| Guest | HELP with Sleep Mode Hi Group: I'm new to the discussion Forum; My Name is Tom and I've resently purchased a New HP Desktop with Vista Home Premium Installed and everything is working great with the exception to the Sleep mode. I did a search and none of th answers is close to what my PC is doing: When I place the computer to sleep mode or ,the computer does it after (1) hour, my PC will come back with a Black Screen and i can hear it running. Also, I have to Control Alt Delete to bring it back from Sleep mode. Its driving me crazy! I've checked the Devise Manager for USPB conflicts and turned off the Weather Gaget off. Any suggestions??? Something so simple has turned into a real nightmare for me! Thanks Tom |
| Guest | Resume Fix??? Resume FIX ??? I'm on my XP IE7 PC cause my Vista PC wouldn't resume and I'm not satisfied with Rhapsody playback This XP PC wouldn't resume either til I disabled jusched Start +R > msconfig > Startup > uncheck jusched Resumes fine now! Google says jusched calls up a Java Update Lookup which obviously is not working right.. Why would I want to check for updates to Java every time Windows resumes anyway??? I have the same jre-6-windows-i586.exe on both machines so I'm hopeful this fix will also work on my Vista PC when I go back to it. Let me know if this helps. Thanks Art |
| Guest | RE: Resume Fix??? I'll try when I get on the Vista PC; it just drives me crazy. Thanks Art for your suggestion and I'll let you know. Tom "art76" wrote: > Resume FIX ??? > I'm on my XP IE7 PC cause my Vista PC wouldn't resume and I'm not satisfied > with Rhapsody playback > This XP PC wouldn't resume either til I disabled jusched > Start +R > msconfig > Startup > uncheck jusched > Resumes fine now! > > Google says jusched calls up a Java Update Lookup which obviously is not > working right.. > Why would I want to check for updates to Java every time Windows resumes > anyway??? > > I have the same jre-6-windows-i586.exe on both machines so I'm hopeful this > fix will also work on my Vista PC when I go back to it. > Let me know if this helps. > Thanks Art > |
| Guest | RE: Resume Fix??? NOPE; the jusched is not on the start up; any other suggestions? Just getting back to this discussion group is hard! "Thomas Kent" wrote: > I'll try when I get on the Vista PC; it just drives me crazy. Thanks Art for > your suggestion and I'll let you know. Tom > > "art76" wrote: > > > Resume FIX ??? > > I'm on my XP IE7 PC cause my Vista PC wouldn't resume and I'm not satisfied > > with Rhapsody playback > > This XP PC wouldn't resume either til I disabled jusched > > Start +R > msconfig > Startup > uncheck jusched > > Resumes fine now! > > > > Google says jusched calls up a Java Update Lookup which obviously is not > > working right.. > > Why would I want to check for updates to Java every time Windows resumes > > anyway??? > > > > I have the same jre-6-windows-i586.exe on both machines so I'm hopeful this > > fix will also work on my Vista PC when I go back to it. > > Let me know if this helps. > > Thanks Art > > |
| Guest | Re: HELP with Sleep Mode I had the same problem. Reloaded the pc, updated the video drivers, critical updates, etc... then I formatted the hard drive and loaded from scratch. Save yourself some trouble. The Nvidia 7900 gs Video card was bad. Dell replaced the card and it is running fine now. -- ohgail Posted via http://www.vistaheads.com |
| All the new modes like the Sleep Mode and Hibernate Mode | Vista performance & maintenance | |||
| Sleep Mode - disconnected, automatically reconnected after sleep m | Vista networking & sharing | |||
| No sleep mode/hibernate mode; no screen saver | Vista performance & maintenance | |||
| Hibernate mode turns to sleep mode after a few hours | Vista General | |||
| Sleep Mode and Hibernation Mode | Vista General | |||
