| | aero glass ? Need some help. Ok I have read a little about Aero glass and did a search but I can not find the info on it on my PC. What is getting to me is I can not find out if I have it turned on or not. Right now my theme is Vista and I have a PC rating of 3. I have a BNG 6800OC. Right now it is not OC past the system specs. The weird part is that I can not run 1024x768 with 32 bit turned on I can only do it with 16bit turned on. So that is kind of getting to me because I can do 800x600 with 32 bit. I do not know if this might be the issue but I can not see drivers for my NEC 17" CRT monitor. I am not sure if that is why I can not turn on 32 bit since it is just a windows driver. Thanks for any help |
| | Re: aero glass ? Need some help. If its running at 16-bit, you don't have AERO Glass. I would check nVidia's website to see if they have the latest beta 2 drivers for your video card. If you are still experiencing the resolution issue, right click your desktop > click Personalize > click "Display Settings > Advanced Settings..." > under "Adapter" > click "List All Modes..." > select an appropriate Refresh rate running at 1024 by 768, click OK > OK. -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "Neal" <jarrettracing@sbcglobal.net> wrote in message news:4F73F4CA-FA9E-430A-A630-22002A57CD3B@microsoft.com... > Ok I have read a little about Aero glass and did a search but I can not > find the info on it on my PC. What is getting to me is I can not find out > if I have it turned on or not. Right now my theme is Vista and I have a > PC rating of 3. I have a BNG 6800OC. Right now it is not OC past the > system specs. The weird part is that I can not run 1024x768 with 32 bit > turned on I can only do it with 16bit turned on. So that is kind of > getting to me because I can do 800x600 with 32 bit. I do not know if this > might be the issue but I can not see drivers for my NEC 17" CRT monitor. > I am not sure if that is why I can not turn on 32 bit since it is just a > windows driver. > > Thanks for any help |
| | Re: aero glass ? Need some help. Did you update the drivers from Nvidia's site? There not great, but they may improve things. "Neal" <jarrettracing@sbcglobal.net> wrote in message news:4F73F4CA-FA9E-430A-A630-22002A57CD3B@microsoft.com... > Ok I have read a little about Aero glass and did a search but I can not > find the info on it on my PC. What is getting to me is I can not find out > if I have it turned on or not. Right now my theme is Vista and I have a > PC rating of 3. I have a BNG 6800OC. Right now it is not OC past the > system specs. The weird part is that I can not run 1024x768 with 32 bit > turned on I can only do it with 16bit turned on. So that is kind of > getting to me because I can do 800x600 with 32 bit. I do not know if this > might be the issue but I can not see drivers for my NEC 17" CRT monitor. > I am not sure if that is why I can not turn on 32 bit since it is just a > windows driver. > > Thanks for any help |
| | Re: aero glass ? Need some help. Oops! Sorry about the incorrect time. (-: -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) Quote from George Ankner: If you knew as much as you think you know, You would realize that you don't know what you thought you knew! "Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote in message news:%23aYIwOYjGHA.4512@TK2MSFTNGP02.phx.gbl... >I have installed Vista on 4 different computers now. In each case, if the >hardware was capable, glass was automatically "enabled" upon the first >appearance of the desktop. > > -- > Regards, > > Richard Urban > Microsoft MVP Windows Shell/User > (For email, remove the obvious from my address) > > Quote from George Ankner: > If you knew as much as you think you know, > You would realize that you don't know what you thought you knew! > > "Neal" <jarrettracing@sbcglobal.net> wrote in message > news:4F73F4CA-FA9E-430A-A630-22002A57CD3B@microsoft.com... >> Ok I have read a little about Aero glass and did a search but I can not >> find the info on it on my PC. What is getting to me is I can not find >> out if I have it turned on or not. Right now my theme is Vista and I >> have a PC rating of 3. I have a BNG 6800OC. Right now it is not OC past >> the system specs. The weird part is that I can not run 1024x768 with 32 >> bit turned on I can only do it with 16bit turned on. So that is kind of >> getting to me because I can do 800x600 with 32 bit. I do not know if >> this might be the issue but I can not see drivers for my NEC 17" CRT >> monitor. I am not sure if that is why I can not turn on 32 bit since it >> is just a windows driver. >> >> Thanks for any help > > |
| | Re: aero glass ? Need some help. The monitor does not matter. If you have an LDDM driver from nVidia installed you should have Aero Glass. "Neal" <jarrettracing@sbcglobal.net> wrote in message news:4F73F4CA-FA9E-430A-A630-22002A57CD3B@microsoft.com... > Ok I have read a little about Aero glass and did a search but I can not > find the info on it on my PC. What is getting to me is I can not find out > if I have it turned on or not. Right now my theme is Vista and I have a > PC rating of 3. I have a BNG 6800OC. Right now it is not OC past the > system specs. The weird part is that I can not run 1024x768 with 32 bit > turned on I can only do it with 16bit turned on. So that is kind of > getting to me because I can do 800x600 with 32 bit. I do not know if this > might be the issue but I can not see drivers for my NEC 17" CRT monitor. > I am not sure if that is why I can not turn on 32 bit since it is just a > windows driver. > > Thanks for any help |
| | #6 (permalink) |
| | Re: aero glass ? Need some help. I have installed Vista on 4 different computers now. In each case, if the hardware was capable, glass was automatically "enabled" upon the first appearance of the desktop. -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) Quote from George Ankner: If you knew as much as you think you know, You would realize that you don't know what you thought you knew! "Neal" <jarrettracing@sbcglobal.net> wrote in message news:4F73F4CA-FA9E-430A-A630-22002A57CD3B@microsoft.com... > Ok I have read a little about Aero glass and did a search but I can not > find the info on it on my PC. What is getting to me is I can not find out > if I have it turned on or not. Right now my theme is Vista and I have a > PC rating of 3. I have a BNG 6800OC. Right now it is not OC past the > system specs. The weird part is that I can not run 1024x768 with 32 bit > turned on I can only do it with 16bit turned on. So that is kind of > getting to me because I can do 800x600 with 32 bit. I do not know if this > might be the issue but I can not see drivers for my NEC 17" CRT monitor. > I am not sure if that is why I can not turn on 32 bit since it is just a > windows driver. > > Thanks for any help |
| WGA and Aero Glass | Vista General | |||
| How do I get AERO GLASS | Vista music pictures video | |||
| Aero glass | Vista General | |||
| Aero Glass? | Vista General | |||
