| Guest | schtasks changing the default power options Hi All, I am trying to add a new task from scheduler on Vista OS. I am doing this through the command prompt. I am able to add the task but the issue is "Start the task only if the computer is on AC power" option is by default enabled. How can I disable this option from command prompt? Thanks in advance for your suggestions. |
Power Options Corrupt (power plan unavailable) | General Discussion | |||
| Useful tool for power enthusiasts on the go (advanced power options) | General Discussion | |||
| Power Management/Power Options in Vista | Vista General | |||
| Stop Power Options from changing | Vista performance & maintenance | |||
| power options | Vista performance & maintenance | |||
