Vista Tutorial - Caps Lock key Bleep - how?
Old 03-08-2007   #1 (permalink)
Dennis
Guest
My self-learned typing using one finger from each hand doesn't allow me to
look at the screen while typing. In Windows XP I knew where to go in
Control-Panel to have my Caps Lock bleep at me when I hit it because 90% of
the time me hitting the Caps Lock key is a mistake.
I'd like to know where I can set my -bleeping- Caps Lock key.. Thanks.
Old 03-08-2007   #2 (permalink)
Opinicus
Guest
Re: Caps Lock key Bleep - how?
Control Panel > Accessibility Options > Keyboard > ToggleKeys > [x] Use
ToggleKeys > OK.
Bob
http://www.kanyak.com
Notification area/ How to get rid of Caps Lock, Scroll Lock Vista General
Caps Lock Off Vista General
CAPS lock / SHIFT lock difficulty Vista General
Caps Lock problems Vista General
caps/num lock Vista installation & setup
