| Guest | Memorex USB FlashDrive U3 does not work with Vista The security software loaded in the flash drive cannot be open in Vista. Until I got a software update, all the files in the vault folder are invisible. Bummer. |
| Guest | Re: Memorex USB FlashDrive U3 does not work with Vista My SanDisk Cruzer 4gb stick had U3 software on it...I went to http://www.u3.com/support/default.aspx#CQ3 and used their remove function and reformatted the stick as fat32 and all worked fine after that for me... Greenwing "nofumble" <Davit62@gmail.com> wrote in message news:1172001413.835464.180340@l53g2000cwa.googlegroups.com... > The security software loaded in the flash drive cannot be open in > Vista. Until I got a software update, all the files in the vault > folder are invisible. > > Bummer. > |
| Guest | Re: Memorex USB FlashDrive U3 does not work with Vista nofumble wrote: > The security software loaded in the flash drive cannot be open in > Vista. Until I got a software update, all the files in the vault > folder are invisible. > > Bummer. > Yes. You will have to wait for a compatibilty update. I stopped waiting and removed U3 off of mine. Then I went to portableapps.com got what I needed and loaded TrueCrypt along with it. That allows me to encrypt what I don't want people to see. |
| How to install Vista with only USB Flashdrive? | Vista installation & setup | |||
| Vista SP1: USB port and usb readyboost flashdrive problem. | Vista hardware & devices | |||
| Memorex 20x MRX-530L v1 Internal | Drivers | |||
| Vista on 32GB flashdrive? | Vista installation & setup | |||
| Memorex TravelDrive 4gb not recognized by TWO different Vista Comp | Vista hardware & devices | |||
