Vista Tutorial - Power Button will not shut down
Old 02-28-2007   #1 (permalink)
Malcolm H
Guest
When I try to shut down with the Vista Power Button it will only select
sleep. In 'System Settings' the Power Button is selected to 'Shut Down'.
Whatever action is selected in System Settings the Power Button it will only
select Sleep.
If Shut Down is selected from options menu (Start/Little Right Arrow) then
Shut Down is successful.
What has happened and how do I correct it??
Malcolm H
Old 02-28-2007   #2 (permalink)
woody
Guest
Re: Power Button will not shut down
In this instance, the power button refered to is the main power button on
your computer.
Woody
"Malcolm H" <mph@nospam.com> wrote in message
news:PhdFh.38170$wP3.10240@newsfe7-gui.ntli.net...
> only select Sleep.
> Malcolm H
Old 02-28-2007   #3 (permalink)
Malcolm H
Guest
"woody" <woody@woohoo.ca> wrote in message
news:%23kVZAkyWHHA.3972@TK2MSFTNGP03.phx.gbl...
> your computer.
> Woody
No, I am referring to the Vista on-screen Power Button. It used to shut down
immediately (up to yesterday!) but suddenly it refuses to shut down and will
only put the machine to sleep! The System Settings call for it to Shut Down.
Old 02-28-2007   #4 (permalink)
Beck
Guest
"Malcolm H" <malcolmh@nospam.com> wrote in message
news:%23k74GsyWHHA.1636@TK2MSFTNGP02.phx.gbl...
>> your computer.
>> Woody
> down immediately (up to yesterday!) but suddenly it refuses to shut down
> and will only put the machine to sleep! The System Settings call for it to
> Shut Down.
Have you tried changing the setting to something else, say restart and using
that once then chnaging it back again?
Old 02-28-2007   #5 (permalink)
Joshua Eason
Guest
I believe the system settings option for changing how the power button
reacts is actually referring to the power button on the machine and not the
on-screen power button. Personally, my Vista install has always went into
hibernate when pressing the stupid on-screen power button and I really,
really hate that.
Josh
"Beck" <beck@none> wrote in message
news:e5074CzWHHA.4872@TK2MSFTNGP03.phx.gbl...
>>> on your computer.
>>> Woody
>> to Shut Down.
> using that once then chnaging it back again?
Old 02-28-2007   #6 (permalink)
Malcolm H
Guest
>>> on your computer.
>>> Woody
>> to Shut Down.
Just tried, didn't work!
Old 03-01-2007   #7 (permalink)
Dave R.
Guest
"Joshua Eason" <jeason@ccboe.org> wrote in message
news:%23N8F8j0WHHA.3592@TK2MSFTNGP03.phx.gbl...
>the on-screen power button. Personally, my Vista install has always
>went into hibernate when pressing the stupid on-screen power button and
>I really, really hate that.
To change the behavior of the Start Menu Power Button, go to Control
Panel - System and Maintenance - Power Options - Change Plan Settings
(for whichever power plan you are using) - Change Advanced Power
Settings - Power Buttons and Lid - Start Menu Power Button - Setting:
Shut Down.
Works fine for me, but of course YMMV.
Regards,
Dave
Old 03-01-2007   #8 (permalink)
Malcolm H
Guest
"Dave R." <dwragle at drbsystems dot com> wrote in message
news:45e6ed88$0$97261$892e7fe2@authen.yellow.readfreenews.net...
>>the on-screen power button. Personally, my Vista install has always went
>>into hibernate when pressing the stupid on-screen power button and I
> Panel - System and Maintenance - Power Options - Change Plan Settings (for
> whichever power plan you are using) - Change Advanced Power Settings -
> Power Buttons and Lid - Start Menu Power Button - Setting: Shut Down.
> Regards,
> Dave
Fantastic Dave, it works for me too! But how obscure was that!!!
Thank you again, I knew there had to be an answer.
Malcolm
Old 03-01-2007   #9 (permalink)
Daze N. Knights
Guest
Something I don't understand about changing the functions of these
"buttons" is that three are listed: "Power button action," "Sleep button
action," and "Start menu power button." I know where the "Start menu
power button" is located and have changed it from Sleep to Shut Down.
But where are the other two buttons located?
> Shut Down.
> Regards,
> Dave
Old 03-01-2007   #10 (permalink)
Dave R.
Guest
news:6aDFh.32374$s47.1665@newsfe4-gui.ntli.net...
>>>button reacts is actually referring to the power button on the
>>>machine and not the on-screen power button. Personally, my Vista
>>>install has always went into hibernate when pressing the stupid
>>>on-screen power button and I really, really hate that.
>> Shut Down.
Glad to help. I agree, this trend MS has of burying settings deeper and
deeper in the UI id annoying. Seems like they've come to the conclusion
that users can only handle a couple of options per screen so the screens
get more simple but there are way more of them piled deeper and
deeper...
Regards,
Dave
Dell- blinking power button- vista power mgmt? General Discussion
Vista power settings - power button functionality Vista installation & setup
No shut down options or power off button Vista General
Shut Down button refuses to be configured to SHUT DOWN !! Vista General
disable lock button beside power button? Vista General
