Vista Forums Home Join Vista Forums Windows 7 help and support Forum Vista Tutorials Tags
Go Back   Vista Forums > Vista Newsgroup Archive > Vista Newsgroups > Vista General
RB
Vista - Sound from onboard and soundcard?
03-11-2007   #1 (permalink)
keiron99@hotmail.com
My motherboard has onboard sound, but I also have a sound card plugged
in too. Try as I might, I can't find a setting that enables me to use
both at the same time. I've been into the BIOS to ensure it's enabled,
but right clicking on the speaker icon which takes me into Playback
Devices, only allows you to select one output as a default, so I can
only switch between the two (which wouldn't be so bad, as long as
there was a quick and easy way to do it).
Is there either:
- a way to enable both at the same time, or
- a quick and easy way to switch between the two?
Thanks
03-11-2007   #2 (permalink)
Just out of curiosity, why do you need both ?
03-11-2007   #3 (permalink)
Re: Sound from onboard and soundcard?
I want one to run to the monitor (with built in speakers) and one to
my hi-fi amp.
03-11-2007   #4 (permalink)
Could you not just use a splitter on the audio out to direct the sound to both places ?
Similar Threads for: Sound from onboard and soundcard?
Onboard mobo sound or dedicated sound card? Sound & Audio
Realtek onboard sound and Visat 64 Vista hardware & devices
Using the onboard sound driver Vista General
Can I use a sound card as well as onboard audio? Vista General
DVD CDROM Onboard sound Vista hardware & devices
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
