| Guest | C:\Users\All Users is a shortcut, not a junction This one would seem to be quite a major bug, unless I've missed something, or it's been fixed by one of the recent updates. The link 'All Users' in c:\Users would appear to be a shortcut to c:\ProgramData rather than a junction to it. This means that any application attempting to write to c:\Documents and Settings\All Users\.... or to its subfolders would fail. and hence might explain some of the compatibility problems with older programs that people are having. If that is the case then you can fix the problem by deleting the 'All Users' shortcut in C:\Users, and running this command from an elevated command prompt mklink /j "C:\Users\All Users" "C:\ProgramData" If I've made a mistake here, then please let me know. -- Jon |
| Guest | Re: C:\Users\All Users is a shortcut, not a junction "Jon" <Email_Address@SomewhereOrOther.com> wrote in message news:OpFYOVoXHHA.4520@TK2MSFTNGP06.phx.gbl... > This one would seem to be quite a major bug, unless I've missed something, > or it's been fixed by one of the recent updates. > > The link 'All Users' in c:\Users would appear to be a shortcut to > c:\ProgramData rather than a junction to it. > > This means that any application attempting to write to > > c:\Documents and Settings\All Users\.... or to its subfolders would fail. > > and hence might explain some of the compatibility problems with older > programs that people are having. > > > If that is the case then you can fix the problem by deleting the 'All > Users' shortcut in C:\Users, and running this command from an elevated > command prompt > > mklink /j "C:\Users\All Users" "C:\ProgramData" > > If I've made a mistake here, then please let me know. > > -- > Jon > > Oops, my mistake - looks like it's a symlink, not a standard shortcut. Still odd that it's the odd one out of the bunch, though. Anyhow apologies. Ignore the previous post. -- Jon |
| creating a shortcut in the All Users Start menu | Vista General | |||
| Help Run Dll C:\Users\ Users name\AppData\local\temp\axdeqxgo.dll | Vista security | |||
| Compare users in AD with an SQL table and insert the missing users | VB Script | |||
| Access All Users & Default Users Start menu | Vista file management | |||
| Apply Shortcut to All Users | Vista General | |||
