| | Serious sleep and hibernation problems My system configurations are: Core2Duo (a little bit overclocked) ASUS P5B (up-to-date BIOS. S3 enabled. On-board LAN enabled) XFX 7600GT (w/ Vista default driver, not installed nVidia's one) MS Ergonomics 4000 keyboard / MS intelli optical mouse (USB) Vista Business 32-bit version. And, my problem is when I try to make my computer into hibernation, Vista does not turn off my computer entirely. After saving data to RAM, my computer just resumes and comes back again. It's also in sleep mode. Whenever I put my computer in sleep state, it never fall into sleep and wakes up immediately. Someone says that turn off the options in LAN card settings. I've tried, but if failed. I also tried to disable my LAN card and pull LAN cable, but it also failed. Furthermore, tweaked BIOS settings, keyboard/mouse driver updates, and so on. All strugglings are in vain. Is there anyone who suffers this problem? Please help me out. Thanks |
| | Re: Serious sleep and hibernation problems "~^_^~" <null.function@gmail.com> wrote in message news:1172091931.631002.11150@v33g2000cwv.googlegroups.com... > My system configurations are: > > Core2Duo (a little bit overclocked) > ASUS P5B (up-to-date BIOS. S3 enabled. On-board LAN enabled) > XFX 7600GT (w/ Vista default driver, not installed nVidia's one) > MS Ergonomics 4000 keyboard / MS intelli optical mouse (USB) > Vista Business 32-bit version. > > And, my problem is when I try to make my computer into hibernation, > Vista does not turn off my computer entirely. After saving data to > RAM, my computer just resumes and comes back again. It's also in sleep > mode. Whenever I put my computer in sleep state, it never fall into > sleep and wakes up immediately. > > Someone says that turn off the options in LAN card settings. I've > tried, but if failed. I also tried to disable my LAN card and pull LAN > cable, but it also failed. Furthermore, tweaked BIOS settings, > keyboard/mouse driver updates, and so on. All strugglings are in vain. > > Is there anyone who suffers this problem? Please help me out. It's very common. Search Google. http://www.google.co.uk/search?hl=en...problems&meta= I think that Asus boards might be particularly bad in this respect. I have a P5W DH Deluxe, and I cannot use Sleep or Hibernate without massive problems. I hope MS can sort this crap out as soon as possible. ss. |
| | Re: Serious sleep and hibernation problems I have P5B-E/NVidia 7800GT and had sleep problems too. Last night, I finally able to make it sleep and resume without problems. Here's what I did: 1. Update to the latest Nvidia 100.65 drivers. 2. Disable VGA Post on resume in BIOS. 3. In the device manager, under USB Root Hub's Power Management tab, enabled 'Allow the computer to turn off this device to save power'. 4. In the NIC's Advanced Option, changed the Wake-On-LAN settings to 'Magic Packet'. My P5B-E has a jumper to supply 5VSB to keyboard when in standby. By default, this is disable so I changed the jumper. "Synapse Syndrome" <synapse@NOSPAMgomez404.elitemail.org> wrote in message news:%23$3cV6fVHHA.4260@TK2MSFTNGP06.phx.gbl... > "~^_^~" <null.function@gmail.com> wrote in message > news:1172091931.631002.11150@v33g2000cwv.googlegroups.com... >> My system configurations are: >> >> Core2Duo (a little bit overclocked) >> ASUS P5B (up-to-date BIOS. S3 enabled. On-board LAN enabled) >> XFX 7600GT (w/ Vista default driver, not installed nVidia's one) >> MS Ergonomics 4000 keyboard / MS intelli optical mouse (USB) >> Vista Business 32-bit version. >> >> And, my problem is when I try to make my computer into hibernation, >> Vista does not turn off my computer entirely. After saving data to >> RAM, my computer just resumes and comes back again. It's also in sleep >> mode. Whenever I put my computer in sleep state, it never fall into >> sleep and wakes up immediately. >> >> Someone says that turn off the options in LAN card settings. I've >> tried, but if failed. I also tried to disable my LAN card and pull LAN >> cable, but it also failed. Furthermore, tweaked BIOS settings, >> keyboard/mouse driver updates, and so on. All strugglings are in vain. >> >> Is there anyone who suffers this problem? Please help me out. > > > It's very common. Search Google. > > http://www.google.co.uk/search?hl=en...problems&meta= > > I think that Asus boards might be particularly bad in this respect. I > have a P5W DH Deluxe, and I cannot use Sleep or Hibernate without massive > problems. > > I hope MS can sort this crap out as soon as possible. > > ss. |
| Odd Sleep/Hibernation | Vista General | |||
| Vista Premium Networking Problems after Sleep, Hibernation 2nd Post | Vista networking & sharing | |||
| Vista Premium Networking Problems after Sleep, Hibernation | Vista networking & sharing | |||
| Auto-sleep and hibernation problems | Vista General | |||
