| | Microphone level indicator fluctuates, but no audio can be heard Have a strange problem in Vista Home Premium that's driving me bonkers, this is on a new install; Have a Sirius Satallite Radio dock hooked up to the mic jack. Levels have all been checked and the level indicator fluctuates as if audio is playing, but I can't hear it. Changing the mic level changes the level on the indicator, and turning off the radio causes the level to drop to zero, so it seems like the input is working. Sound otherwise works fine, from all applications. Have also tried connecting via the line in jack, and the front panel mic jack, same symptoms. Originallyt was using the default Microsoft drivers, so I verified that my drivers were updated (VIA High Definition Audio), no change. Also verified that the mic/line in jack used what set to default, no change. Any ideas what I may be missing? Why does Vista see that an input signal is there, but I can't hear it? By the way, everything works on my other Windows XP box. Thanks!! |
| | RE: Microphone level indicator fluctuates, but no audio can be heard Anyone have any ideas? "Benjamin G" wrote: > Have a strange problem in Vista Home Premium that's driving me bonkers, this > is on a new install; > > Have a Sirius Satallite Radio dock hooked up to the mic jack. Levels have > all been checked and the level indicator fluctuates as if audio is playing, > but I can't hear it. Changing the mic level changes the level on the > indicator, and turning off the radio causes the level to drop to zero, so it > seems like the input is working. Sound otherwise works fine, from all > applications. > > Have also tried connecting via the line in jack, and the front panel mic > jack, same symptoms. Originallyt was using the default Microsoft drivers, so > I verified that my drivers were updated (VIA High Definition Audio), no > change. Also verified that the mic/line in jack used what set to default, no > change. Any ideas what I may be missing? Why does Vista see that an input > signal is there, but I can't hear it? > > By the way, everything works on my other Windows XP box. > > Thanks!! |
| | Re: Microphone level indicator fluctuates, but no audio can be heard On Fri, 2 Mar 2007 19:01:56 -0800, Benjamin G <BenjaminG@discussions.microsoft.com> wrote: >Anyone have any ideas? Have you checked that the microphone isn't muted on your audio control pannel anywhere? If you see movement in levels Windows seems to be internally processing the signal, just that it isn't getting out. As nuts as it sounds I had a similar problem when upgrading. I did a install in place, so all the same hardware and I didn't touch and of my speaker or mic connections. I didn't hear any audio until I started pulling plugs and switching them around. What had worked fine no longer worked till I did. Odd. > >"Benjamin G" wrote: > >> Have a strange problem in Vista Home Premium that's driving me bonkers, this >> is on a new install; >> >> Have a Sirius Satallite Radio dock hooked up to the mic jack. Levels have >> all been checked and the level indicator fluctuates as if audio is playing, >> but I can't hear it. Changing the mic level changes the level on the >> indicator, and turning off the radio causes the level to drop to zero, so it >> seems like the input is working. Sound otherwise works fine, from all >> applications. >> >> Have also tried connecting via the line in jack, and the front panel mic >> jack, same symptoms. Originallyt was using the default Microsoft drivers, so >> I verified that my drivers were updated (VIA High Definition Audio), no >> change. Also verified that the mic/line in jack used what set to default, no >> change. Any ideas what I may be missing? Why does Vista see that an input >> signal is there, but I can't hear it? >> >> By the way, everything works on my other Windows XP box. >> >> Thanks!! |
