Vista - VPN & Smart Card reader problem
Old 03-07-2007   #1 (permalink)
Aleksandar
Hi ,
I have problem with MS Vista when I want to connect via VPN (pptp) and use
Smart Card for authentication.
Note:This connection & Smart Card works just fine on Windows XP
when I insert my smart card I get the following error:
"The card is available for use. However, the card is not the one being
requested, and cannot be used for the current operation."
error from event viewer:
System
- Provider
[ Name] Microsoft-Windows-Smartcard-Server
[ Guid] {4FCBF664-A33A-4652-B436-9D558983D955}
[ EventSourceName] SCardSvr
- EventID 610
- EventData
Message Access is denied.
Reader OMNIKEY CardMan 3x21 0
IOCTL GET_STATE
Does anyone have solution for this problem ?
thank's
P.S. all settings are indentical on Vista and XP, eg. CRL; Root Certificate;
Conncetion parameters and etc.
CAC reader drivers? (smart card) Drivers
Smart Card Reader? Vista General
smart card reader? Vista hardware & devices
Smart Card Reader Vista General
How to turn off Smart Card reader Vista hardware & devices
