Vista - I / PC needs help plz
Old 03-08-2007   #1 (permalink)
help me
ok so i got vista ultimate (yey) but now my sodding fans wont shut up! the
cpu temp is only 30c. and the cpu fan is going at 4,500 rpm! the psu is
going at full wak and the side fan is going at 3,500rpm ! it's so noisy
here. any suggestions? ohh yeah and my comp specs are this
abit 4core vista premuim ready mobo
intel core 2 duo e6660 (i think) (2 x 1.86 no overclock)
ati x1650 pro 512mb pci-e graphics
1TB HDD sata
22" widescreen lcd (don't know if it makes any difference i woulnt imagine
it would but hey)
2.5 GB ram ddr2
ohh btw it was quite in XP and my cpu fan is a "stock fan" style by
coolmaster (the one with the huge tube attached to the end)
any ideas?
Old 03-08-2007   #2 (permalink)
ChrisM
Re: I / PC needs help plz
In message 4D999A77-ED21-44D8-A02B-D18571C7FAA6@microsoft.com,
help me <noname@noname.com> Proclaimed from the tallest tower:
> up! the cpu temp is only 30c. and the cpu fan is going at 4,500 rpm!
> the psu is going at full wak and the side fan is going at 3,500rpm !
> it's so noisy here. any suggestions? ohh yeah and my comp specs are
> this
> 1TB HDD sata
> imagine it would but hey)
> 2.5 GB ram ddr2
> any ideas?
I'm prepared to stand corrected, but I wouldn't have thought that the OS
would get involved in controlling the fans...?
That must surely be a hardware/bios issue??
I suppose it IS possible that Vista is making higher demands on the system,
and so raising the temperature/setting the fans off more(??). Have you tried
turning off the high demand graphical functions (if they are currently on)
temporarily and seeing if that makes any difference??
Have you looked in the bios settings to see if there is a 'quiet' mode or
something?
Regards,
Chris.
(Remove Elvis's shoes to email me)
Old 03-08-2007   #3 (permalink)
Synapse Syndrome
"ChrisM" <chris_mayersblue@suedeyahoo.com> wrote in message
news:OyRdspXYHHA.208@TK2MSFTNGP05.phx.gbl...
>> this
>> 1TB HDD sata
>> 2.5 GB ram ddr2
>> any ideas?
> system, and so raising the temperature/setting the fans off more(??). Have
> you tried turning off the high demand graphical functions (if they are
> currently on) temporarily and seeing if that makes any difference??
> something?
Yeah. I have never had an Abit motherboard, but Asus have AI-Quiet 2 in the
BIOS to control fan speeds. There must be something like that in the Abit
BIOS or some Abit software. Otherwise the OP could try something like
Speedfan or something more simple.
http://www.almico.com/speedfan.php
ss.
Old 03-08-2007   #4 (permalink)
CJM
"Synapse Syndrome" <synapse@NOSPAMgomez404.elitemail.org> wrote in message
news:dYidnZD_CMPtn23YnZ2dnUVZ8v2vnZ2d@bt.com...
> the BIOS to control fan speeds. There must be something like that in the
> Abit BIOS or some Abit software. Otherwise the OP could try something
> like Speedfan or something more simple.
Speedfan may or may or not work on that mobo but it's worth a try.
Usually these features work at a BIOS level, perhaps with supporting
software tools, eg. ASUS QFan and the ASUS AI Tools. I expect Abit have
something similar.
Old 03-08-2007   #5 (permalink)
Kerry Brown
Look for a couple of things on the abit support site - an updated BIOS that
supports Vista, and/or updated chipset drivers that support Vista.
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca
"help me" <noname@noname.com> wrote in message
news:4D999A77-ED21-44D8-A02B-D18571C7FAA6@microsoft.com...
> 1TB HDD sata
> it would but hey)
> 2.5 GB ram ddr2
> any ideas?
Old 03-09-2007   #6 (permalink)
ChrisM
In message uU4$DJZYHHA.2556@TK2MSFTNGP02.phx.gbl,
CJM <cjmnews04@newsgroup.nospam> Proclaimed from the tallest tower:
> message news:dYidnZD_CMPtn23YnZ2dnUVZ8v2vnZ2d@bt.com...
>> 2 in the BIOS to control fan speeds. There must be something like
>> that in the Abit BIOS or some Abit software. Otherwise the OP could
>> try something like Speedfan or something more simple.
> have something similar.
Oi!
Who are you, and who said you could use my initials??? :-))
Regards,
Chris.
Old 03-09-2007   #7 (permalink)
What a bastard?
news:%23WchxbkYHHA.1220@TK2MSFTNGP03.phx.gbl...
> Oi!
> Regards,
> Chris.
Old 03-09-2007   #8 (permalink)
CJM
I think you will find you are using mine...
Chris M
