| | System Mechanic I have Vista Business 64bit - full version not an upgrade. Iolo have brought out a new version of SystemMechanic for Vista. I can download it - but the installation process then checks for updates - and just hangs. I can use the rest of the machine but cannot get rid of the installer without rebooting. Has anyone successfully installed it? |
| | Re: System Mechanic Hi, Have you brought this issue up with Iola yet? Are you running setup as administrator? -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org "mike" <me@privacy.net> wrote in message news:m7u2u2htrcmbdbhpvjivjhfq766jg3mq7s@4ax.com... >I have Vista Business 64bit - full version not an upgrade. > > Iolo have brought out a new version of SystemMechanic for Vista. > > I can download it - but the installation process then checks for > updates - and just hangs. I can use the rest of the machine but > cannot get rid of the installer without rebooting. > > Has anyone successfully installed it? |
| | Re: System Mechanic On Sun, 25 Feb 2007 07:50:01 -0500, "Rick Rogers" <rick@mvps.org> wrote: >Hi, > >Have you brought this issue up with Iola yet? >Are you running setup as administrator? No - I will do - but I thought I'd ask if anyone else had issues. Yes. |
| | Re: System Mechanic Mike... I also have the same problem with System Mechanic Pro 7....plz post back here if you get a reply from Iolo....I find them very uncommunicative ![]() Tony A "mike" wrote: > On Sun, 25 Feb 2007 07:50:01 -0500, "Rick Rogers" <rick@mvps.org> > wrote: > > >Hi, > > > >Have you brought this issue up with Iola yet? > >Are you running setup as administrator? > > > No - I will do - but I thought I'd ask if anyone else had issues. > > Yes. > |
| | Re: System Mechanic Mike, System Mechanic does not work with x 64 bit vista full stop...............It doesn't even work with the 32 bit version (even though it says that it does) Iolo have ripped of thousands of people making them believe that thier product works with Vista when in fact it doesn't. Go here to read the problems associated with Iolo products and Vista http://www.techguy.org/ Type in system Mechanic Read the article from the Lawyer and her pursuit to stop people being ripped off by Iolo. Don't even bother hounding Iolo for an answer or your money back....... You wont get it. They don't answer e mails, they send out auto replies generated from a database of stock answers. Phone support is nil, the line is always locked in a never ending loop of callers waiting in a queue. So don't bother holding on for an answer because it will end up giving you a bigger bill and headache to boot. If you get any answers from them please post the outcome Cheers! "mike" <me@privacy.net> wrote in message news:dkh3u2d1ce8pb3d3lo0g0qmh4nf4ck0old@4ax.com... > On Sun, 25 Feb 2007 07:50:01 -0500, "Rick Rogers" <rick@mvps.org> > wrote: > >>Hi, >> >>Have you brought this issue up with Iola yet? >>Are you running setup as administrator? > > > No - I will do - but I thought I'd ask if anyone else had issues. > > Yes. |
| | #6 (permalink) |
| | Re: System Mechanic Even MS list System Mechanic as being compatible check this list http://support.microsoft.com/default.aspx/kb/933305 T5 "T5" <noanswer@hotmail.com> wrote in message news:696F9298-6661-462A-898D-F5A0888109E7@microsoft.com... > Mike, > > System Mechanic does not work with x 64 bit vista full > stop...............It > doesn't even work with the 32 bit version (even though it says that it > does) > Iolo have ripped of thousands of people making them believe that thier > product works with Vista when in fact it doesn't. > > Go here to read the problems associated with Iolo products and Vista > http://www.techguy.org/ > > Type in system Mechanic > > Read the article from the Lawyer and her pursuit to stop people being > ripped > off by Iolo. > > Don't even bother hounding Iolo for an answer or your money back....... > You > wont get it. They don't answer e mails, they send out auto replies > generated > from a database of stock answers. Phone support is nil, the line is always > locked in a never ending loop of callers waiting in a queue. So don't > bother > holding on for an answer because it will end up giving you a bigger bill > and > headache to boot. > > If you get any answers from them please post the outcome > > Cheers! > > "mike" <me@privacy.net> wrote in message > news:dkh3u2d1ce8pb3d3lo0g0qmh4nf4ck0old@4ax.com... >> On Sun, 25 Feb 2007 07:50:01 -0500, "Rick Rogers" <rick@mvps.org> >> wrote: >> >>>Hi, >>> >>>Have you brought this issue up with Iola yet? >>>Are you running setup as administrator? >> >> >> No - I will do - but I thought I'd ask if anyone else had issues. >> >> Yes. > |
| System Mechanic!!!!!!!! Works!!!!! | Vista General | |||
| System Mechanic 6 | Vista General | |||
| System Mechanic | Software | |||
| Re: Vista 64bit and System Mechanic | Vista General | |||
| System Mechanic 7.0 Pro incompatible | Vista General | |||
