| | Another Sleep mode problem. Temporary "fix" with S1?? There are several posts about problem with Sleep mode in Vista. On my PC the problem was that when putting the PC on Sleep, it took some 90 seconds to wake it up. A normal start takes only 60 seconds. As I understood, the computer was making a complete restart when pressing any key after Sleep mode. There was a black screen for at least 30 seconds before it started to load Windows. Now I have got that part to work, well partially. I really don't know if it goes to Sleep according the MS intention, because fan keeps running. What I did, after comparing with the settings on my XP computer, was to change in BIOS. The parameter Suspend Mode was changed from [Auto] to [S1 (POS) Only]. The motherboard I am using is ASUS P5W-DH De Luxe. The OS is Vista Home Premium 64 bit. However, now there is another "problem". The PC is waking up as soon as one touches the table. By putting the mouse on a cushion, fix that problem. I have tried to untick the box "Allow this device to wake up the computer" for the mouse, but it does not work. After reading several posts about this Sleep problem, I wonder where the error is. In Vista or BIOS? Do we know if Microsoft is working on the problem? This is how it should work: http://www.microsoft.com/windows/pro...andresume.mspx |
| | Re: Another Sleep mode problem. Temporary "fix" with S1?? Did you follow their advice? ------------QUOTE----------------- For optimal speed and performance when putting the PC to sleep, and when resuming it, purchase a new PC with Windows Vista preinstalled, rather than upgrading an existing PC. -----------------UNQUOTE--------------- af Gultarp wrote: > There are several posts about problem with Sleep mode in Vista. > On my PC the problem was that when putting the PC on Sleep, it took some 90 > seconds to wake it up. A normal start takes only 60 seconds. > As I understood, the computer was making a complete restart when pressing > any key after Sleep mode. There was a black screen for at least 30 seconds > before it started to load Windows. > > Now I have got that part to work, well partially. I really don't know if it > goes to Sleep according the MS intention, because fan keeps running. > > What I did, after comparing with the settings on my XP computer, was to > change in BIOS. The parameter Suspend Mode was changed from [Auto] to [S1 > (POS) Only]. The motherboard I am using is ASUS P5W-DH De Luxe. The OS is > Vista Home Premium 64 bit. > > However, now there is another "problem". The PC is waking up as soon as one > touches the table. By putting the mouse on a cushion, fix that problem. I > have tried to untick the box "Allow this device to wake up the computer" for > the mouse, but it does not work. > > After reading several posts about this Sleep problem, I wonder where the > error is. In Vista or BIOS? > Do we know if Microsoft is working on the problem? > This is how it should work: > http://www.microsoft.com/windows/pro...andresume.mspx > > > > |
| Vista "Sleep" and "Hibernate" problem | General Discussion | |||
Problem with "Sleep" mode | General Discussion | |||
| Subject: Vista question about "compatibility mode" and "safe mode" | Vista General | |||
| Does Vista 'sleep mode' suspend all "scheduled tasks" until awaken again | Vista General | |||
| Wirless Network Doesn't work after "hibernation or sleep" mode | Vista networking & sharing | |||