| | Re: Microphone level indicator fluctuates, but no audio can be heard Sounds somewhat similar to the problem I have using my microphone with Skype in Vista (which doesn't occur on the same system running XP). I have been discussing this microphone low/no volume issue in Vista with a few other posters at a Creative Labs forum. If you'd like to peek into it (where I'm "whozat"), go to: http://forums.creative.com/creativel...cending&page=1 or http://tinyurl.com/2tslrt Benjamin G wrote: > Have a strange problem in Vista Home Premium that's driving me bonkers, this > is on a new install; > > Have a Sirius Satallite Radio dock hooked up to the mic jack. Levels have > all been checked and the level indicator fluctuates as if audio is playing, > but I can't hear it. Changing the mic level changes the level on the > indicator, and turning off the radio causes the level to drop to zero, so it > seems like the input is working. Sound otherwise works fine, from all > applications. > > Have also tried connecting via the line in jack, and the front panel mic > jack, same symptoms. Originallyt was using the default Microsoft drivers, so > I verified that my drivers were updated (VIA High Definition Audio), no > change. Also verified that the mic/line in jack used what set to default, no > change. Any ideas what I may be missing? Why does Vista see that an input > signal is there, but I can't hear it? > > By the way, everything works on my other Windows XP box. > > Thanks!! |
| | Re: Microphone level indicator fluctuates, but no audio can be heard I am experiencing the same problem, no mic volume when using Skype. Vista Business Edition BillP "Daze N. Knights" <Daze@microchip.com> wrote in message news:eM%23BdvVXHHA.1296@TK2MSFTNGP02.phx.gbl... > Sounds somewhat similar to the problem I have using my microphone with > Skype in Vista (which doesn't occur on the same system running XP). I have > been discussing this microphone low/no volume issue in Vista with a few > other posters at a Creative Labs forum. If you'd like to peek into it > (where I'm "whozat"), go to: > > http://forums.creative.com/creativel...cending&page=1 > > > or http://tinyurl.com/2tslrt > > > > > Benjamin G wrote: >> Have a strange problem in Vista Home Premium that's driving me bonkers, >> this is on a new install; >> >> Have a Sirius Satallite Radio dock hooked up to the mic jack. Levels have >> all been checked and the level indicator fluctuates as if audio is >> playing, but I can't hear it. Changing the mic level changes the level on >> the indicator, and turning off the radio causes the level to drop to >> zero, so it seems like the input is working. Sound otherwise works fine, >> from all applications. Have also tried connecting via the line in jack, >> and the front panel mic jack, same symptoms. Originallyt was using the >> default Microsoft drivers, so I verified that my drivers were updated >> (VIA High Definition Audio), no change. Also verified that the mic/line >> in jack used what set to default, no change. Any ideas what I may be >> missing? Why does Vista see that an input signal is there, but I can't >> hear it? >> >> By the way, everything works on my other Windows XP box. >> >> Thanks!! |
| | #6 (permalink) |
| | Re: Microphone level indicator fluctuates, but no audio can be heard I have troubleshooted this issue up and down and all around, and it seems to me at this point to be a bug in Vista. Changing sound cards or drivers or whatever has done nothing to improve the situation for me. The most telling thing is that I have no problem at all with mic volume using Skype while running XP on this very same system. And it is not strictly a Skype issue, either, as I have the same mic problem when using Vista's "Sound Recorder" and others have reported the problem using their mics with other apps. This problem has been reported by posters using different mobos (both Asus and Intel), so it can't have anything to do with the chipset. And it has been reported by posters using different versions of Vista, so it's not specific to a certain version. What I don't understand is why so *few* Vista users seem to be complaining of this mic issue. Apparently, it is only affecting a few of us, yet I fail to see what unusual thing we might have in common in addition to the fact we're running Vista. I keep wondering if Microsoft knows anything about this . . . Bill Pomeroy wrote: > I am experiencing the same problem, no mic volume when using Skype. > Vista Business Edition > BillP > > "Daze N. Knights" <Daze@microchip.com> wrote in message > news:eM%23BdvVXHHA.1296@TK2MSFTNGP02.phx.gbl... >> Sounds somewhat similar to the problem I have using my microphone with >> Skype in Vista (which doesn't occur on the same system running XP). I >> have been discussing this microphone low/no volume issue in Vista with >> a few other posters at a Creative Labs forum. If you'd like to peek >> into it (where I'm "whozat"), go to: >> >> http://forums.creative.com/creativel...cending&page=1 >> >> >> >> or http://tinyurl.com/2tslrt >> >> >> >> >> Benjamin G wrote: >>> Have a strange problem in Vista Home Premium that's driving me >>> bonkers, this is on a new install; >>> >>> Have a Sirius Satallite Radio dock hooked up to the mic jack. Levels >>> have all been checked and the level indicator fluctuates as if audio >>> is playing, but I can't hear it. Changing the mic level changes the >>> level on the indicator, and turning off the radio causes the level to >>> drop to zero, so it seems like the input is working. Sound otherwise >>> works fine, from all applications. Have also tried connecting via the >>> line in jack, and the front panel mic jack, same symptoms. >>> Originallyt was using the default Microsoft drivers, so I verified >>> that my drivers were updated (VIA High Definition Audio), no change. >>> Also verified that the mic/line in jack used what set to default, no >>> change. Any ideas what I may be missing? Why does Vista see that an >>> input signal is there, but I can't hear it? >>> >>> By the way, everything works on my other Windows XP box. >>> >>> Thanks!! > |
| | #7 (permalink) |
| | Re: Microphone level indicator fluctuates, but no audio can be heard On Mar 3, 12:49 pm, "Daze N. Knights" <D...@microchip.com> wrote: > I have troubleshooted this issue up and down and all around, and it > seems to me at this point to be a bug in Vista. Changingsoundcards or > drivers or whatever has done nothing to improve the situation for me. > The most telling thing is that I have no problem at all with mic volume > using Skype while running XP on this very same system. > > And it is not strictly a Skype issue, either, as I have the same mic > problem when using Vista's "SoundRecorder" and others have reported the > problem using their mics with other apps. > > This problem has been reported by posters using different mobos (both > Asus and Intel), so it can't have anything to do with the chipset. And > it has been reported by posters using different versions of Vista, so > it's not specific to a certain version. > > What I don't understand is why so *few* Vista users seem to be > complaining of this mic issue. Apparently, it is only affecting a few of > us, yet I fail to see what unusual thing we might have in common in > addition to the fact we're running Vista. > > I keep wondering if Microsoft knows anything about this . . . > > Bill Pomeroy wrote: > > I am experiencing the same problem, no mic volume when using Skype. > > Vista Business Edition > > BillP > > > "Daze N. Knights" <D...@microchip.com> wrote in message > >news:eM%23BdvVXHHA.1296@TK2MSFTNGP02.phx.gbl... > >> Sounds somewhat similar to the problem I have using my microphone with > >> Skype in Vista (which doesn't occur on the same system running XP). I > >> have been discussing this microphone low/no volume issue in Vista with > >> a few other posters at a Creative Labs forum. If you'd like to peek > >> into it (where I'm "whozat"), go to: > > >>http://forums.creative.com/creativel...oard.id=Vista&... > > >> orhttp://tinyurl.com/2tslrt > > >> Benjamin G wrote: > >>> Have a strange problem in Vista Home Premium that's driving me > >>> bonkers, this is on a new install; > > >>> Have a Sirius Satallite Radio dock hooked up to the mic jack. Levels > >>> have all been checked and the level indicator fluctuates as if audio > >>> is playing, but I can't hear it. Changing the mic level changes the > >>> level on the indicator, and turning off the radio causes the level to > >>> drop to zero, so it seems like the input is working.Soundotherwise > >>> works fine, from all applications. Have also tried connecting via the > >>>line injack, and the front panel mic jack, same symptoms. > >>> Originallyt was using the default Microsoft drivers, so I verified > >>> that my drivers were updated (VIA High Definition Audio), no change. > >>> Also verified that the mic/line injack used what set to default, no > >>> change. Any ideas what I may be missing? Why does Vista see that an > >>> input signal is there, but I can't hear it? > > >>> By the way, everything works on my other Windows XP box. > > >>> Thanks!! I'm having issues with all sound input devices. I first tried to plug my minidisc player into the line-in port so I could listen to my tunes. This didn't work, so I tried plugging into the rear microphone, same problem, then the front mic jack. At least the monitor registered a volume level, however still no sound. I tested my connection cable, so I know it isn't the problem. Any ideas? |
