
Windows Defender Icon Not Appearing In System Tray Vista security
Defender - exclamation mark on icon in system tray Vista General
Windows Defender tray icon just popped up w/ exclamation point and cant get rid of it System Security
Defender and system tray icon Vista security
tray icon windows defender Vista security
