| | Battery Alarm I got a new Toshiba laptop that runs Vista. My problem is that my battery alarms haven't worked since I got it. Any Ideas? |
| | Re: Battery Alarm JA wrote: > I got a new Toshiba laptop that runs Vista. My problem is that my > battery alarms haven't worked since I got it. Any Ideas? This is directly related to Toshiba's power management software or if they didn't create power management software for Vista (they did on their laptops running XP), there is a problem with the Vista power management functions. The operative words here are "new laptop". Contact Toshiba tech support immediately. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| HP 6600 low battery audio alarm not working | Vista General | |||
| battery alarm - turn back on?? | Vista General | |||
| Critical Battery Alarm Not Working | Vista hardware & devices | |||
| Laptop battery issue ??battery calibration?? | General Discussion | |||
| low battery alarm | Vista General | |||
