| Guest | Vista wireless/Internet problems I'm having problems with my wireless adaptor and Vista on my desktop PC. It must be a local problem to this machine since my laptop (in the same room but running XP) works fine - both using wireless connections. I have two problems. 1. Often when I boot my desktop PC I only get "local" access - rather than "local and Internet" access. I have to fiddle around to eventually get Internet access (usually by disconnecting and reconnecting my adaptor, sometimes by "repairing" it - using Vista). 2. Sometimes when I connect, the connection is very slow. I suspect this is the wireless part of my connection rather than the Internet part. What could be the problem? Is Vista wireless support OK? I have an old (PCI) wireless adaptor from Belkin (about 2-3 years old). Could it be my wireless adaptor? If I need to get a more up-to-date adaptor, can anyone recommend an inexpensive one that works well with Vista? Cheers. Bobby |
| Guest | Re: Vista wireless/Internet problems I have a Linksys router and if Vista can't see the internet hitting the reset button usually fixes the problem. "Bobby" <bobby@europe.com> wrote in message news:OcUyrdlXHHA.3268@TK2MSFTNGP04.phx.gbl... > I'm having problems with my wireless adaptor and Vista on my desktop PC. > > It must be a local problem to this machine since my laptop (in the same > room but running XP) works fine - both using wireless connections. > > I have two problems. > > 1. Often when I boot my desktop PC I only get "local" access - rather than > "local and Internet" access. I have to fiddle around to eventually get > Internet access (usually by disconnecting and reconnecting my adaptor, > sometimes by "repairing" it - using Vista). > > 2. Sometimes when I connect, the connection is very slow. I suspect this > is the wireless part of my connection rather than the Internet part. > > What could be the problem? Is Vista wireless support OK? I have an old > (PCI) wireless adaptor from Belkin (about 2-3 years old). Could it be my > wireless adaptor? > > If I need to get a more up-to-date adaptor, can anyone recommend an > inexpensive one that works well with Vista? > > Cheers. > > Bobby |
| Guest | Re: Vista wireless/Internet problems On 4 Mar, 13:19, "Bobby" <b...@europe.com> wrote: > I'm having problems with my wireless adaptor and Vista on my desktop PC. > > It must be a local problem to this machine since my laptop (in the same room > but running XP) works fine - both using wireless connections. > > I have two problems. > > 1. Often when I boot my desktop PC I only get "local" access - rather than > "local and Internet" access. I have to fiddle around to eventually get > Internet access (usually by disconnecting and reconnecting my adaptor, > sometimes by "repairing" it - using Vista). > > 2. Sometimes when I connect, the connection is very slow. I suspect this is > the wireless part of my connection rather than the Internet part. > > What could be the problem? Is Vista wireless support OK? I have an old (PCI) > wireless adaptor from Belkin (about 2-3 years old). Could it be my wireless > adaptor? > > If I need to get a more up-to-date adaptor, can anyone recommend an > inexpensive one that works well with Vista? > > Cheers. > > Bobby Having the same trouble with a Belkin MIMO router and wireless USB device. Driving me crazy - only just bought the router before upgrading to Vista... |
| Guest | Re: Vista wireless/Internet problems On 4 Mar, 13:19, "Bobby" <b...@europe.com> wrote: > I'm having problems with mywirelessadaptor andVistaon my desktop PC. > > It must be a local problem to this machine since my laptop (in the same room > but running XP) works fine - both usingwirelessconnections. > > I have two problems. > > 1. Often when I boot my desktop PC I only get "local" access - rather than > "local and Internet" access. I have to fiddle around to eventually get > Internet access (usually by disconnecting and reconnecting my adaptor, > sometimes by "repairing" it - usingVista). > > 2. Sometimes when I connect, the connection is veryslow. I suspect this is > thewirelesspart of my connection rather than the Internet part. > > What could be the problem? IsVistawirelesssupport OK? I have an old (PCI)wirelessadaptor fromBelkin(about 2-3 years old). Could it be mywireless > adaptor? > > If I need to get a more up-to-date adaptor, can anyone recommend an > inexpensive one that works well withVista? > > Cheers. > > Bobby Found the answer! I think. Solved the slow internet, but not the Belkin MIMO router connection issue: http://www.wibbler.com/archives/2007...ess_intern.php |
| Wireless Internet problems | Browsers & Mail | |||
| Internet problems through wireless router. | Browsers & Mail | |||
| Problems with internet connection either wireless or DSL | Vista security | |||
| please help wireless internet problems with latop | Vista General | |||
| Vista Ultimate: Wireless network connection problems and slow internet access | Vista networking & sharing | |||
