| Guest | 64 bit Vista business hardware problem I've been using Vista business 64 bit for about 3 weeks now, at first there was the software/hardware problem, but gradually I've worked that out, I un-installed the last two programmes Studio and Roxio and my optical drives are reconised. The two programmes website say it is compatable with Vista, and that maybe so, but it seems to conflict with the drives, has anybody got any ideas about what I maybe doing wrong. All I know is that when I installed the two software and eventually went to bed, when I woke up, I noticed that I had no optical drives and no matter I did, it would not remedy the situation? |
| Guest | Re: 64 bit Vista business hardware problem In article <88CBE370-2C19-4EC7-BAE7-2424C4F9986F@microsoft.com>, agricola36 says... > I've been using Vista business 64 bit for about 3 weeks now, at first there > was the software/hardware problem, but gradually I've worked that out, I > un-installed the last two programmes Studio and Roxio and my optical drives > are reconised. The two programmes website say it is compatable with Vista, > and that maybe so, but it seems to conflict with the drives, has anybody got > any ideas about what I maybe doing wrong. All I know is that when I installed > the two software and eventually went to bed, when I woke up, I noticed that > I had no optical drives and no matter I did, it would not remedy the > situation? > Doesn't Roxio install an ASPI layer? Could be that which is causing problems. Backup your cdrom.sys file, install the software you think is causing the issue then replace the cdrom.sys file with the backup. -- Conor Light travels faster than sound. This is why some people appear bright until you hear them speak......... |
| Guest | Re: 64 bit Vista business hardware problem Some programs install upper and lower filters which cause your problem. If installed, you can edit them from the registry, but make sure you make a copy of the registry keys before you remove the filters. "agricola36" <agricola36@discussions.microsoft.com> wrote in message news:88CBE370-2C19-4EC7-BAE7-2424C4F9986F@microsoft.com... > I've been using Vista business 64 bit for about 3 weeks now, at first > there > was the software/hardware problem, but gradually I've worked that out, I > un-installed the last two programmes Studio and Roxio and my optical > drives > are reconised. The two programmes website say it is compatable with Vista, > and that maybe so, but it seems to conflict with the drives, has anybody > got > any ideas about what I maybe doing wrong. All I know is that when I > installed > the two software and eventually went to bed, when I woke up, I noticed > that > I had no optical drives and no matter I did, it would not remedy the > situation? |
| Re: HOWTO Use Vista Event Log to diagnose hardware problem? | Vista General | |||
| Hardware devices problem in vista home | Vista hardware & devices | |||
| Windows Vista Hardware problem (RTM x64) | Vista hardware & devices | |||
| Problem Installing Vista (Hardware I Think) | Vista hardware & devices | |||
| Problem Installing Vista (Hardware i think) | Vista installation & setup | |||
