| | 32bit > 64bit I have installed Vista Beta 2 32bit x86 on a spare partition and am successfully duel booting with my normal XP... I am running an Athlon64 3200+ with 2gig of RAM... so I was wondering if there would be any benefit in installing the 64bit x64 ? (I am currently downloading the 64bit just in case and am aware that to install the 64bit you need to boot from the DVD) Could I upgrade the 32bit or would a Format and clean install of the 64bit be better in the long term? -- HTH - Any Advice Appreciated - Please Reply To Newsgroup Only jel183(UK) |
| | Re: 32bit > 64bit You would have to do a clean install of the x64 Vista. -- Jane, not plain 64bit enabled ![]() Batteries not included. Braincell on vacation ![]() "jel183(UK)" <nospam@myhome.com> wrote in message news:eOx2m3fjGHA.4044@TK2MSFTNGP03.phx.gbl... >I have installed Vista Beta 2 32bit x86 on a spare partition and am >successfully duel booting with my normal XP... I am running an Athlon64 >3200+ with 2gig of RAM... so I was wondering if there would be any benefit >in installing the 64bit x64 ? (I am currently downloading the 64bit just in >case and am aware that to install the 64bit you need to boot from the DVD) > > Could I upgrade the 32bit or would a Format and clean install of the 64bit > be better in the long term? > > -- > HTH - Any Advice Appreciated - Please Reply To Newsgroup Only > > jel183(UK) > |
| | Re: 32bit > 64bit Thanks -- HTH - Any Advice Appreciated - Please Reply To Newsgroup Only jel183(UK) "Jane C" <jellybean@NOSPAMxjgarage.org> wrote in message news:95CF4CE9-7E62-4C52-82E7-41A1BB6B4EDB@microsoft.com... > You would have to do a clean install of the x64 Vista. > > -- > Jane, not plain 64bit enabled ![]() > Batteries not included. Braincell on vacation ![]() > "jel183(UK)" <nospam@myhome.com> wrote in message > news:eOx2m3fjGHA.4044@TK2MSFTNGP03.phx.gbl... >>I have installed Vista Beta 2 32bit x86 on a spare partition and am >>successfully duel booting with my normal XP... I am running an Athlon64 >>3200+ with 2gig of RAM... so I was wondering if there would be any benefit >>in installing the 64bit x64 ? (I am currently downloading the 64bit just >>in case and am aware that to install the 64bit you need to boot from the >>DVD) >> >> Could I upgrade the 32bit or would a Format and clean install of the >> 64bit be better in the long term? >> >> -- >> HTH - Any Advice Appreciated - Please Reply To Newsgroup Only >> >> jel183(UK) >> > |
| I have dual boot PC [VISTA 32BIT & 64BIT]---problems only in 64bit vista drivers | Drivers | |||
| In a 64bit PC may make 4 partitions vista 32bit, vista 64bit, and ... | Virtual PC | |||
| 64bit PC MACHINE, X86 WINDOWS,CAN I have 32bit & 64bit vista partitions | General Discussion | |||
| 32bit vs 64bit | Vista General | |||
| switching from 64bit to 32bit now then back to 64bit later | Vista installation & setup | |||
