| | Readyboost with flash drive question I plugged in my 1G flashdrive and the autoplay came up, selected readyboost and the configuration, when I unplug the drive and plug back in, that autoplay came up again, but this time doesn't have the readyboost option, is it normal? |
| | Re: Readyboost with flash drive question If you plugged it back into the same USB port - Then yes, the behavior is normal. <skinnyboywolfie@gmail.com> wrote in message news:1172125570.953496.18260@v45g2000cwv.googlegroups.com... >I plugged in my 1G flashdrive and the autoplay came up, selected > readyboost and the configuration, when I unplug the drive and plug > back in, that autoplay came up again, but this time doesn't have the > readyboost option, is it normal? > |
| U3 Readyboost flash drive problem | Vista General | |||
| Removal of Readyboost Flash Drive | Vista General | |||
| ReadyBoost killed my USB flash drive | Vista hardware & devices | |||
| ReadyBoost Flash Drive Snag | Vista General | |||
| usb flash drive and readyboost | Vista hardware & devices | |||
