| Guest | System Restore Points in a dual boot enviroment Is it possible to change the path where the System Volume Information is stored? I would like to be able to store the SVI files on an external hard drive. One could then load the drive after you boot to Vista. Restore points could be created while you are in Vista,then unload the drive before booting to XP. |
| Guest | Re: System Restore Points in a dual boot enviroment System Restore points must remain on the same partition that Windows Vista is installed on. -- Carey Frisch Microsoft MVP Windows - Shell/User -------------------------------------------------------------------------------- "Kue2"wrote: Is it possible to change the path where the System Volume Information is stored? I would like to be able to store the SVI files on an external hard drive. One could then load the drive after you boot to Vista. Restore points could be created while you are in Vista,then unload the drive before booting to XP. |
| System Restore Points - Stop XP Dual Boot Delete | Tutorials | |||
| Dual Boot Vista - XP backup restore losing restore points | Vista General | |||
| dual boot xp and restore points in vista | Vista General | |||
| Dual boot and Vista restore points | Vista General | |||
| Dual Booting and Creating System Restore Points | Vista hardware & devices | |||
