| Guest | Indexing is not running I've registered many folders in 'Indexing Options' - 'Modify'. There are about 2GB indexing files in C:\ProgramData\Microsoft\Search after indexing (200,000 files indexed). However, there are some corruption, so I completely remove all indexed folder, and rebuilt it from 'Advanced' menu. Now, C:\ProgramData\Microsoft\Search is completely empty. Then, I tried to add index locations in 'Indexing Options'. However, when I launched 'Indexing Options', there are no folders (of course!), and the dialog box says 'Indexing is not running' in the top. The problem is 'Modify' and 'Advanced' buttons are disable, so I cannot add location anymore. I've also noticed that 'c:\windows \system32\SearchIndexer.exe' is not working anymore. How can I restart index service? Thanks in advance. |
| Guest | Re: Indexing is not running On Mar 7, 11:21 am, "MJ" <art.orien...@gmail.com> wrote: > I've registered many folders in 'Indexing Options' - 'Modify'. There > are about 2GB indexing files in C:\ProgramData\Microsoft\Search after > indexing (200,000 files indexed). However, there are some corruption, > so I completely remove all indexed folder, and rebuilt it from > 'Advanced' menu. Now, C:\ProgramData\Microsoft\Search is completely > empty. > > Then, I tried to add index locations in 'Indexing Options'. However, > when I launched 'Indexing Options', there are no folders (of course!), > and the dialog box says 'Indexing is not running' in the top. The > problem is 'Modify' and 'Advanced' buttons are disable, so I cannot > add location anymore. I've also noticed that 'c:\windows > \system32\SearchIndexer.exe' is not working anymore. > > How can I restart index service? Thanks in advance. There are a service 'Windows Search' that launches 'C:\Windows \system32\SearchIndexer.exe /Embedding'. However, when I restart the service, I got the following error message: --- Windows could not start the Windows Search on Local Computer. For more information, review the System Event Log. If this is a non-Microsoft service, contact the service vendor, and refer to service-specific error code -2147218141. --- When I search a specific keyword in Windows Explorer's search box in right top corner, the yellow caption bar pops up with 'Your searches might be slow because the index is not running. Click to turn on the index...'. So I click the bar, turn on the index in the following dialog box: [Window Title] Turn on Index [Main Instruction] Do you want to turn on the index? [Content] Searches will be faster if you turn on the index. [Turn on Index] [Cancel] But, turning on index in the dialog box does not work. Still no index service are running. |
| Guest | Re: Indexing is not running I have exactly the same problem and still didn't find a solution. by the way, i'm running RC1... "MJ" wrote: > On Mar 7, 11:21 am, "MJ" <art.orien...@gmail.com> wrote: > > I've registered many folders in 'Indexing Options' - 'Modify'. There > > are about 2GB indexing files in C:\ProgramData\Microsoft\Search after > > indexing (200,000 files indexed). However, there are some corruption, > > so I completely remove all indexed folder, and rebuilt it from > > 'Advanced' menu. Now, C:\ProgramData\Microsoft\Search is completely > > empty. > > > > Then, I tried to add index locations in 'Indexing Options'. However, > > when I launched 'Indexing Options', there are no folders (of course!), > > and the dialog box says 'Indexing is not running' in the top. The > > problem is 'Modify' and 'Advanced' buttons are disable, so I cannot > > add location anymore. I've also noticed that 'c:\windows > > \system32\SearchIndexer.exe' is not working anymore. > > > > How can I restart index service? Thanks in advance. > > There are a service 'Windows Search' that launches 'C:\Windows > \system32\SearchIndexer.exe /Embedding'. However, when I restart the > service, I got the following error message: > > --- > Windows could not start the Windows Search on Local Computer. For more > information, review the System Event Log. If this is a non-Microsoft > service, contact the service vendor, and refer to service-specific > error code -2147218141. > --- > > When I search a specific keyword in Windows Explorer's search box in > right top corner, the yellow caption bar pops up with 'Your searches > might be slow because the index is not running. Click to turn on the > index...'. So I click the bar, turn on the index in the following > dialog box: > > [Window Title] > Turn on Index > > [Main Instruction] > Do you want to turn on the index? > > [Content] > Searches will be faster if you turn on the index. > > [Turn on Index] [Cancel] > > But, turning on index in the dialog box does not work. Still no index > service are running. > > |
| Indexing is not running pop up | Vista performance & maintenance | |||
| Folders do not display in Indexing Options / Indexing Locations | Vista file management | |||
| Indexing service isn't indexing a particular file under documents. | Vista file management | |||
| Indexing is not running?? | Vista General | |||
| Is indexing running at the moment? | Vista General | |||
