Vista - Vista was running sweet, not so anymore (two weeks after install)
Old 02-25-2007   #1 (permalink)
craigconfire
Everything was running great with vista ultimate (clean install) until two
days ago. Two days ago I have my computer running meanwhile I decide to play
xbox360. I notice the computer sees the 360 and prompts me to install Media
Center (Media Extender). I did, even though it took for ever to install.
And, now vista is slow to boot (5mins vs 10secs before), IE7 takes forever to
load, basically everything is bogged down now.
How do I use system restore? Better yet will that even work. I could care
less about the 360 and pc seeing each other. I'd rather have my fast machine
back.
Old 02-25-2007   #2 (permalink)
gls858
Re: Vista was running sweet, not so anymore (two weeks after install)
> back.
Click on the Start button and in the search box type restore.
Select system restore and follow the prompts
gls858
Old 03-01-2007   #3 (permalink)
D Caufield
Vista running slow
I had a problem with Vista making my IE7 run slow. Turns out it was the Phishing Filter on McAfee. It was interfering with the phising filter on windows. I turned off the one on McAfee and now everything is speedy.
EggHeadCafe.com - .NET Developer Portal of Choice
http://www.eggheadcafe.com
SP2 Vista 64-Bit Won’t Install Anymore Windows Updates
uninstalling a sweet tooth in IE Windows Live
Can't install McAfee 8.7 or 8.5 anymore Vista General
Went from PERFECT Install & Use to HELL in last 2 weeks Vista General
Vista was running sweet, not so anymore (two weeks after install) Vista installation & setup
