| | Easy Transfer Question---need help please? I have copied the files I wish to transfer, but I just want to know if there is any precaution I should take like a type of back up or recovery I should do on laptop, before I try to add the files onto it? I just don't want to create problems for myself given the problems I have heard ppl are having with Vista. Just want to be careful with what I want to do, until all the bugs have bee worked out in Vista, given that this is a new Laptop and a New OS. Thanks |
| | Re: Easy Transfer Question---need help please? If you truly want to be safe then back up your laptop so you have an image of it should you need to revert. Easy Transfer moves your data, OS settings and App settings so your machine should be good to go. "Boots911" <Boots911@discussions.microsoft.com> wrote in message news:2F1CC56D-BF10-414E-B982-EDBF58EB0598@microsoft.com... >I have copied the files I wish to transfer, but I just want to know if >there > is any precaution I should take like a type of back up or recovery I > should do on laptop, before I try to add the files onto it? I just don't > want to create problems for myself given the problems I have heard ppl are > having with Vista. Just want to be careful with what I want to do, until > all > the bugs have bee worked out in Vista, given that this is a new Laptop and > a > New OS. > > Thanks |
| Windows Easy Transfer Question 2 | Vista General | |||
| Easy Transfer - Easy Transfer error messages - creating accounts | Vista General | |||
| Windows Easy Transfer, XP to Vista, and Belkin's transfer cable | Vista installation & setup | |||
| 5384: Easy Transfer not transfering easy... | Vista installation & setup | |||
| Easy Transfer Question | Vista General | |||
