| | Major Problems with upgrade to vista Problems: Every time I try to open control panels, explorer crashes - can not access control panels. Every time I try to access the security centre, Rundll32 crashes. The problem is reported, but no solution is given. I can not change any settings because I can not get to them! I can not uninstall programs etc because I can not access Add/remove programs. This is a major fustration and a major disaster with assignments due etc!!! Running Vista business - upgraded from XP Pro. Core 2 duo T6200 Gigabit motherboard nVida Graphics card GeForce 7600 2gb ram |
| | Re: Major Problems with upgrade to vista What errors are you seeing in the event logs? -- Kerry Brown Microsoft MVP - Shell/User http://www.vistahelp.ca "Kevin" <Kevin@discussions.microsoft.com> wrote in message news:16793E32-061F-4397-810A-09E1016D8E8B@microsoft.com... > Problems: > Every time I try to open control panels, explorer crashes - can not access > control panels. > > Every time I try to access the security centre, Rundll32 crashes. The > problem is reported, but no solution is given. > > I can not change any settings because I can not get to them! > > I can not uninstall programs etc because I can not access Add/remove > programs. > > This is a major fustration and a major disaster with assignments due > etc!!! > > Running Vista business - upgraded from XP Pro. > > Core 2 duo T6200 > Gigabit motherboard > nVida Graphics card GeForce 7600 > 2gb ram > |
| Major problems starting Vista | General Discussion | |||
| Major Problems with Laptop (Vista) | General Discussion | |||
| Vista 64: Major problems after hardware upgrade | General Discussion | |||
| Vista SP1 - Major network performance problems | Vista General | |||
| Major problems with vista demo | Vista General | |||