| | #8 (permalink) |
| | Re: Microphone level indicator fluctuates, but no audio can be heard A lady I know uses Skype on a laptop with Vista Home Premium and when she calls me with it, it sounds like she is screeching. I have tried adjusting her microphone levels but it seems like Vista has a mind of its own and sets it to whatever it wants. I have ticked off the "do not adjust levels in Skype and that did not work either. I have not found a solution yet. The only application using the microphone is Skype so I find it strange that the microphone gets adjusted by some other program. Al On 19 Mar 2007 09:04:59 -0700, sciba.yca@gmail.com wrote: >On Mar 3, 12:49 pm, "Daze N. Knights" <D...@microchip.com> wrote: >> I have troubleshooted this issue up and down and all around, and it >> seems to me at this point to be a bug in Vista. Changingsoundcards or >> drivers or whatever has done nothing to improve the situation for me. >> The most telling thing is that I have no problem at all with mic volume >> using Skype while running XP on this very same system. >> >> And it is not strictly a Skype issue, either, as I have the same mic >> problem when using Vista's "SoundRecorder" and others have reported the >> problem using their mics with other apps. >> >> This problem has been reported by posters using different mobos (both >> Asus and Intel), so it can't have anything to do with the chipset. And >> it has been reported by posters using different versions of Vista, so >> it's not specific to a certain version. >> >> What I don't understand is why so *few* Vista users seem to be >> complaining of this mic issue. Apparently, it is only affecting a few of >> us, yet I fail to see what unusual thing we might have in common in >> addition to the fact we're running Vista. >> >> I keep wondering if Microsoft knows anything about this . . . >> >> Bill Pomeroy wrote: >> > I am experiencing the same problem, no mic volume when using Skype. >> > Vista Business Edition >> > BillP >> >> > "Daze N. Knights" <D...@microchip.com> wrote in message >> >news:eM%23BdvVXHHA.1296@TK2MSFTNGP02.phx.gbl... >> >> Sounds somewhat similar to the problem I have using my microphone with >> >> Skype in Vista (which doesn't occur on the same system running XP). I >> >> have been discussing this microphone low/no volume issue in Vista with >> >> a few other posters at a Creative Labs forum. If you'd like to peek >> >> into it (where I'm "whozat"), go to: >> >> >>http://forums.creative.com/creativel...oard.id=Vista&... >> >> >> orhttp://tinyurl.com/2tslrt >> >> >> Benjamin G wrote: >> >>> Have a strange problem in Vista Home Premium that's driving me >> >>> bonkers, this is on a new install; >> >> >>> Have a Sirius Satallite Radio dock hooked up to the mic jack. Levels >> >>> have all been checked and the level indicator fluctuates as if audio >> >>> is playing, but I can't hear it. Changing the mic level changes the >> >>> level on the indicator, and turning off the radio causes the level to >> >>> drop to zero, so it seems like the input is working.Soundotherwise >> >>> works fine, from all applications. Have also tried connecting via the >> >>>line injack, and the front panel mic jack, same symptoms. >> >>> Originallyt was using the default Microsoft drivers, so I verified >> >>> that my drivers were updated (VIA High Definition Audio), no change. >> >>> Also verified that the mic/line injack used what set to default, no >> >>> change. Any ideas what I may be missing? Why does Vista see that an >> >>> input signal is there, but I can't hear it? >> >> >>> By the way, everything works on my other Windows XP box. >> >> >>> Thanks!! > >I'm having issues with all sound input devices. I first tried to plug >my minidisc player into the line-in port so I could listen to my >tunes. This didn't work, so I tried plugging into the rear >microphone, same problem, then the front mic jack. At least the >monitor registered a volume level, however still no sound. I tested >my connection cable, so I know it isn't the problem. > >Any ideas? |
| Microphone not working, able to hear all sound but not be heard. | Sound & Audio | |||
| Audio Not Heard In Web Browser(s) | Sound & Audio | |||
| Re: Decrease input level of a USB connected microphone | Vista General | |||
| Microphone playback volume level | Vista hardware & devices | |||
| battery level indicator/icon in navigation bar | Vista performance & maintenance | |||
