| | Changing the way of changing the colorscheme I have Windows Vista and have a question about the way of changing the colorscheme. You can change the colorscheme of Vista and the color intensity in the settings screen. You can also choose for using the 'classic' colorscheme changer (so you can choose for the Vista standard, Vista basic, Windows classic etc. schemes). I clicked on that, so everytime I want to change the colorscheme of Vista the classical colorscheme editor opens. Is there a way back to the 'Vista' colorscheme editor? Thanks! |
| | Re: Changing the way of changing the colorscheme "Tipsko" <Tipsko@discussions.microsoft.com> wrote in message news:85789E10-7D92-4492-B35E-C8B88609566C@microsoft.com... >I have Windows Vista and have a question about the way of changing the > colorscheme. > > You can change the colorscheme of Vista and the color intensity in the > settings screen. You can also choose for using the 'classic' colorscheme > changer (so you can choose for the Vista standard, Vista basic, Windows > classic etc. schemes). I clicked on that, so everytime I want to change > the > colorscheme of Vista the classical colorscheme editor opens. Is there a > way > back to the 'Vista' colorscheme editor? The newer one only appears if your color scheme is Windows Aero. Make the change back to Windows Aero and apply that, then prelaunch Windows Color and Appearance and you should once again see the color changer for Vista Aero. -- Tom Porterfield |
| Changing 64 bit to 32 bit? | Windows Updates | |||
| Changing Ip | Network & Sharing | |||
| Changing the CPU | Vista General | |||
| media changing delays when changing tracks | Vista music pictures video | |||
| Changing RAM | Vista installation & setup | |||
